Old 04-24-2006, 01:16 PM   #6151
Originally Posted by kewdawg
I'm not certain, but it seems to be just a difference in color. The names for them are the same with color as the only noticeable change. Maybe, someone here knows for sure?
I tried both. They are the same. The difference is just color
silverM3 is offline   Reply With Quote
Old 04-24-2006, 02:03 PM   #6152
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Originally Posted by rmdhawaii
I used Permatex RTV Silicone Gasket Maker to seal my rear diff and it hasn't leaked since. The only thing is, you have to be neat about it.
Where can I purchase it from? Or, maybe I can just go to a hardware store to look for it!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 04-24-2006, 02:25 PM   #6153
rmdhawaii's Avatar
Auto parts, K-Mart, Wall-Mart, etc.. I can't remember if I'm using the "Blue RTV" (older formula) or the "Ultra Blue" (newer formula). Either one should be fine, but if you can wait another 8 hours, I can tell you exactly which one.
rmdhawaii is offline   Reply With Quote
Old 04-24-2006, 04:50 PM   #6154
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by psbarger
Hey guys,
I just ran my WCE car for the first time at Cinci yesterday and had a blast except for the fact that I stripped 2 second gear spur gears. Both of them lasted approximately 20-30 minutes run time before shaving themselves smooth. The gear mesh was set correctly as far as I can tell, and I didn't have a problem at all with 1st gear. Any ideas on what could have caused this?
Make sure there is not to much play on the shaft if so it may be binding up near the fly wheel & causing it to hit the gears as it is shifting & wears down the spurs faster
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-24-2006, 05:11 PM   #6155
performula's Avatar
Are you talking about the crankshaft or the layshaft?
performula is offline   Reply With Quote
Old 04-24-2006, 06:49 PM   #6156
GMartinez's Avatar
Layshaft if the spacing on the crankshaft has 2 much kiss the conrod goodbye
Old 04-24-2006, 06:59 PM   #6157
My advise is to get the o'ring. I tried that stuff. I guess I wasn't very neat.
Old 04-24-2006, 08:17 PM   #6158
performula's Avatar
I'm still lost. Oh well.
Old 04-24-2006, 08:51 PM   #6159
Osiris 75's Avatar
Aight...
Chris Kemper
Old 04-24-2006, 09:17 PM   #6160
performula's Avatar
Forgot to mention I picked one up - WCE (Friday or Monday). Also got a few spares, minus the rear shock tower and 1st gear aluminum pinion. Hopefully, the stock gearing will be OK on my track. Are there any tips or is any fabrication needed for the building process? I hope I made the right choice...if not I'll take that percentage hit off eBay.
Old 04-24-2006, 09:44 PM   #6161
rmdhawaii's Avatar
Aight...
It's the Blue RTV
Old 04-24-2006, 10:09 PM   #6162
rmdhawaii's Avatar
Letís seeÖ
1. The biggest pain in the butt is modifying the servo horn. Maybe someone can give you some advice here. You don't want to do it the way I did it.
2. When you spin the clutch bell facing up or facing down, it should spin for at least 5 seconds (per 710 FAQ ) BTW Ė The instructions say nothing about end play. Glenn Cauley recommends, ď. You want to have only a very small amount of endplay; just a barely noticeable hint of movement (0.10mm) is good, but don't remove ALL endplay or the clutch will drag.Ē
3. The fuel hose used for the brake is too short in step 38, in my opinion. Try 20mm.
4. Watch which ends you put which ball caps on in steps 8
5. Watch which end you mount the camber link in step 18. (i.e. the adjustment rod needs to face a certain way).
6. The slop in the top suspension arms can be adjusted by using a 3mm washer. You donít have to remove all of it, 1-2mm is okay, but itís debatable.
7. Donít over tighten the shock caps (i.e. steps 11, 27 part #129).
8. Belt tension should be loose for front and rear.
9. You have to bend the muffler stay in step 46 yourself.
Help me out guys. What have I missed?
Old 04-25-2006, 12:35 AM   #6163
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Some more things to remember while building the car!
1. File out the lower chassis a bit so you can slide off the clutch bell without having to remove the engine.
2. File the hole in the radio plate above the steering servo horn so you can more easily remove the servo horn with a flat tool ie. a screw driver.
3. Filing once more! Make the hole where you pass the cables for the receiver through longer, this makes it a lot easier installing the radio gear.
Besides that RMD said everything else.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - SavŲx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 04-25-2006, 01:15 AM   #6164
esham's Avatar
Thank you guys... finishing idea.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 04-25-2006, 06:26 AM   #6165
jag
jag's Avatar
Letís seeÖ
1. I used an aluminum servo horn (Futaba) and I didn't have to do anything to it except to drill the hole out a little. It works very well. If you use a long horn (20mm) you may have to rotate it 1 tooth forward so it does not hit the gas tank at full throw and you may need to trim the top deck opening in the front and back of the opening. I also added a small washer inside the horn to shim it out a little further to provide more clearance between the horn and top deck.
3. I also use a return spring on the back side of the mixing arm to eliminate any brake drag.
6. I used a 2mm caster clip from my old Serpent and sanded it down until it fit perfectly and now I have no slop at all.
The thing I found most difficult is the wiring. I trimmed the steering servo mount to allow the wires for the steering servo and transponder (I don't use a switch) to run behind the receiver. If you use a very small receiver, things will fit easier.
Don't tighten the gas tank down too tight. It should move.
jag is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
