Old 05-02-2006, 12:22 AM   #6271
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
How big is the bend? If it's just 1-2 mm i wouldnt bother changing the chassies, my RRR WCE chassies is slightly bent after 2 racedays without any wall-hits and the car has never handled as good as now. When you put the stiffener on it will surely make the chassies flat again..
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 05-02-2006, 03:08 AM   #6272
rmdhawaii's Avatar
I would imagine so. Once you bolt everything on - the upper plate, the stiffner and the engine mount - it should flatten itself out. If it doesn't, then I would definitely return it. Now if you had a 7075 chassis and it was bent, that would be a different story.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-02-2006, 03:16 AM   #6273
Originally Posted by rmdhawaii
Please be sure to keep track of your lap times and how you do relative to your buddies. Once you add the UE parts, it would be good to note if you see an improvement. Also, let me know what your setup is. Are any of the other guys running V1RRR WCE? That would be great if they are. Hmmm.. Maybe the preliminary shopping list will be ready earlier than expected...
i just got some parts in do you want some weight differences between the stock engine mounts and the one-piece engine mount, aluminium brake lever and the stock plastic one and the alloy hex drives versus the stock plastic ones.
ae_ntc3 is offline   Reply With Quote
Old 05-02-2006, 03:22 AM   #6274
rmdhawaii's Avatar
Originally Posted by maskedrider
so is it that the chassie should be flat straight from the head to the end ? Or is it the end should be slightly upward ?
It doesn't look like the end of a banana does it?
Just kidding! Just kidding!
Just for you bro, I pulled the car out of the box, took off the wheels and put it on the Hudy setup board - and you know what? My chassis is straight except the back end after the rear wheels where the back of the chassis is about 0.5mm off the board. Big deal. You guys should see some of the track acrobatics I've done with the car. I'm surprised it doesn't look like ... a banana!
I wouldn't worry about it. We're all going to get Shimo replacement chassis anyway. Right?
Old 05-02-2006, 03:28 AM   #6275
rmdhawaii's Avatar
Okay, if it's not too much trouble. Should be interesting to see what the differences are.
You got four scales? I would be suprised if you did. I would really like to know what the weight distribution is under each wheel, with and without the engine and pipe on. That will give me some weight distribution information for the knowledge base.
Thanks!
Old 05-02-2006, 03:42 AM   #6276
rmdhawaii's Avatar
I really hope that Team Kyosho can maintain it's title at this year's ROAR Nationals. Team Mugen is awfully dangerous with those MTX-4 - and they've got another year of racing under their belt - and Mike's got all of those championship titles. Yikes!
Josh's Race Report: http://www.kyosho.co.jp/web/race/rac.../result-e.html
Old 05-02-2006, 05:31 AM   #6277
actually i dont but i know someone that does have 4 scales all hooked up together. They cost about $3000 aud !!!!!there made by longacre.
i wont be able to measure for a few weeks cause the person who owns them are going on holidays.
Old 05-02-2006, 05:58 AM   #6278
rmdhawaii's Avatar
Okay.
Old 05-02-2006, 07:32 AM   #6279
B4
B4's Avatar
Does anyone know of another gear diff I can use in the front of the RRR. The standard gear diff does not let you use number 11 ackerman as the diameter of the diff is to great.
B4 is offline   Reply With Quote
Old 05-02-2006, 07:52 AM   #6280
performula's Avatar
Shock Questions
Rebound -
So far I have all the air out and no leaks, but one is a tad faster than the other. Still air in the shock?
Removal-
How is everyone popping their shocks off towers and arms?
performula is offline   Reply With Quote
Old 05-02-2006, 07:55 AM   #6281
performula's Avatar
How big is the bend? If it's just 1-2 mm i wouldnt bother changing the chassies.
.1-.2 of a millimeter.
Old 05-02-2006, 09:18 AM   #6282
jag
jag's Avatar
Originally Posted by performula
Shock Questions
Rebound -
Removal-
If one shock is faster, then that one probably has more oil in it.
I don't pop the shocks off the tower, I just unscrew the ball. I pop them off the bottom with my 1.5mm hex driver. It's long and thin and fits right between the arm and the cap. Just slide it in there and pry it off... carefully. Make sure you pry against the plastic cap and not the shock spring, cup or shaft. Just my method.
jag is offline   Reply With Quote
Old 05-02-2006, 09:24 AM   #6283
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default race
I really hope that Team Kyosho can maintain it's title at this year's ROAR Nationals. Team Mugen is awfully dangerous with those MTX-4 - and they've got another year of racing under their belt - and Mike's got all of those championship titles. Yikes! we just got to keep testing because the mugen guys dont take breaks they practice day in & day out i know believe me thats why we in LV have started traveling to CALI. to practice if you want to keep it close just keep working it wont be easy some other drivers are just on a different level im behind by about 20 years but im trying good luck to all a Race Report: http://www.kyosho.co.jp/web/race/rac.../result-e.html
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 05-02-2006, 09:27 AM   #6284
Default race
practice track time is key lets do IT 3R
WILLIAM PENDERGRASS
Old 05-02-2006, 01:20 PM   #6285
rmdhawaii's Avatar
Are you trying to avoid using the #10? Worried about too much steering? Using the #10 might be unavoidable.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
