Old 04-03-2006, 09:36 AM   #5626
Team Kamikaze's Avatar
change the rear sway bar to the softest VZ217-1.8 , remove the sway bar only if the traction is very high
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-03-2006, 09:38 AM   #5627
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Talking hmmm
are these setups for multiple tracks or just the track you guys run at i run at rev,cp,& vegas i understand some people only run one track down there
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 04-03-2006, 09:39 AM   #5628
you might want to switch the front caster clips all to the rear of the arm if using softer rear tires
Old 04-03-2006, 09:46 AM   #5629
Default what
Originally Posted by Team Kamikaze
Front 1/2 degree Toe out each side
Front 1 degree Negative camber
Rear 2 degees toe in
Rear 2 to 3 degrees Negative camber
Front caster clips all in front of the upper suspension arm
Front shock position all the way up to the last hole
Front sway bar standing up this should prevent the car from spinning out when turning and use 38 or 40 shore foam tire front ,38 shore foam rear
rear shock position on the middle TRY THIS SET UP IT SHOULD WORK JUST FINE
WILLIAM PENDERGRASS
Old 04-03-2006, 12:32 PM   #5630
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Now I'm having problems fish-tailing out of turns. I've tried different shores of tires, but it still does the same thing. My ride height is 4mm. What else can I do to prevent this??
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 04-03-2006, 12:34 PM   #5631
jag
jag's Avatar
What size tires are you using front and rear? Are you using the same shore front and rear?
jag is offline   Reply With Quote
Old 04-03-2006, 12:45 PM   #5632
Osiris 75's Avatar
42 fronts and 37 rear.. I also tried 40's all the way around. 42,37 was recommended by my LHS!!
Chris Kemper
Old 04-03-2006, 12:51 PM   #5633
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by SOLOARTIST 702
So Am I
looking at your comments that there are some rough areas & the track is pretty technical
here are some of my recommendations if you don't like his set up
Front toe 0 tire shore 35 or 37 true down 61.5 spring black
rear toe 2.5 tire shore 37 true down 63.5spring gold
front camber 2mm/ droop 3mm to reduce onpower push
rear camber 4mm/droop 1mm
front shock position stock
rear shock last hole outward
ride height front 5.5
rear ride height 6
caster settings 2mm front & back nuetral position
going with all your caster settings front will create to much of an aggressive entry & real sluggish exit out of turns since the car comes with 0 degree spindles if it came with 2 degree then the caster settings up forward would be ok. with a higher traction wear from the track you should get at least 2 qualifiers with your tires if you don't chunk. I tried this setup @ a track in Ny similiar to what your running with the same conditions. LMK the outcome
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-03-2006, 01:00 PM   #5634
jag
jag's Avatar
What diameter?
I find that a 2mm split is too much for me. It makes the rear end loose coming out of a turn if I get on the gas to quick. I tried going to a softer tire in the rear, which helped a little, but going to a 1mm split with the same shore tire worked better. The car is much easier to drive.
Old 04-03-2006, 02:00 PM   #5635
Osiris 75's Avatar
26MM Front, 30MM Rear.
Chris Kemper
Old 04-03-2006, 02:11 PM   #5636
jag
jag's Avatar
Height, not width.
Old 04-03-2006, 02:15 PM   #5637
Thumbs up Fish Tailing
Try the rear diff (cant see if anyone has mentioned this above - so apologies if I am repeating what has aleady been said). The RRR come with 30K as std but on low traction surfaces especially trying to get out of turns with the power on the rear will slide. Try 10K and then go up to 20K - find which works best for you. Also, you can try running with less oil in the diff and a heavier oil - this can prevent less initial resisiance to differential action.
Also, running too light a front diff can cause this same problem. I have been running 100K (Associated brand) in the front of mine and the car is feeling really good!
Hope this helps
Tricknut is offline   Reply With Quote
Old 04-03-2006, 02:20 PM   #5638
Osiris 75's Avatar
Height, not width.
199 front, 200 rear..
Chris Kemper
Old 04-03-2006, 02:21 PM   #5639
Data's Avatar
you are good.........
Data is offline   Reply With Quote
Old 04-03-2006, 02:59 PM   #5640
V1-RRR-WC's Avatar
37 shore should be fine for the rears , go harder on the fronts like 40 shore, also true the tires to 60mm fronts and 62 mm rears with front ride height at 4.5mm and rear ride height at 5.5mm and go smoke the competition
Hey Team Kamikaze,
Again, thanks so much for all the info.
As for the 40 shore tires, I will not have these till next weekend, so what specs should I run this weekend with the 37 shore till I get the 40?
I have also ordered the rear sway bar as suggested (1.8) which will come in the same time with the 40 shore tires. So, can I use the (2.0) for now?
What adjustments should I make in the meanwhile for this?
Since I will have 37 all around for this weekend, should I just remove the rear sway bar?
Also, when you say "you might want to switch the front caster clips all to the rear of the arm if using softer rear tires" do you mean softer than 37?
What about the rear upper arms? Should these remain stock at 2mm and in the OUT position?
I also noticed you did not mention anything about the rear down stop or spring colours (front & back).
Let me know.
Thanks!
V1-RRR-WC is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
