Old 04-01-2006, 11:59 PM   #5611
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Alright,
I am looking for a front one way / front spool for my RRR WCE. I hear K factory has one but who can I get it from? Is there anyone else who makes one other than K factory. Any advice would be appreciated.
EA Motorsports
picco007 is offline   Reply With Quote
Old 04-02-2006, 12:28 AM   #5612
Motorman's Avatar
See the signature in my line. click the Phenix Dist link and you will find a dealer who can help you with anything K factory for your car you need. We stock everything for the RRR and other cars here in the USA.
No one makes one but K Factory. It has been a very popular part, actually the entire line has been quit popular. One thing about K factory you will find it a little higher in price than some of the other performance parts lines but no one builds the level of quality option parts these guys do except maybe Kawahara and K Factory made some of Kawaharas parts at one time. You just have to ask yourself do you want a low grade alumunium part of 6061 or worse, or do you want hard annodized 7075.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 04-02-2006, 01:59 AM   #5613
B4
B4's Avatar
Originally Posted by picco007
Alright,
Atomic also make a spool available from RC Union this multi diff is probably cheaper than the KFactory because you use the original pulley. I haven't used the KFactory one so i can not confirm the longevity.
B4 is offline   Reply With Quote
Old 04-02-2006, 08:49 AM   #5614
maskedrider's Avatar
Anyone here have the IFMAR 2004 200mm brazil world race video ?
alrite to PM me ?
thanks in advance
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 04-02-2006, 11:03 AM   #5615
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Talking hmmm
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 04-02-2006, 04:52 PM   #5616
V1-RRR-WC's Avatar
Default Should I increase camber???
Hey Guys,
I finally got around to breaking in my new RRR these past two weekends and noticed a few things.
Last weekend, I had the camber set as I do on the 4-Tec that I race on the same track, which performs exceptionally well.
(1deg front R & L)
(1.5 R/R - 2.1 L/R)
This resulted in a slight conning on the RRR's Left Rear tire, but turned corners ok. (Can't push it hard just yet because of the new engine)
In looking over the factory specs and speaking to the hobby shop I purchased the car from, they said not to cross 0.5 degs of rear camber.
So I made the change back and found that the car spins out easily on every corner.
It's not the brakes, which is set to just drag lightly.
So, should I increase the camber?
Should I look at the droop adjustment? (I know this caused spin outs on my 4-Tec)
What about the rear stay bar? (I know some persons who remove this)
Any help on which direction to go would be greatly appreciated.
V1-RRR-WC is offline   Reply With Quote
Old 04-02-2006, 06:07 PM   #5617
carkillaii's Avatar
First you cant compare the 3RWC to a 4tech 2nd your setup should be the box stock setup its a verry good starting point see how the car runs on ur track in the stock set up first then make your addjustments according to your track , never use .5 camber never ur front camber should be -2.0&rear should be -3.0 just to start & try -3 toe in too try that
Originally Posted by V1-RRR-WC
Hey Guys,
(1deg front R & L)
(1.5 R/R - 2.1 L/R)
carkillaii is offline   Reply With Quote
Old 04-02-2006, 06:18 PM   #5618
V1-RRR-WC's Avatar
Hi carkillaii,
Yes I know, in NO WAY can I compare these two cars. I was just giving a reason why I used the specs I did.
You mentioned never to use .5 deg camber, but correct if I am wrong, is this not what the factory specs are?
I would like to try what you suggest, so let me make sure I understand you clearly.
Front / -2 Deg
Read / -3 Deg
Rear Toe / -Deg
The track I am on is short, do you think this should be fine?
Please let me know.
Thanks!
Old 04-02-2006, 06:44 PM   #5619
carkillaii's Avatar
I dont thik it is V1 well it shouldnt be .5 but even on a short track the set up i gave u is a good starting point but if anyone knows ant good short track setups help the man out
Old 04-02-2006, 06:55 PM   #5620
GMartinez's Avatar
Trader Rating: 85 (100%+)
first what type of condition is the asphalt grade
smooth permanent track
rough parking lot condition
then you might get the help you need since we already know it is a short track.
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-02-2006, 07:04 PM   #5621
V1-RRR-WC's Avatar
Hey 710baby,
Great to hear from you. Long time no speak!
The track is a parking lot. Some parts smooth but generally rough throughout.
Please find attached the track layout.
Looking forward to your setup layout.
Front Camber:
Rear Camber:
Rear Toe:
Rear Sway Bar:
Rear Droop:
Thanks!
Old 04-02-2006, 10:24 PM   #5622
picco007's Avatar
Thanks, I will look into it.
EA Motorsports
Old 04-03-2006, 01:26 AM   #5623
Team Kamikaze's Avatar
Hi carkillaii,
Front / -2 Deg
Read / -3 Deg
Rear Toe / -Deg
Please let me know.
Thanks!
Front 1/2 degree Toe out each side
Front 1 degree Negative camber
Rear 2 degees toe in
Rear 2 to 3 degrees Negative camber
Front caster clips all in front of the upper suspension arm
Front shock position all the way up to the last hole
Front sway bar standing up this should prevent the car from spinning out when turning and use 38 or 40 shore foam tire front ,38 shore foam rear
rear shock position on the middle TRY THIS SET UP IT SHOULD WORK JUST FINE
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-03-2006, 06:16 AM   #5624
V1-RRR-WC's Avatar
Hey Team Kamikaze,
Thanks so much!
I will try this setup and let you know.
The only thing is that I have about (5) sets of Arrows that I ordered which are coming in tomorrow. I think these are 37 Shore.
Is this ok for now? Or should I try to sell them off?
Also, what ride height should I look for? And the rear sway bar, should this be removed?
Please let me know.
Thanks!
Old 04-03-2006, 09:33 AM   #5625
Default set up
37 shore should be fine for the rears , go harder on the fronts like 40 shore, also true the tires to 60mm fronts and 62 mm rears with front ride height at 4.5mm and rear ride height at 5.5mm and go smoke the competition
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
