Old 06-28-2006, 08:00 AM   #7351
maskedrider's Avatar
Originally Posted by robert maestrey
Thinner oil = softer diff car will have more off throttle steering less on power
thicker oil= opposite as above..........
Usually higher traction tracks you want stiffer diff, less traction softer diff
Robert Maestrey
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 06-28-2006, 10:05 AM   #7352
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Has anyone had any problems with the front dog bones (CVD's) barely fitting into the cups???
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 06-28-2006, 10:18 AM   #7353
Mike Ellis's Avatar
Providing the axles are the correct ones maybe check the width of the front end. Most often it will be 199mm measured at outside of tires at 0 camber
Mike Ellis is offline   Reply With Quote
Old 06-28-2006, 10:24 AM   #7354
litespeed-dom's Avatar
Yup!
Also per instructions, there is shim between the 1-way "tube" and the outdrives, don't forget those.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 06-28-2006, 11:16 AM   #7355
Ice_nl's Avatar
Send a message via MSN to Ice_nl
should there also be some sort of shim when running a diff up front? As the front cvd's pop out of the cups. sometimes when hitting the grass or just under normal running. I already changed track width from 199to 194mm but it didn't help. When running the one way i don't have any trouble with the CVD's.
RC-Models.nl | Shepherd Velox V8 EC OM-Edition | Shepherd Velox F1 | Buri Racer E1.2 | Tamiya 419x
Ice_nl is offline   Reply With Quote
Old 06-28-2006, 11:28 AM   #7356
I just put a diff in my car, I'll check it out tonight on how much "meat" the CVD has on the outdrive and report back.
Dom
Old 06-28-2006, 11:32 AM   #7357
boner's Avatar
make sure you use the right length outdrive when you build the front diff. The front diff outdrive is longer than the rear, VZ218 - I think that's the outdrive required..
boner is offline   Reply With Quote
Old 06-28-2006, 12:22 PM   #7358
R/C Tech Charter Subscriber
Finally got my WCE home and started building it and what do I find. Kyosho packed 2 left front bulkhead parts trees in the kit instead of a left and a right. Kinda puts a damper on the mood. Guess I just have to wait for them to send me the right one. Oh well atleast I have a spare left front bulkhead.
NismoSkyline17 is offline   Reply With Quote
Old 06-28-2006, 12:25 PM   #7359
Osiris 75's Avatar
Yep, I installed the front diff, and that's when I noticed the problem. I used the exact out drives the manual mentioned, and it was running fine. All of the sudden the dog bone is barely in the cup, and it starts the front tire to start wobbling. When I try try to maybe pull out the cup a little, it doesn't budge.
Chris Kemper
Old 06-28-2006, 12:31 PM   #7360
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Dom
Diff in your car why?? I took my out
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 06-28-2006, 01:00 PM   #7361
Just trying something different.... you know me, I'm always wanting to go faster... I actually will be testing a spool too.
Dom
Old 06-28-2006, 01:42 PM   #7362
drfritz's Avatar
MMMM sounds like some problems at the factory, I had two sets of front cvd that were packaged wrong also, they were to long toasted both sets before I figured out they were wrong,.sure wished I had kept the header card that came with the parts, nothing I can do about it now. I'm just out the 100.00
drfritz is offline   Reply With Quote
Old 06-28-2006, 01:54 PM   #7363
Dan, do you at least have the receipt with the part number on there? Or invoice if you ordered online? Part# would be on there.... If the wrong CVDs were in the package and I can get some kind of proof, I might be able to get it sorted out with Kyosho America for you.
Dom
Old 06-28-2006, 11:39 PM   #7364
drfritz's Avatar
Dom
You have Pm.
Old 06-28-2006, 11:59 PM   #7365
Yup!
Dom
is it that small plastic round ring ?? I did not fit it since day one when i got my WC....
Mainly i just insert the one way outdrive into the Oneway......SO far no problem whatsoever is it...but is it a must to fit it
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
