Kyosho v-one rrr
Old 05-01-2006, 07:50 AM
  #6256
performula's Avatar
My question is that has anyone had a chassis 'tweaked' from the factory? My chassis is bowed very very very slightly.
performula is offline
Old 05-01-2006, 08:56 AM
  #6257
SOLOARTIST 702's Avatar
Default pract.
had a good practice at REV. yestarday A few of us LV guys went down for test & tune great day all the way around track was great look foward to doing it again in 2 weeks keep your eyes open we are hitting a track near you.
SOLOARTIST 702 is offline
Old 05-01-2006, 09:18 AM
  #6258
rmdhawaii's Avatar
Originally Posted by Kyosho3PKRacer
With the K-Factory chassis, so far it's working really well, just been in a big event here and checked for any tweaks in it after and it is still dead straight.
From a driving/handling perspective, what would you say is the primary difference between this chassis and the stock one? Have you tried the Kyosho Shimo chassis? What do you think of that one?
Thanks!
rmdhawaii is offline
Old 05-01-2006, 09:24 AM
  #6259
rmdhawaii's Avatar
Please be sure to keep track of your lap times and how you do relative to your buddies. Once you add the UE parts, it would be good to note if you see an improvement. Also, let me know what your setup is. Are any of the other guys running V1RRR WCE? That would be great if they are. Hmmm.. Maybe the preliminary shopping list will be ready earlier than expected...
Old 05-01-2006, 09:47 AM
  #6260
dougday's Avatar
i have been through 3 kits and built 2 others for friends and have never seen a bent chassis.
check the chassis on both sides
dougday is offline
Old 05-01-2006, 10:09 AM
  #6261
Default v1 wce
2 of us are running it & two are running tx4 so we got a little comp. to deal with along with pro series & sedan nats comming up i will keep you informed
Old 05-01-2006, 10:10 AM
  #6262
Default chassis
may be in the market to get a chassis wich one shimo or K- factory oh yeah price also
Old 05-01-2006, 10:15 AM
  #6263
jag
jag's Avatar
Is it bowed after you built it or is the chassis itself tweaked?
jag is offline
Old 05-01-2006, 10:57 AM
  #6264
rmdhawaii's Avatar
Shimo is ~ $80, K Factory ~ $109. Can't say which one is the better chassis from a driving/handling perspective. Anyone else?
Old 05-01-2006, 11:43 AM
  #6265
kidDynomite's Avatar
Shimo chassis is the way to go. Never tweaked it. 3-racing chassis, it'll bow on you. Trust me. Went back to the Shimo twice after testing 2 other chassis. Same thing with my FWs, always went back to the Shimos. Kyosho duraluminum is top notch. Don't bother with the others. I take that back. I do like the quality of an old V-one Kawahara chassis. They didn't have Shimo racing back then.
kidDynomite is offline
Old 05-01-2006, 12:30 PM
  #6266
rmdhawaii's Avatar
Thanks! Appreciate the feedback.
Old 05-01-2006, 01:45 PM
  #6267
performula's Avatar
I must be lucky. I checked both sides. When I set the chassis the way it will be, built, the chassis has a bow up.
The first thing I did was open the kit and throw the chassis on the Hudy board. Usually the first thing I check.
A Rep at Kyosho said that it would straighten out once the kit was put together. As much as I don't believe this statement, he said that I could send it in. My only issue is that I would like to race this weekend.
Will the chassis straighten out? I guess I could build it, try to adjust the bow from the upper deck mounts (loosen screws, push down evenly through the front and rear bulkheads, have another person tighten the screws), and put it on a flat surface again or use the tweak station. What a bummer.
Old 05-01-2006, 04:14 PM
  #6268
Default chassis
thanks team its settled ill get the shimo chassis LOOK OUT SEDAN NATS here i come
Old 05-01-2006, 05:27 PM
  #6269
Team Kamikaze's Avatar
I have the option SP chassis VZW214 Genuine Kyosho Parts 7075 Gunmettallic color
it's much stiffer, the window for the battery becomes enclosed,
Team Kamikaze is offline
Old 05-01-2006, 10:25 PM
  #6270
performula's Avatar
I'm so upset about the chassis I quit building. No one seems to have the stock chassis. The least I could do is get a chassis to hold me off until the defective part is replaced.
