Old 05-17-2006, 05:49 PM   #6661
litespeed-dom's Avatar
Originally Posted by carkillaii
Im sorry guys im lookin for the o-rings that are used as a failsafe
Again, go down to your local Ace Hardware.... they have different sizes, strength o-rings up the ying yang!
Ace Hardware needs to pay me for promotion today! Wait, maybe I can get a sponsor from them!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 05-17-2006, 06:46 PM   #6662
carkillaii's Avatar
Dom
lol thanks Dom
carkillaii is offline   Reply With Quote
Old 05-18-2006, 12:11 AM   #6663
AHP
Default Trust bearing grease
Hi all experts, please tell me what oil is being placed on the trust bearing as all of them seems to disappear after a round! In addition, what is the usual shimming gap for the inside and outside of the clutch bell? Thanks for advice in advance. Have you guys heard on RRR EVO? Heard it will hit Japan in June...
AHP is offline   Reply With Quote
Old 05-18-2006, 12:26 AM   #6664
As far as grease for the thrust bearing goes, a lot of people uses Mugen thrust grease. I personally use a white teflon-based grease made by Racer's Choice. It's been working flawlessly for me.
Dom
Old 05-18-2006, 12:39 AM   #6665
itchy b's Avatar
mugen super grease is the one mugen make for this application, and as for experts, theres no such thing because no 1 person knows everything, we all are constantly learning
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 05-18-2006, 12:52 AM   #6666
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I use Tamiya AW Grease. It's sticky so it doesn't get flung out of the bearing plus it does what it says: "Anti Wear". I actually use it for a lot of things like the front and rear outdrives and universal joints.I used to use Super Joiunt grease from Mugen but it's too thin to stay on for very long.
As far as shimming goes, each motor is usually different. That's just one thing that requires time and trial and error to get the right shimming. After you do it -a few times, it comes naturally.
-Just add shims behind the bearing till the bell doesn't drag when you spin it crankshaft pointing up.
-To make sure it right, remove one shim and spin test it again.
-If it drags then it's the right number of shims and you can put it back.
-If it doesn't then you used too many so take out a shim till it drags then add it back.
Racing4Evo is offline   Reply With Quote
Old 05-18-2006, 01:04 AM   #6667
itchy b's Avatar
super joint grease is different to super grease, i use both and super grease is the stickiest grease that i,ve come across so far, maybe there is a grease that is used in industry that is as thick and sticky, if not more so. most likely comes in larger packs for better value too! if anyone knows where some can be obtained, i'd be interested
EX1.5-SC10 4x4
Old 05-18-2006, 01:35 AM   #6668
Racing4Evo's Avatar
It sounds a lot like AW Grease. Is it metallic gray?
Old 05-18-2006, 01:54 AM   #6669
AHP
Default trust bearing grease
Hi, all!!! thanks for the instant reply!!!!!!!! I am using the super grease but it seems like it all disappear after a while.... anyway thansk alot!!!! So have you guys heard on the RRR EVO???? this is a great thread!!!!
Old 05-18-2006, 02:06 AM   #6670
itchy b's Avatar
its a dark brown colour and very thick and sticky as the proverbial.........
a friend found some grease that is used at his work for the machinery that is much like this but i'll have to find out the name of it and let you guys know
if anyones interested
EX1.5-SC10 4x4
Old 05-18-2006, 02:40 AM   #6671
antoine80's Avatar
Default shock oil
Hello again,
what oil do you use for shocks? i use the default oil that came with my kit (RRR), what is the difference in handling using thinner or hardest oil?
i change the rear differential oil from 30000 to 20000, i read the tip in the thred, now the car runs much better in the circuit i use to run
my main problem this moment is when i try to change car direction with a lot of spead, it seems like the fron side of the car doesn't "listen" very well.. and the car goes straight i tried to make the rear antiroll bar a bit hardest but it hasn't helped that much. any ideas?
antony
antoine80 is offline   Reply With Quote
Old 05-18-2006, 02:42 AM   #6672
maskedrider's Avatar
RRR evo in action at Taiwan Now
http://www.team-titan.com.tw/femca/h...S/20050516.htm
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 05-18-2006, 03:40 AM   #6673
luketob's Avatar
antony
your problem is the front side of the car, try changing with softer tires to get more bite as you don't have enough front traction that result the car understeer. If tires does not help either, you could try soften up the shock by lowering down the front shock position, also try adjusting you front sway bar as well. Just do one adjustment at a time so you won't get confuse.
Hope this helps.
luketob is offline   Reply With Quote
Old 05-18-2006, 05:00 AM   #6674
antoine80's Avatar
Hope this helps.
Fron sway bar your mean the front antiroll bar.. i think everything is antiroll bar for me
i will try the changes during the weekend and tell you
Old 05-18-2006, 06:20 AM   #6675
performula's Avatar
Originally Posted by maskedrider
Great photos!
performula is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
