Kyosho v-one rrr
Old 05-08-2006, 06:41 PM
  #6436
Originally Posted by rmdhawaii
In the attached photo, you'll see two dimensions for the rear hub - 4.2mm and 4.5mm. These are the same for the RRR and the WCE. What are your measurements? Also, what is your rear camber setting?
BTW: It's 1:25AM here now. I'm sorry, but I'll have to resume this discussion some time tomorrow..
i don't know what my rear camber is at the moment because ive just loosely put the car together(i havnt put the main shaft in) so ive jjust set the camber roughly at about 2 degrees.
i will adjust the rear to 4.2mm and 4.5mm and come back and tell you what the rear track is.
what is soo confusing is that i got a pair of brand new out of the box GQ's and on the box it says offset: 0. I wonder if at the factory theve put the wrong tyre in the wrong box???
or is there offset scale backwards e.g 0offset in GQ is really 2 offset?????
oh and btw ive switched back to the stock plastic hexes but i get the same results with vzw010 and the plastic hexes.theres no difference between them except for ones metal and the other ones plastic
ae_ntc3 is offline
Old 05-08-2006, 06:51 PM
  #6437
tenderfoot57's Avatar
Quick question. I have three tanks that are leeking air from under the lid. I know that it is from the gasket getting old. Does anyone know the part number for the gasket and retainer clip.
Thanks for the help.
tenderfoot57 is offline
Old 05-08-2006, 07:12 PM
  #6438
ALMS FAN's Avatar
I have just finished putting together my rrr can any one tell me what 1/10
bodies are suppose to fit . I have tried the opel astra and the protoform mazda 6 but when you sit the body on top with the wheel cut outs in place
the front foam bumber wont fit under?????????
ALMS FAN is offline
Old 05-08-2006, 07:18 PM
  #6439
rmdhawaii's Avatar
You need to trim the bumper.
rmdhawaii is offline
Old 05-08-2006, 11:13 PM
  #6440
adl
had the same problem-i opted to use serpent gasket and retainer and no more problem a little bit more difficult to install ihad to remove cap from tank and i made the middle part of the clip bigger by using a reamer. if this is too hard for you to do i seen other guys just use 2 kyosho gaskets. hope this helps--good luck
adl is offline
Old 05-09-2006, 12:55 AM
  #6441
rmdhawaii's Avatar
Here are some pictures of the new PARMA/PSE 1/10 Type "M" Sedan prior to painting:
http://www.nitrokb.com/reviews/parma_type_m/
Old 05-09-2006, 01:47 AM
  #6442
ok now i have another problem but hopefully this one is easier to fix.
whenever i tighten the screw that holds the first gear spur on the mesh becomes really tight. but when i undo the screw the mesh is perfect and the gears spin freely.
has anyone else had this problem and what did you do to fix it ???
ae_ntc3 is offline
Old 05-09-2006, 02:24 AM
  #6443
carkillaii's Avatar
The 2speed clutch has to be loosend on the shaft once you do that slide the shaft to the right-->,or slide the 2speed clutch back some then tightn down the screw.
carkillaii is offline
Old 05-09-2006, 02:57 AM
  #6444
rmdhawaii's Avatar
If I understand you correctly, the spur gears are suppose to be mounted on the car (step 26) before you mount the engine and line up the pinion gears (step 44). Not the other way around. You should never loosen the spur gear screw to adjust the mesh between the pinion and the spur gear. Make sure that your piece of paper is only 1/2 inch in width and you are only measuring the gap with the outer pinon and outer spur gear.
Does this make sense? Maybe I don't fully understand what you are doing.
Old 05-09-2006, 04:43 AM
  #6445
so you mean i ahve to loosen the grub screw and move both spur gears towards the bulkhead??? now i understand
have you had this problem before aswell ??
sorry rmd, carkillaii beat you to it lol
ae_ntc3 is offline
  #6446
B4
B4's Avatar
Where did you get the body. I tried HK and JP with no luck.
B4 is offline
Old 05-09-2006, 04:52 AM
  #6447
B4
B4's Avatar
Without the clutch bell on the car.
Do the spurs spin freely in both directions.
Can you push the main shaft left to right or is it tight.
If you push the main shaft towards the spur side and have both spurs on is there a gap between the first gear spur and the retainer.
B4 is offline
Old 05-09-2006, 06:04 AM
  #6448
carkillaii's Avatar
Yes but not the spur gears , move the 2speed cluch closer to the bulkhead
but dont make it flush against the bearing you want the shaft to move just a lilbit
yes I have been through this before
Old 05-09-2006, 07:05 AM
  #6449
Trader Rating: 13 (93%+)
ive read the article aboutgetting 200mm wide rear end on the wce with zero offset wheels.
I have a heap of 0 offset wheels so i just wanted to know what you guys have found to be the best option to get the 200mm trackwidth ?
thanks
JOHN
mrgsr is offline
Old 05-09-2006, 07:32 AM
  #6450
SOLOARTIST 702's Avatar
Default hmm
whats up vaughn when you racing
SOLOARTIST 702 is offline
