Old 03-21-2006, 11:47 AM   #5491
markp27's Avatar
Send a message via ICQ to markp27
Originally Posted by jag
Let's just say that he finished one place behind Robert in the "A".
markp27 is offline   Reply With Quote
Old 03-21-2006, 11:51 AM   #5492
markp27's Avatar
OR I would be happy to test a set of ceramics (for free) to see just how long they last.
I await your report
Old 03-21-2006, 12:01 PM   #5493
rmdhawaii's Avatar
Default V-ONE RRR WC Edition Bearing Reference
For what it's worth, attached is a bearing refererence for the V-ONE RRR WC Edition. For readability, change the font to Courier New.
On thing to note about the Boca Bearing Kit #25-420C-YU for the V-ONE RRR, is that it only includes one 5x8x2.5 bearing for the clutch (none for the throttle arm) and one extra 5x10x4 bearing for the Clutch Bell, Rear.
rmdhawaii is offline   Reply With Quote
Old 03-21-2006, 01:37 PM   #5494
robert maestrey's Avatar
Originally Posted by maskedrider
ok....let's get this rite... different shores of tires are design on different tracks..Anyone can get it rite on this for our babes??
35 shore are for what kind of track?
37 shore are for?
40 and 42...
any advised??
..Nope....it all depends how good the bite is.......thats what determines the compound of tire to use...low traction softer....high traction harder.....bottom line is if you can get your car to rotate with a harder tire the faster you will be..setup, tires, body all help...
robert maestrey is offline   Reply With Quote
Old 03-21-2006, 02:01 PM   #5495
Originally Posted by Gearhead3
Im sure Mike or Jim would be happy to let you sweep/blow off the track anytime..
Mike or Jim........
Old 03-21-2006, 02:20 PM   #5496
Default rrr chassis
hey rob got your chassis will have it @ the kyosho cup
PNP HOBBIES is offline   Reply With Quote
Old 03-21-2006, 03:20 PM   #5497
Trader Rating: 13 (93%+)
Default weight reduction part 2
after reading a lot of info about bearings ...
i dont wanna start playing with cutting bits away from the chassis
i only wanna lose about 20 more grams so im hoping i can change the pillow balls to titanium but i heard they arent too tiough ??
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 03-21-2006, 03:47 PM   #5498
rmdhawaii's Avatar
Default Boca Bearing Ultra Seals - "Maintenance free and lubed for life..."
This is what Boca Bearings had this to say about the Ultra Seals:
Thanks for getting in touch. While you may be able to extend the life of an ultra seal bearing by opening it and cleaning it, you will void our warranty. Lubed for life means it is lubed until the bearing starts to feel gritty, when this occurs it is either time to replace the bearing or open/clean it. but from that point forward the bearing would not be covered by us in case of failure. The biggest issue is that you can very easily damage the seals or shields. The Ultra seals are not water tight, there is no bearing that is water tight sealed, even the most heavy duty seals are just water resistant. So opening and cleaning is really your judegement call when you feel as though your bearings are getting towards the end of their natural life. Hope that helps, let me know if you have anyother questions.
Well, that answers that question!
Old 03-21-2006, 04:16 PM   #5499
jeffreylin's Avatar
R/C Tech Charter Subscriber
rmdhawaii, it occurs to me that you really want to try these bearings. whether they do provide the performance bang for the buck is of personal opinion. in truth, many upgrades we do to our cars do not improve our lap times at all, but they sure make us feel better about our cars, and i am certainly guilty of that. but this is a hobby and you should have fun with it. so if you can afford it maybe you should try a set and you can decide for yourself.
jeffreylin is offline   Reply With Quote
Old 03-21-2006, 04:56 PM   #5500
Originally Posted by jeffreylin
It's hard to say. As I mentioned earlier, the bearings go bad mainly due to collisions and dirt. So depends on how the race go, I may replace bearings as often as one race if I had a bad hit. On the flip side of that, some bearings are still good since when I built the car back in 04.
The wheel bearings especially outside ones tends to go bad easily. Bearings in the drive-train usually last a long time.
Please note that I have very strict standards when it comes to bearings. A lot of bearings I replaced might be consider good by others. I will replace them if they feel the slightest grittiness and not complete smooth.
I have to say that the Boca Ceramics are meant to last at least 16 races.
If they fail before that, then sometimes they will replace them at no cost.
Ceramics are the way forward, micro bearings in RC cars just dont handle it like above. Ceramics are lighter, freer running, last longer, and resist corrosion.
Its a no brainer. Why replace crappy bearings all the time when one set of 130 ceramics can last the season? (roughly)
rcrossco_1 is offline   Reply With Quote
Old 03-21-2006, 05:01 PM   #5501
Have you started to shave small areas of the chassis?
What a stupid idea.
Get the titanium hinge pins, balls, and suspension pivot balls.
Ive replaced most of the metals with titanium, and the difference is amazing, the car is SO light you can feel the difference.
Also get the titanium Bevel shafts, and titanium 2 speed shoe holder.
Old 03-21-2006, 05:06 PM   #5502
jeffreylin's Avatar
16 races? where did you get that from? 1 day races or 3 day events?
I had full ceramic bearings on all my electric cars and they did not last much longer than the regualr bearings.
Old 03-21-2006, 05:06 PM   #5503
Originally Posted by markp27
Oh man that hurt
Each to their own. The bearings I got weren't to be recommended, can't remember the name of the firm, but as I was saying above, the rubber seals were very bad and created friction which negated any free-rolling effects the bearings may have had.
Maybe I should test the Boca bearings.....send me a set over, Robert and I'll give you my opinion
Like Robert, I also clean my bearings very regularly - after two days of running at the weekend, all bearings are flushed and re-lubed. Buying ceramics and then not maintaining them is certainly a waste of money. You can only get the best out of the bearings by looking after them.
Cheers, MArk.
ITs all about the seals man. Ive a feeling you tested the ACER ones.
Utter rubbish I found them. Some of the seal was binding while other portions left huge gaps.
Boca are the best in my opinion. Stay away from Acer
Old 03-21-2006, 05:13 PM   #5504
Boca.
Old 03-21-2006, 05:22 PM   #5505
ogreasurada's Avatar
Boca.
I was just looking at the Boca bearings and i want to know
What difference do the different seals used in the YS and YU series? Which ones are better for onroad?
ogreasurada is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
