Old 04-23-2006, 06:35 PM   #6136
teammpp's Avatar
Originally Posted by OldNSlow2
What? That makes it longer!
Ok, just so you all know I am not looking for a fight here, it's Friday night, I'm home watching hockey and reading the "net". Plus I am Old and Slow so I tend to study these things, plus it is what I do for a living.
I will say this one last time. If you lower the upper arm on the inside you will raise the roll center, and increase camber gain. A shorter upper link will cause a more rapid change in camber gain. Please go back and look at the Cauley picture and imagine the upper link on a steep angle down then connect all the lines to this new instant center. The roll center will be higher. I just did it again myself to make sure.
Ain't this fun?
I have to apologise and admit I was wrong. I dont have any excuses other than the few I had to drink. Just moving to the inside hole does raise the roll center but moving to the inside and increasing the length of the arm to keep the same camber lowers it.
teammpp is offline   Reply With Quote
Old 04-23-2006, 08:43 PM   #6137
performula's Avatar
Wow, everyone has their own opinions. I wish I had the knowledge to know myself. Honestly, I have never raced on the track, but I visited their races today. Similar to the gearing opinions, the people there have mixed opinions on traction. A main guy says kind of low/medium two others say "such a high bite".
Anyway, RDHawaii, I couldn't tell you. They DO have two nitro classes. Tomorrow I will be ordering the WCE and was hoping box stock would work on this track. (slightly bumpy - just a tad, medium traction, small track) Some guys run 40/37 and 37/35 to me that sounds like a medium traction track to me if this can be judged by tires and current temp. I have about 40 hours track time, 15 hours with an R40, and 25 hours with an MTX3. Still learning.
performula is offline   Reply With Quote
Old 04-23-2006, 09:56 PM   #6138
Trader Rating: 13 (93%+)
if the traction is low ... swap the springs around back to fornt togive you more steering on that track
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 04-24-2006, 12:55 AM   #6139
esham's Avatar
Changing the rear diff oil - WIP.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 04-24-2006, 06:35 AM   #6140
kewdawg's Avatar
Originally Posted by jag
How does this work with the new alum rear mount? You can mount the link in the 3 different positions as well as using the 2mm washer. The instructions say to mount it in the hole closest to the wheel with the spacer.
Sounds to me, like this will mimick the stock set-up with the original parts.
This makes the link short and the angle steep. What condition is this setup best for?
Basically, a high bite set-up.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-24-2006, 06:46 AM   #6141
WildChild's Avatar
Send a message via Yahoo to WildChild
what about spring length? on nitro cars the fronts are shorter
WildChild is offline   Reply With Quote
Old 04-24-2006, 07:49 AM   #6142
kewdawg's Avatar
V one RRR Rear Spring(4-1.6mm) - Black #VZ073-4016.
Quinn Moon
Old 04-24-2006, 07:53 AM   #6143
Osiris 75's Avatar
Trader Rating: 17 (100%+)
I lost the thin black O-ring that goes on the rear differential to make sure it doesn't leak. Do I have to purchase another one, or does anyone have a remedy to prevent the Diff. oil from leaking out, without an O-ring???
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 04-24-2006, 07:55 AM   #6144
jag
jag's Avatar
Thanks.
That's what I thought.
jag is offline   Reply With Quote
Old 04-24-2006, 08:00 AM   #6145
kewdawg's Avatar
Thanks.
Glad I could help.
Quinn Moon
Old 04-24-2006, 08:01 AM   #6146
i dont know if this question has been asked before but whats the difference between the black shock diaphragm(w6006) and the whit diaphragm(w6007)
thanks in advance
ae_ntc3 is offline   Reply With Quote
Old 04-24-2006, 08:09 AM   #6147
kewdawg's Avatar
thanks in advance
I'm not certain, but it seems to be just a difference in color. The names for them are the same with color as the only noticeable change. Maybe, someone here knows for sure?
Quinn Moon
Old 04-24-2006, 12:23 PM   #6148
kidDynomite's Avatar
Default Spring Rate Chart
Here's what I have laminated in my tackle box and set-up binder. It's a spring rate chart that I believe is still current. I highlight the springs I have (yellow for fronts and green for rears) for quick referencing. If you can't dial it in on race day, this will also help you figure out what your competition is using... minus the piston and oil wt they are using.
Hope this helps.
kidDynomite is offline   Reply With Quote
Old 04-24-2006, 12:59 PM   #6149
Default 2nd gear problems
Hey guys,
I just ran my WCE car for the first time at Cinci yesterday and had a blast except for the fact that I stripped 2 second gear spur gears. Both of them lasted approximately 20-30 minutes run time before shaving themselves smooth. The gear mesh was set correctly as far as I can tell, and I didn't have a problem at all with 1st gear. Any ideas on what could have caused this?
psbarger is offline   Reply With Quote
Old 04-24-2006, 01:07 PM   #6150
rmdhawaii's Avatar
I used Permatex RTV Silicone Gasket Maker to seal my rear diff and it hasn't leaked since. The only thing is, you have to be neat about it.
rmdhawaii is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
