Old 03-14-2006, 02:06 PM   #5341
Osiris 75's Avatar
Trader Rating: 17 (100%+)
The basic Duratrax box!! It's like the rubber is just scraping off on the flywheel. I can move the flywheel with my fingers, but it only goes so far when the starter box turns it..
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 03-14-2006, 03:20 PM   #5342
rmdhawaii's Avatar
Originally Posted by Osiris 75
I'm attempting to start a brand new engine with a starter box, but the flywheel seems to get stuck and won't move. Any ideas??
This is your basic "the engine is tight at Top Dead Center (TDC)" problem. I had the same problem when breaking in my OS 12TZ engine. Once it got stuck, it started shaving the rubber off the starter wheel as in your case. Even when the engine was hot I had problems.
The advice I got and followed, is to use a large flat tip screwdriver to force the flywheel to turn over. This is probably the worst advice you could posssibly follow, but it's totally up to you. Leaving the car on the starter box, place the screwdriver blade about 1/8 way from the top of the flywheel (so that the blade tip is parallel to the groves on the flywheel - like this || ) on the fuel tank side and push down. This will force the flywheel to turn and your engine as well. You have to be very, very careful - because given the force you need to use, if your screwdriver slips, you could potentially damage something or injure yourself.
Initially, I used my fingers to turn the flywheel to get past the stuck point (i.e. take the car off the starter, turn the flywheel, put it back on), but it got tougher and tougher to do and I would continuously get air filter oil on my hand.
The heat gun / blow dryer idea sounds pretty good to me, but you have to have one of those two on hand at the track. In addition, you have to consider the time it takes for the head to heat up. As previously mentioned, I had problems even when the engine was hot.
I never thought of taking out the glow plug - because the engine (cold) would get stuck even if the glow plug wasn't inserted and I was turning the flywheel by hand.
Now that the engine has broken in, the engine doesn't get stuck anymore - but I'm not sure what damage, if any, the screwdriver technique may have caused.
I would consider the screwdriver technique, the technique of last resort.
Good luck!
rmdhawaii is offline   Reply With Quote
Old 03-14-2006, 03:37 PM   #5343
markp27's Avatar
Send a message via ICQ to markp27
Don't try and turn the flywheel like that - you will do some serious damage to the engine or yourself.
Do it like I show in the picture. This way you can use the screwdriver to lever the flywheel little by little - reducing the forces applied to the internal components of the engine.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 03-14-2006, 03:47 PM   #5344
markp27's Avatar
You'll have to make sure your starter box is adjusted correctly so that when you press down, that the rubber wheel makes good contact with the flywheel.
New engines are sometimes very tight and difficult to start. Once a bit of fuel gets into the engine, they generaly turn over a little better (due to the oil).
First of all, when you have your engine free again, heat up the motor head with a hairdryer - make sure not to melt anything though
Once the motor is nice and warm, you can try again with the start box.
Try pressing down on the car on the opposite side to the motor, to try and get the rubber starter wheel spinning before it makes contact with the flywheel. The allows the rubber starter wheel to get upto full speed before trying to turn the motor. Just pressing down normally means that the rubber starter wheel isn't rotating very fast before it makes contact with the flywheel, which makes it more difficult for it to turn over the motor.
If the flywheel still jams, then take out the glow plug and run the motor on the starter box for 20 seconds or so (if the starter box doesn't turn over your motor without the glow plug, then probably the electric motor(s) are too weak).
After you've had the motor turning over for 20 seconds or so, some heat and lubrication will have got into the motor (becareful though - this is really messy, with fuel flying out through the glowplug hole - use a clean rag to stop most of it from flying everywhere). Now replace the glowplug and try again to start the motor. You may find you even have to loosen the glowplug off a little in order to get the motor to turn over.
Good luck.
Mark.
Old 03-14-2006, 03:47 PM   #5345
rmdhawaii's Avatar
Thanks for the info Mark! Next time I'll know better!!
Is it typical for an engine to be that tight at TDC?
Old 03-14-2006, 03:50 PM   #5346
markp27's Avatar
Some motors can be - I had one motor which I just couldn't start with my old startbox until I had heated it up with a hairdryer.
Its often a good sign - my best motors are the ones with which I had more problems getting turned over.
Cheers, Mark.
Old 03-14-2006, 03:50 PM   #5347
markp27's Avatar
No problem - I didn't know it either until someone showed my - we all live and learn
Old 03-14-2006, 04:33 PM   #5348
robert maestrey's Avatar
Originally Posted by jag
Does anybody know the part number for the Kyosho lightweight mid shaft? I can't seem to find it.
Robert, you should know.
Thanks.
they have them in stock at Go Racing.......
robert maestrey is offline   Reply With Quote
Old 03-14-2006, 04:34 PM   #5349
jeffreylin's Avatar
R/C Tech Charter Subscriber
Thanks.
VZW056
jeffreylin is offline   Reply With Quote
Old 03-14-2006, 04:37 PM   #5350
Thanks.
Hope to see you at Go Racing this weekend......Jim
We need to get that car ready for Kissimmee...
Old 03-15-2006, 03:03 AM   #5351
ziggy12345's Avatar
Hi
I am hearing a lot of the top drivers are using a front diff with very heavy oil. 300,000-500,000 weight with 50,000 in the back. This is to be able to get the power down really early in the corners and power round and out. Anybody try this?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 03-15-2006, 06:00 AM   #5352
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
500k silicone "oil"? Why not just add silicone glue?
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 03-15-2006, 07:08 AM   #5353
jag
jag's Avatar
Cheers, Mark.
The first thing I would try is a 2.5mm hex on the end of the clutch. Prying the flywheel with a screwdriver marks-up the flywheel. I just stick a 2.5mm in the screw that holds the clutch on and give it a twist... to the right.
jag is offline   Reply With Quote
Old 03-15-2006, 07:17 AM   #5354
jag
jag's Avatar
How about coming up to Royal Palm on Saturday? I hear Maxy, Bart and Steve are coming up. I'm going to try to get Tim, Billy and Peter to come. If you come up with Wayne and Tino we could have a really good crowd. I'm sure Eddie (shorts) and Sonny will be there as well.
You are right, we do need to my car ready for Kissimmee.
Old 03-15-2006, 07:43 AM   #5355
markp27's Avatar
Can be done, too - I stopped doing this though, as I once rounded off the screw and it was a pain to get to out.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
