Old 05-22-2006, 04:28 PM   #6841
robert maestrey's Avatar
Hey Just want to give thanks to Jim(jag) and Eddie(shorts) for helping me out this weekend at the region 4 champs at ft.Myers...........Was a very fun weekend like always had a great time...The RRR ran wonderfully even though the track conditions were not prime...at times it was over 160 degrees track temp. the parm type m body had plenty of steering..I liked it personally... Got to give props to Jim he ran his best ever at Ft.Myers and this was the first time he used RRR there. Congratz On the 3rd place B-main finish that is Awesome.
Robert Maestrey
robert maestrey is offline   Reply With Quote
Old 05-22-2006, 04:46 PM   #6842
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Originally Posted by rmdhawaii
Sorry officer. I know the rules say 50mm max (not really), but I guess I wasn't paying attention and before you know it, I was over the 50mm limit. Can I just get away with a warning this time? I'll be sure to keep it at or below 50mm next time.
2006 Roar Rule Book
6.1.13 Cooling holes: Bodies for on-road fuel-powered cars (other than touring vehicle bodies)may have up to 1/3 of the windshield cut out. Bodies used on off-road fuel-powered cars may have up to 1/2 the windshield cut out. For touring vehicle windshields, one cooling opening is permitted, limited to a maximum of 60mm in any direction.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 05-22-2006, 05:07 PM   #6843
rmdhawaii's Avatar
Originally Posted by rcfoolz
2006 Roar Rule Book
Sweet!
I can't remember the size at the moment, but I'll be sure to measure it when I get home and let you guys how big it is.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-22-2006, 05:16 PM   #6844
litespeed-dom's Avatar
Sweet! I didn't know they changed it to 60mm, I've always been doing 50mm.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 05-22-2006, 05:26 PM   #6845
2006 Roar Rule Book
interesting James ive been doing 50 all this time...maybe thats why im leaning out
Old 05-22-2006, 05:42 PM   #6846
performula's Avatar
Originally Posted by litespeed-dom
I'm assuming you checked the shocks length and they are the same, and you disconnected the sway bar, right?
Could it be the plastic on the knuckle, where the pivot ball comes up got jacked and limiting travel?
Dom
New kit, never run. I disconnected the sway bar and the shocks are matched. Investigation techniques aren't working on my end. The manual calls for 4mm droop, at least both sides will match.
performula is offline   Reply With Quote
Old 05-22-2006, 06:06 PM   #6847
Trader Rating: 13 (93%+)
Default front up stop and adjusting those ear things on the arms
hey guys
i just wanted some info about adjusting the front upstops and how/when to adjust those ear things on the front lower arms
do you disconnect the sway bar and adjust the upstop to zero on the droop gauge ? then what do you do with the ear things ?
thanks
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 05-22-2006, 06:12 PM   #6848
rmdhawaii's Avatar
Originally Posted by mrgsr
hey guys
thanks
Ear things? Ear things?!
Dude! These things have part numbers.
Ah, sorry. Could you provide the part number please, I don't know what you're talking about.
Old 05-22-2006, 06:18 PM   #6849
haha umm
they are round with a point
at the bottom of the front lower suspension arm
part number vz206
Old 05-22-2006, 06:19 PM   #6850
Pretty sure he is talking about the ecentrics......right and left ones that attach to way bar.....
1-disconnect sway bar
2-make sure both ear things ecentrics are pointing in the same direction..they should be pointing towards the tires both exaclty the same..
3-set the droop accordingly with your preferd tools
4-then reconnect sway bars and recheck droop right and left should saty the same.
5-any change from left to right in droop after these steps cahnces are one of the sway bars must be bent...or your ecentrics are not set exactly the same might have to adjut them...
6-upstops are not used....
Hope this helps...
Old 05-22-2006, 06:23 PM   #6851
thanks robert
yep you got it spot on
its a brand new kit and my second rrr i just wanted to make sure this one was built right from the beginning
yep its down stop my mistake
Old 05-22-2006, 06:37 PM   #6852
jag
jag's Avatar
I'll let you off easy this time but don't let it happen again. If I catch you again your fine will be painting me a body.
Nice work on those bodies.
jag is offline   Reply With Quote
Old 05-22-2006, 06:47 PM   #6853
jag
jag's Avatar
Robert Maestrey
Thanks Robert. You should have brought home the 1st place trophy for the A main. I can't believe your transmitter battery went dead... while leading the race.
A bit of free advice to those of you out there like me... not an expert driver. Find an expert driver then watch and listen. It really helps.
Thanks again Robert. What are we going to do for the summer?
Old 05-22-2006, 07:35 PM   #6854
has anyone tried the k factory steel rear universals?
i am putting them on my wce now and noticed a lot of play in the hub,they are not fitting snug like the kit.
what i mean by play is my rear width can go from 200 to 210 because the universal slides back and forth in the hub.
bosfan is offline   Reply With Quote
Old 05-22-2006, 07:51 PM   #6855
rmdhawaii's Avatar
That's not good. My suggestion would be, pull one of them out, put the stock and the K Factory universal side-by-side and compare the two. What is difference?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
