Old 05-30-2006, 08:19 PM   #7096
need-4-speed's Avatar
Originally Posted by rmdhawaii
Excellent tip. I'll have to keep this in mind for the next race. I bet it works in the opposite direction as well.
Inside joke: I thought the Hokage outlawed Nitro racing in the Village? Have you and Naruto been at it again?
You know Naruto, always breaking the rules!
need-4-speed is offline   Reply With Quote
Old 05-30-2006, 09:13 PM   #7097
ttr_racer's Avatar
Trader Rating: 23 (100%+)
Check this out
http://www.rctech.net/forum/showthread.php?t=116009
ttr_racer is offline   Reply With Quote
Old 05-30-2006, 10:23 PM   #7098
V1-RRR-WC's Avatar
Originally Posted by need-4-speed
Just a tip: If your car is pushing that means the rear of the car has too much traction. By removing the rear sway bar you have actually made the push even worse. A better approach would be to flatten your front sway bar, then maybe stiffen the rear sway bar to free up the rear and give you more turn in. Another tuning option would be to dial out some rear toe. You can also increase the amount of droop in the rear to increase the response of your car when turning. There are a lot of tuning options to fix a push. Just try them one at a time until you hit the sweet spot. I hope this helps.
Thanks!
I have taken note.
But about the tire dia. (Front & Rear) I consider this very improtant to get maximum effect of the settings you listed.
V1-RRR-WC is offline   Reply With Quote
Old 05-31-2006, 12:27 AM   #7099
antoine80's Avatar
Originally Posted by jeff1
Guys I am bulding a RRR is not WCE and I noticed a lot of play in the upper suspension arm I tried some shims combination but did not work.
Any sugestion?
Thanksss
i have bought some claster clips from GS and used, i replaced the 1mm claster clip that came with RRR with a 1.7-2mm claster clip and now is working just perfect i am not sure about the width of it but it is almost the double of the standard one.
i used the stardard clip on the front side of the arm and inserted the new one on the end. i hope this helps
antony
antoine80 is offline   Reply With Quote
Old 05-31-2006, 01:23 AM   #7100
acutts's Avatar
Does anyone use this part?
Kyosho Roll-Bar for RRR-WRC-EVO vzw-33
acutts is offline   Reply With Quote
Old 05-31-2006, 02:01 AM   #7101
ziggy12345's Avatar
No but looks good! I use the one from the V-1-RR Jap cup version. It has the same holders and is metal
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 05-31-2006, 05:13 AM   #7102
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I set my fastest qual time on 57 front 59 rear. 37 shore front, 40 shore rear.
Final was full size rear and -2mm front :P
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 05-31-2006, 08:57 AM   #7103
dougday's Avatar
Acutts,
Where did you find this part and the picture?
dougday is offline   Reply With Quote
Old 05-31-2006, 10:14 AM   #7104
Nitro racing in Vxj
Google Video
TQ-spot = Sparx
Old 05-31-2006, 10:29 AM   #7105
kewdawg's Avatar
Any sugestion?
Thanksss
Use a thick silver shim from a 540 electric motor.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 05-31-2006, 10:40 AM   #7106
litespeed-dom's Avatar
Yup, I found a couple of real thin teflon shims in my motor box, worked out perfectly.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 05-31-2006, 10:50 AM   #7107
rmdhawaii's Avatar
Originally Posted by Sparx
Nitro racing in Vxj
Google Video
TQ-spot = Sparx
Cool video! Thanks for sharing it!
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-31-2006, 10:54 AM   #7108
rmdhawaii's Avatar
Any sugestion?
Thanksss
Kyosho makes a 3mm washer set that will allow you to shim to the exact size.
Old 05-31-2006, 03:04 PM   #7109
jag
jag's Avatar
I like the car planted in the rear, since i have a quite aggressive driving style (for example, i had about 3mm foam left on my left rear wheel after the main ) The traction was also a bit low so the 7000 wt diff helped the car to feel more planted (got a bit more corner entry steering too because of the loose diff). The steering was dead on, never driven such a fast yet easy to drive car.
Will try some rollcenter adjustments with the front upper A-arms this weekend.
Sounds good. I think I may try a few of your ideas.
jag is offline   Reply With Quote
Old 05-31-2006, 03:10 PM   #7110
jag
jag's Avatar
Part number please...
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
