Old 04-10-2006, 10:14 PM   #5821
robert maestrey's Avatar
Originally Posted by Osiris 75
I'm trying to adjust my 2 speed to shift sooner, so I'm going to take it apart and put it together again. Any idea on how many turns I should go when putting in the screws??
tighten them all the way down...then back off 3 turns on both screws try that as a starting point.......then go 1/4 turn on each clockwise to shift later or counter for earlier ...keep going in 1/4 increments until you get your correct shift point....This shift point should work on most tracks....depending on size of track you might have to gear the car differnetly that is the key.....
robert maestrey is offline   Reply With Quote
Old 04-10-2006, 10:16 PM   #5822
kewdawg's Avatar
Originally Posted by robert maestrey
For one thing it lightens your weights......I was told to do this at W-nats by Bertin....And my clutch feels very nice since i have been doing it.....
What tools did you use?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-10-2006, 10:25 PM   #5823
To make the holes bigger in the weights.....u can use a dremel, reamer, step bit.. several ways to do it.....need to be very carful not to deform the weight when doing it...
Old 04-10-2006, 10:28 PM   #5824
kewdawg's Avatar
Which do you think is the safest?
Quinn Moon
Old 04-10-2006, 10:33 PM   #5825
I used step bit worked very well....dont kill yourself to get exactly 3.8 if you know what I mean.
Old 04-10-2006, 10:42 PM   #5826
kewdawg's Avatar
Yeah.. I know exactly what you mean. Thanks!
Quinn Moon
Old 04-11-2006, 04:57 AM   #5827
geeunit1014's Avatar
what exactly does lowering the weight of the rear diff oil do? say from the stock 30k weight to a 10k weight?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 04-11-2006, 05:05 AM   #5828
B4
B4's Avatar
Originally Posted by drfritz
well these guys used to have it. heres the link that I saved as a favorite.
http://www.precisionrc.com/nv/car/pr...oduct_id=11861
when you do a normal search it comes up a goose eggs.
hey what are you all using to remove the pinions ?
I have the VZW040 wrench, works great for the second gear, but for the 1st gear does'nt for a flying #####
I have set of plyers that I have put shrink tube around the jaws, but looks a little cheesie.
The Kawahara sway bar looks like it would be a good option although you need to consider.
1) It is heavier than the standard components.
2) The softest setting is usually harder than the lightest Kyosho bar.
3) How often do you need to change the tension, if it's during a pit stop OK. But between races there is more than enough time.
To change the pinions get yourself this Serpent part. It's only USD$13 and you get two tools in the kit one for first gear and another for second. Kyosho make a tool to hold the clutch bell that I have but I can't remember the part number, you can also easily mod the Serpent one to do the same thing.
B4 is offline   Reply With Quote
Old 04-11-2006, 05:07 AM   #5829
kidDynomite's Avatar
It allows for more diff action in the rear. If you're on a low bite track like a parking lot. 10K works pretty good. In extreme conditions, I've used 5-7K. It really helps keep the car from oversteering or breaking loose. But I've seen some really high-bite where you may want to go 50K. Diff oil is a great tuning aid. Experiment or better yet, make some spare diffs for quick changes at the track.
kidDynomite is offline   Reply With Quote
Old 04-11-2006, 05:14 AM   #5830
B4
B4's Avatar
As you go lighter in the diff oil you are allowing the diff action to occur. That is each side can rotate at different speeds.
Old 04-11-2006, 05:54 AM   #5831
kewdawg's Avatar
Not really an issue with this car. The car is already underweight. It will have an affect on the CG of the car's rear.
REALLY not a problem with this car! I found the softest rear sway bar to be much too soft.
If, ever needed, I'd say it would be a lot easier / quicker to change.
Quinn Moon
Old 04-11-2006, 06:22 AM   #5832
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default the car
hope to see all the 3R s at the race next week vegas is the way
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 04-11-2006, 06:26 AM   #5833
jag
jag's Avatar
1) I don't think the weight is a big issue but it's worth considering.
2) Unless you race on a track with no traction I don't think this is a problem.
3) I think the Kawahara piece allows for "fine" tuning.
I don't know about you guys but I don't care for the way the stock sway bar is mounted. I'm not a fan of the friction fit.
Is anybody using the Kawahara sway bar now? I think I saw one on Tosolini's car at the WinterNats.
BTW, the Serpent tool will not work. They use a different pitch on their gears.
jag is offline   Reply With Quote
Old 04-11-2006, 06:47 AM   #5834
Hey joe that great to hear you coming back.....to be hones with you the stock setup works pretty well....if you want to see the setup I used at this years W-Nats just look back a few pages its on the rrr thread......see ya soon bud....
cool, thats what i was thinking--- the stock setup works good. by the way, what gearing are you running at go racing?
Joe Chaplow is offline   Reply With Quote
Old 04-11-2006, 07:30 AM   #5835
jag
jag's Avatar
Default Wheel Hexes
Is anybody using aftermarket alum. wheel hexes? I don't like the stock ones. The pins are very difficult to remove. What are you guys using? Are there any that have 2mm offset?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
