Old 05-27-2006, 05:21 AM   #6976
maskedrider's Avatar
can be use on this clutch bell When i using the Kyosho pinion opener ? Any precaution that i make ? seems like hte hex hole can only fix in either holes on the bell...and how abt the rest ?
hawaii, your tools like my groundnuts opener
ok. ok...jokes aside, didn't saw any of this tools in my LHS
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 05-27-2006, 06:00 AM   #6977
itchy b's Avatar
[QUOTE=rmdhawaii]I just bought the Hudy Excellent Tire Truer w/arbor. OMG. I think I'm going to be sick.... Excuse me, I'll be right back...[HTML]
I would say, that this is my first reluctant R/C purchase. It it were $200-300, it wouldn't be so bad. But $500! [PHP]
i wish the hudy truer was that cheap in australia
here we have to pay around the $800-$900 mark to get that type of quality
thats why i settled for the eagle racing truer for $300-$400.
i can spend more on my car instead
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 05-27-2006, 06:10 AM   #6978
ziggy12345's Avatar
Originally Posted by rmdhawaii
The SP belts comes standard on the WCE, but I guess you could consider it an upgrade if you're just running the standard RRR.
As far as the rollbar holder goes, how would you best describe how it improves handling? Does it provide additional tuning options?
No it seems to be more predictable at the front. The droop setting is more deffinate
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 05-27-2006, 08:45 AM   #6979
jag
jag's Avatar
I used an alum front sway bar holder on my 710 and it worked well. It's a little more precise and consistant. It also does not allow any flex. The only issue I had was that it could bind the suspension if it does not fit correctly. When you rotate the cams it can bind the hinge pins. Just make sure it works right after you set the droop and tighten everything down. I had to do some modifying to get mine to work right on my 710.
jag is offline   Reply With Quote
Old 05-27-2006, 09:02 AM   #6980
jag
jag's Avatar
Try some Malox or Immodium.
You should find someone that has another truer so you can try it. Otherwise you won't be able to fully appreciate the Hudy.
Well, now I think I have eveything I could ever need...
Uh, except . . .
Yeah right... for today maybe. Face it, you are addicted. The first step to recovery is admitting your addiction.
I better keep that list to myself...
Oh please share... we all have that list. Sharing may not help you but it might give others something to add to their list.
Old 05-27-2006, 09:12 AM   #6981
robert maestrey's Avatar
I use them...the reason why i do is because the droop set screw sits on metal instead of plastic......in a hard collision or when is comes to wear its less likely the aluminum fail before the plastic there is no additonal tuning features that i have noticed
robert maestrey is offline   Reply With Quote
Old 05-27-2006, 09:52 AM   #6982
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hudy
i have an integy truer i used my buddys hudy its all that i will get 1 some day i cut some tires in 1 wack i was done beautiful
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 05-27-2006, 06:26 PM   #6983
Osiris 75's Avatar
Trader Rating: 17 (100%+)
We have to crawl before we can walk. I'm crawling right now!!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 05-27-2006, 06:31 PM   #6984
badKarma's Avatar
Send a message via AIM to badKarma Send a message via Yahoo to badKarma
question, i only have 1 nitro build under my belt, a NTC3, but im looking for a new car to race this summer. I like the V one RRR, but i heard the instruction manual is difficult for novice builders like myself, is this true? and also, what K factory hop up parts are available for this car?
badKarma is offline   Reply With Quote
Old 05-27-2006, 06:34 PM   #6985
rmdhawaii's Avatar
The car is easy to build. Trust me. Also, go to my Web site and go through the build tips. It has almost everything you need to know. In the links section, you will find a link to the K Factory Racing Web site. If you pick up the car and have any problems, just come back here and we can help you out.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-27-2006, 06:36 PM   #6986
rmdhawaii's Avatar
GQ Tires came today and I'm starting to understand why the wheels are so durable. Check out the wheel design.
Old 05-27-2006, 06:41 PM   #6987
litespeed-dom's Avatar
NICE! The spokes are thicker in general compare to other spoked wheels. Also check out the edge of the wheel on the backside, the edge is chamfered.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 05-27-2006, 07:00 PM   #6988
rmdhawaii's Avatar
Dom
Sweet! That should take care of some of that front shock end cap scraping that normally occurs with standard wheels. We'll see how they perform next weekend.
Old 05-27-2006, 07:16 PM   #6989
badKarma's Avatar
shouldnt i just wait for the EVO to come out instead of purchasing the RRR right now?
Old 05-27-2006, 07:41 PM   #6990
Send a message via ICQ to momotalo
also the tyre is cheaper than the other brand.. hihihihi
and the preformace quite good
momotalo is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
