Old 06-21-2006, 02:01 PM   #7321
ziggy12345's Avatar
Arrow
I just installed the RPM counter from Spektrum on the RRR. At first i was having trouble finding a place for it then I saw you could mount it just below the rear bracket that holds the roll bar. It looks directly at the layshaft. I put a shiny sticker on the shaft and it picks it up no problem and really neat installation.
To get the MPH from the middle shaft RPM you need the following roll out
Rear tyre dia
59mm 0.005047581
60mm 0.005133134
61mm 0.005218686
62mm 0.005304238
63mm 0.00538979
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-21-2006, 02:51 PM   #7322
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I fitted the RPM Counter on the front One-way tube using a lexan bracket from the upper deck. Used a screw and nut in the middle hole in the front part of the deck. Fits very nice.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 06-22-2006, 12:24 PM   #7323
fastrcracer's Avatar
Default RRR WCE
What pinion spur gear combinations come in the RRR WCE kit ?
Associated FT SC10
Futaba 3PK
AKA Tires
Maxamps Batteries
SRI Raceway, Louisville KY
fastrcracer is offline   Reply With Quote
Old 06-22-2006, 03:39 PM   #7324
V1-RRR-WC's Avatar
1st - 16/61
2nd - 21/56
V1-RRR-WC is offline   Reply With Quote
Old 06-22-2006, 03:51 PM   #7325
ziggy12345's Avatar
Anybody using the Evolva front shock for the rear of the RRR?
Cheers
Sponsored by:
Norfolk and Chance
Old 06-23-2006, 07:17 PM   #7326
Default Shock Towers
I have about five 4mm shock towers. I had them made at a shop that does carbon fiber work for trinity, in my opinion, very good work. i have about 5 extra that i will never use. they are pretty much indestructable. if anyone needs one, let me know, i will give it for free.
Joe Chaplow is offline   Reply With Quote
Old 06-23-2006, 08:24 PM   #7327
Send a message via MSN to ickvanovs
Cheers
will it fit? any impact in performance?
ickvanovs is offline   Reply With Quote
Old 06-23-2006, 08:39 PM   #7328
robert maestrey's Avatar
they are very well made Joe is a friend of mine....ill take one joe..
robert maestrey is offline   Reply With Quote
Old 06-24-2006, 05:35 AM   #7329
hey robert,
whats up man. i was talking to renee yesterday and he told me you are messing around up west palm some nowadays. i will be out of town this weekend (leaving in 15 minutes) and out of town the following weekend as well. should be around the two weekends following that. i want to check that track out. maybe we could go up there in two weekends. but that may interefere with the GLC, i dont know the dates. anyhow, let me know and i will save one of the towers for you.
joe
Old 06-24-2006, 04:36 PM   #7330
jeff1's Avatar
What is the meaning of "Camber Angle 0G"? I have hudy set-up station, I understood that I should put 0║ of camber. Is this correct?
How you guys adjust the width? My tatical is line up the thread of the pillow ball to the arm, and then turn clockwise 1/2 in the both sides (the same amount I turn in one side I do in the other). I never saw the others guys making this adjust, so I am just curious to know how they do it.
jeff1 is offline   Reply With Quote
Old 06-24-2006, 04:51 PM   #7331
dougday's Avatar
Use camber angle 1G. 0 is for when the car is elevated
dougday is offline   Reply With Quote
Old 06-25-2006, 08:31 AM   #7332
maskedrider's Avatar
found out that rear tires wear unevenly....
the outer layer wear out more then inner layer of the tires.... normal ?
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 06-25-2006, 08:56 AM   #7333
Increase your negative camber Maskedrider, always set the camber for even wear on the tires even if you end up at 4 degrees on one side and 2 on one side. I do very seldom use a camber gauge, only use it for checking when im writing down setups.
Old 06-25-2006, 09:19 AM   #7334
adjust in here ?
Old 06-25-2006, 11:06 AM   #7335
Originally Posted by maskedrider
adjust in here ?
Exactly, shorten it.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
