Old 03-20-2006, 02:56 PM   #5446
ziggy12345's Avatar
Originally Posted by markp27
That's an interesting idea, Ziggy! Not having had this on the 710, I never thought about that.
I take it with the inner position, you get more camber when the suspension compresses in comparison to the outer position?
Why is the 3mm shim necessary?
Cheers, Mark.
The kit is 2mm. The higher it is the lower the roll centre so more camber change. Even with no roll bar my tyres are coned in on both sides after 5 min heat.
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 03-20-2006, 03:00 PM   #5447
jag
jag's Avatar
Originally Posted by rmdhawaii
Interesting. I was more interested in the performance benefits. Given that all bearings are suseptible to dirt, damage and other types of failure, why wouldn't you want the faster bearing?
I found this online: http://www.edsbearings.com/faqbearings.html
Check with Boca Bearings. They make a few different types of ceramics. They are very nice but expensive.
jag is offline   Reply With Quote
Old 03-20-2006, 03:01 PM   #5448
markp27's Avatar
Send a message via ICQ to markp27
Ah, ok I understand. But you wouldn't always want to change the roll-centre, so maybe it is better to try just the inner position first?
markp27 is offline   Reply With Quote
Old 03-20-2006, 03:05 PM   #5449
rmdhawaii's Avatar
Jeffrey: How many hours do you think you're getting between bearing changes and are you changing all 23 bearings? Which ones don't you change?
I did some simple math and total on-track time for me will probably be no more than 24 hours all year - one hour per race day (practice 30min, 2 qualifers @ 4min each and 3 mains @ 5min each) x 24 races a year.
rmdhawaii is offline   Reply With Quote
Old 03-20-2006, 03:19 PM   #5450
jeffreylin's Avatar
R/C Tech Charter Subscriber
It's hard to say. As I mentioned earlier, the bearings go bad mainly due to collisions and dirt. So depends on how the race go, I may replace bearings as often as one race if I had a bad hit. On the flip side of that, some bearings are still good since when I built the car back in 04.
The wheel bearings especially outside ones tends to go bad easily. Bearings in the drive-train usually last a long time.
Please note that I have very strict standards when it comes to bearings. A lot of bearings I replaced might be consider good by others. I will replace them if they feel the slightest grittiness and not complete smooth.
jeffreylin is offline   Reply With Quote
Old 03-20-2006, 03:30 PM   #5451
rmdhawaii's Avatar
Thanks Jag! Wow! What a dizzying array of choices!
Old 03-20-2006, 05:14 PM   #5452
robert maestrey's Avatar
I'm of the same opinion - I once had a set and the rubber seals were really bad, they made contact with the bearings, thus causing aditional friction - my original bearings ran much better.
Mark I hate to disagree with you on this point......But the ceramics make the rrr drivetrain significantly smoother, it makes the car free in all aspects....Another point most of the top guys right now in the industry are using ceramics from one manufactuer or another.
there are some certain keys that help you get the most out of the bearings other than just putting ceramics in Im personally using Boca ceramics and it was a huge difference when I slpapped them on.....and they last.
Cheers friend
Remeber there are many things you can do to free up the drivetrain....ask and you shall receive...
robert maestrey is offline   Reply With Quote
Old 03-20-2006, 05:15 PM   #5453
I wonder were you got that Idea from....
Old 03-20-2006, 05:19 PM   #5454
I have been racing Consistently in S.Florida for about two years every weekend......Racing all over the place.....I have noticed if you constantly maintain you bearing periodically you rarely have to replace them.....it takes alot of work but it save you having to replace bearings...its not easy but trust me it works
Old 03-20-2006, 05:23 PM   #5455
rmdhawaii's Avatar
Rob,
What bearings are you using? Would you happen to have the part numbers handy? There is so much to choose from, I want to make sure that I get the right ones for the RRR WC Edition.
Thanks!
Old 03-20-2006, 05:27 PM   #5456
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default bearings
I agree with you Robert, at least once a month the car comes completely apart and so do all the bearings. Cleaned and regreased and maybe if its for the main in a national they just get some after run oil
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 03-20-2006, 05:28 PM   #5457
Rob,
Thanks!
www.bocabearings.com they should have a link for the rrr complete set...
they are expensive be prepared...if you dont want to pay that much..
you cant try www.acerracing.com very reasonable...I have never tried myself but I have heard some big names running them......
Old 03-20-2006, 05:31 PM   #5458
petey whats going on man.....are you slacking on me ......once a month come on you mean once a week ......and if its nationals or w-nats and big race definetly after each day....
Old 03-20-2006, 05:32 PM   #5459
Mr Day how are you doing I see you are inspecting the thread...
Old 03-20-2006, 05:36 PM   #5460
http://www.bocabearings.com/main1.as...&n=*25-420C-YU
hope this helps
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
