Old 05-13-2006, 05:39 AM   #6541
Cowboy Bob's Avatar
I should have used the right name as I have CVD's for the front and rear in the kit, are the rear ones not correct?
Cowboy Bob is offline   Reply With Quote
Old 05-13-2006, 06:18 AM   #6542
B4
B4's Avatar
They are correct if you want to run 2mm offset which are the rears tires that come with the WCE kit. You just need to be aware otherwise you may order the wrong offset tires and wonder why you have great stability but reduced steering. It's up to you but i have found if for some reason i don't have enough tires at a meeting it is easier to get 0 offset tires from a fellow comptetitor.
B4 is offline   Reply With Quote
Old 05-13-2006, 07:19 AM   #6543
jag
jag's Avatar
B4 is correct. There is nothing wrong with the universals that come with the kit but if you want to run 0 offset wheel (which are much more common) you will want to use VSW007 universals. They are exactly the same as the ones in the kit except they come with a 2mm spacer that goes between the bearing and the hex. If you look back about 20+ pages you will see some pictures of it.
jag is offline   Reply With Quote
Old 05-13-2006, 07:22 AM   #6544
jag
jag's Avatar
Originally Posted by MIKE ELLIS
Sorry you are having that problem. I to noticed it. The other posts are a help but I did one more thing. If you choose the correct length screw you can use a distance spacer from the Jrxs c hub to move the screw head up farther so you don't have to grind as much plastic off. I actually didn't have to take much plastic off with the spacer installed. Be sure the screw doen't go through and hit the outdrive. Hope it helps, Mike
Be aware that if you do this you will be changing the roll center. Be careful, this can adversly affect the handling of the car.
Old 05-13-2006, 11:33 AM   #6545
rmdhawaii's Avatar
Originally Posted by B4
Hi,
Thought it's time to show some pics of my car. From the pics you can see I have modified the Top Deck for better access to the link on the servo horn. Notice the springs keeping the brake pads apart, also I have modiied the Skyline shock brace (two extra holes) so it will fit the new bulk head.
Thanks for sharing. Nice ride and pics - plus a few great ideas.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-13-2006, 01:56 PM   #6546
Munkmotion's Avatar
Smile Front Side Pulley... For Newbies like me...
Since building my kit (rrr not wc) a few months ago, I have been using the 23t pulley on the front. And using rubber tyres.
I read that rubber tyres need to be run with the 24t pulley on the front (to rid the car of the over drive), so I changed it over and took the car out to see what would happen.
The difference in handling is phenominal!
The car is now very solidly planted in sweeping corners, much less twitchy under braking, and the tyres actually last more than a few hours, amongst the many significant differences.
I realise this has been said before, but I would just like to emphasise it again, for those, like myself, who may be wondering if the slight overdrive really makes that much difference.
Next I will be changing the one way for a diff, and shall report...
Munkmotion is offline   Reply With Quote
Old 05-13-2006, 02:34 PM   #6547
rmdhawaii's Avatar
Sweet! Thanks for sharing that with us.
Old 05-13-2006, 03:39 PM   #6548
jag
jag's Avatar
Are the rubber tires the same diameter front and rear?
Old 05-13-2006, 05:01 PM   #6549
Osiris 75's Avatar
Trader Rating: 17 (100%+)
For the life of me, I cannot find the aluminum rear bulkheads, with the multiple post holes. Anyone know where I can find them???
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 05-13-2006, 05:19 PM   #6550
esham's Avatar
Originally Posted by robert maestrey
hey what kind of tires are those and were do you get them....
Robert - It is Chettah tires - Japan. I'm not that sure if u can get it in US. The tires glued well and the rim is tough. Good quality as Kawahara Tires.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 05-13-2006, 05:50 PM   #6551
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 05-13-2006, 06:32 PM   #6552
Munkmotion's Avatar
Default Sponge and Rubber...
Yes, all the same. The 23 tooth pulley is for sponge tyres, but when i put on the same diameter rubber front and back, it puts the car in a constant state of slide, i guess.
Which brings me to another question. Does anyone know of good rubber tyres that are also cheap? I know this is contradictory but thought it worth asking. I've found HPI Belted slicks have almost as much traction as sponges, but they are SO expensive!
Also, can someone clarify exactly what "shore" means? Yes, I am a newbie.
Old 05-13-2006, 06:46 PM   #6553
Default hmmm
[URL=http://]wp spec 3R[/URL ]LOOK OUT
WILLIAM PENDERGRASS
Old 05-13-2006, 08:10 PM   #6554
Shore is a word used for the hardness of tires less 35 soft 45 hard
bjones is offline   Reply With Quote
Old 05-13-2006, 11:08 PM   #6555
performula's Avatar
Enetti Enneti Ennetti Tires at $10.00 a box.
performula is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
