Old 04-20-2006, 11:47 AM   #6061
dougday's Avatar
V1RRR Ultimate Edition
That should be good
dougday is offline   Reply With Quote
Old 04-20-2006, 11:49 AM   #6062
deviltires's Avatar
what does that give you if you move your camber links to the inside hole in the rear
DARNELL WASHINGTON-- TEAM MUGEN----FUTABA 4PK--HOT RACE TIRES
deviltires is offline   Reply With Quote
Old 04-20-2006, 12:22 PM   #6063
jag
jag's Avatar
Originally Posted by tommi
Hey dood, try this? The last I read from someone's post in the MTX-4 thread, Mugen USA no longer handles Kawahara...
Well, the link did work and I ordered the part. It didn't say the part was on back order so we will see. I was told by RC Champ that it was out of stock from Kawahara. I hope they have one in stock.
jag is offline   Reply With Quote
Old 04-20-2006, 01:36 PM   #6064
rmdhawaii's Avatar
The Kyosho V-ONE RRR Ultimate Edition thread is up! Thanks for the support!
rmdhawaii is offline   Reply With Quote
Old 04-20-2006, 04:19 PM   #6065
etgdpu's Avatar
Default battery installation on the upgraded chassis
Hello all,
I am waiting the upgraded chassis for the RRR and I wonder what is the optimal way to install the battery. Since this chassis does not have the "hole" for the battery plate, I suppose I have to install the battery directly onto the chassis. I thought the "glass" tape, which is used in the electric cars to hold the batteries but I am afraid of the fuel and the battery is under the tank. I am also thinking silicon. What do you recommend? Thanks
etgdpu is offline   Reply With Quote
Old 04-20-2006, 04:29 PM   #6066
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by etgdpu
Hello all,
The glass tape for electric cars works fine. Just make sure you tape it tight and go around it 10 times or so. The fuel will wear out the adhesive slowly over time but by then it should be time for you to take the car apart and clean anyway.
jeffreylin is offline   Reply With Quote
Old 04-20-2006, 04:34 PM   #6067
jag
jag's Avatar
I was wondering the same thing. It looks like it would be quite difficult to wrap strapping tape around the battery 10 times as you cannot feed the roll thru the slot. When taping batteries into my 1/12 I only wrap the tape once. Do you think a combination of tape (2 or 3 wraps) along with some shoe goo would hold it?
Old 04-20-2006, 04:48 PM   #6068
jag
jag's Avatar
I think it changes the roll center but I don't know if it raises it or lowers it.
Old 04-20-2006, 05:17 PM   #6069
jeffreylin's Avatar
The holes are big enough for it. Just keep going until it's even with the chassis. I also use double sided tape as it comes with the chassis.
Old 04-20-2006, 05:45 PM   #6070
it will allow the rear to roll more therefore giving you more traction at the rear
bosfan is offline   Reply With Quote
Old 04-20-2006, 11:56 PM   #6071
maskedrider's Avatar
hey Jag, will the steel pinion would wear out the spur faster then the stock alum one ?
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 04-21-2006, 03:43 AM   #6072
B4
B4's Avatar
You would think so but in fact I have experienced the opposite. The steel pinions do not get sharp edges so they do not wear the spurs.
B4 is offline   Reply With Quote
Old 04-21-2006, 05:31 AM   #6073
teammpp's Avatar
It does lower the roll center but on a track producing no grip it wont add any traction. Total opposite.
With tracks that arent producing grip you need to go back to rubber touring basics and raise the roll center and stand the shocks up to get grip.
teammpp is offline   Reply With Quote
Old 04-21-2006, 05:47 AM   #6074
mcsquish's Avatar
Instead of the double sidded tape, I am going to use shoe-goo. I don't think the fuel will attack it.? That is if it ever showes up.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 04-21-2006, 05:48 AM   #6075
kewdawg's Avatar
A longer link will always give more traction. As long as you don't reduce the camber angle, there will be an increase in grip. A matter of leverage.
Standing the shocks up by moving the lower mount to an inner hole on the arm, not on the shock tower. Again, a matter of leverage.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
