Kyosho v-one rrr
#721
Re: Re: Finished
Originally posted by InitialD
Nice job Mark ! Not forgetting the number of lies and days the GF has been deprived !
#722
i ran the car today for the first time. i had some problems at the beginning but overall i am happy. i do not like the throttle linkage though. the ball cups seem to come off easily. i am pretty happy though. tomorrow i have a race--- so we will see. i was planning on running my mtx-3 but i think i will go with the rrr.
#723
#724
Originally posted by kidDynomite
I wouldn't go with the 3Racing shaft. Since the 2 pin holes are so close together, it snapped on me. I'd stick to the stock one until the hollow shafts come out. I have the Kyosho hollow shaft in my Evo...very light, very strong.
#725
3434 posted a picture of the 3Racing middle shaft. It's drilled twice in the middle to fit both the V-One R and V-One RR Evolution. Thier stuff isn't really high quality and I wouldn't use anything they make for high stress applications.
I now have all 3 shock towers(stock, Kyosho VZ056, and Kawahara V-One RR Evolution shock tower) to compare. I think the Kawahara is the best. It mounts securely to the bulkhead like the stock, has 4 holes( 1 more than the graphite Kyosho unit) and has a more linear arc to the shock positions.
#726
rossirocket, i think the rrr is faster out of the hole. i like the way the parts are universal--- could be left side or right side. but i do think the mtx-3 is a more fundamentally sound car. there is no play in the front upper arms, no binding that needs to be drilled out. the plastics are tougher--- the rrr plastics are much more brittal and will crack easier. having said all that, i think with the proper attention and changes, the rrr has more potential. i have a bunch of small changes i want to do, then i think it will be good. i will run the rrr for now.
#727
Re: Front toe.
Originally posted by markp27
Maybe I've missed something, but I can't seem to adjust the front toe, whilst the RRR is mounted on the Hudy setup prisms.
I see there is a little hole in both steering rods, but the upper arms prevent access to it
Is there an easy way of doing this?
Cheers, Mark.
Cheers, Mark.
#728
The RRR is easier to work on, just as high in quality as the Mugen. I used to have a Mugen last year. When the Mugen first came out, it too had some slop issues with the rear arms. The MTX-3 is a great car all around, but the RRR just takes it to the next level. I'm sure when the MTX-4 comes out( whenever that is) it will be an even better car than the 3 and probably better than the RRR. For someone starting out, I would point them to the Mugen for sure. The Kyosho is more sensitive to setup changes, a little trickier to setup/drive for the unexperienced but very fast when setup.
#729
Re: Front toe.
Cheers, Mark.
Cheers, Mark.
#730
Originally posted by rossiRocket
How does the RRR compare to the MTX-3, in terms of handling and overal build-quality and value?
#731
Does anyone have problem with the RRR shock, Does it leak oil? Does the shock ball end pop out easily when front end hits? I have an Evolva, and the Evolva shocks look like the RRR ones. The black diaphragm in the shock inverts upward after awhile. Worst, it cannot seal properly.
The shock ball end on the Evolva may pop out very easily. I wonder whether RRR suffers from the same problem?
#732
I race my RRR today and the car was DIALED! This is the best handling RC car I've ever had (and I had a few). Out of the box setup the car has plenty of steering yet the rear end is very stable and won't come loose. When temperture droped and traction came up in the late afternoon many people were traction rolling yet I can still enter turns by letting off instead of using brakes without worrying about traction roll. Unfortunately I blew my motor at the 20minute mark and DNFed but I was catching up to 3rd quick from a lap down when my motor gave.
#733
#734
GOT MY KIT - At last..
Hi
I received my V one RRR kit today. Just looking at the box gave me goose bumps... !! lol ! well i hope that the driving does that too...... I had just started driving the fw05r last month and it handles quite well but i keep loosing the tyres all the time..... I mean the sponge just chips off....... usually its the front end every day at the track and i loose a pair !! Since i am new to racing at the tracks... i guess thats normal ? or is it ??
Well just wanted to know.... does the car handle as well as the fw05R or better? ? the guys who have driven them both shuold know...... ?!
MY track out here... is very dusty...... so i guess the front one way would not be a good idea.. since it makes the car slip while braking ?? in case i need to get the stock diffs which ones are right 1s for the vone3r ?
Regards
Aziz
Regards
Aziz
#735
What do you mean "since the 2 pin holes are so close toether..." Isn't the 3Racing Ti shaft the same exact dimensions as the stock piece, just different material?
