Old 03-12-2006, 08:30 PM   #5311
mcsquish's Avatar
I have a question for you all, I am trying to find the part number for the front universals that is used with the front Diff/spool. I think they are a little longer than the stock ones that are used with the one-way that came with the WC kit. I don't have the old stock ones to check the length and I need to replace my front universals. Any help would be helpful.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 03-12-2006, 09:34 PM   #5312
AndyT 's Avatar
Originally Posted by Secret_weapon
I was wondering, what is the best method of measuring the toe angle ?
I mean without the use of setup stations.
To measure rear toe angle without a setup station, stand the car on its rear and use a camber gauge upright against the rear wheels to measure the toe angle.
Cheers
AndyT  is offline   Reply With Quote
Old 03-12-2006, 09:51 PM   #5313
kewdawg's Avatar
Try these: Kyosho #VZW054 SWING SHAFT FOR V ONE
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 03-12-2006, 09:58 PM   #5314
Trader Rating: 13 (93%+)
andy thats an awesome way
used to do that before i got the setup station
too bad doesnt work on the front
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 03-13-2006, 12:59 AM   #5315
rmdhawaii's Avatar
Default K-Factory V1RRR Special 3mm Alum. 7075 Chassis (w/carbon stiffener)
K Factory V1RRR Special 3mm Alum. 7075 Chassis (w/carbon stiffener)
http://www.kfactoryracing.com/produc...1912&pageNum=1
I was at the hobby store today and the guy behind the counter pulled out the chassis. It sure looks sweet, but would I just be wasting my money? It's only $125.00 (*cough*) (*cough*) (*gasp*) (*choke*)
Do you have any K Factory parts? Anything good or bad to say about the parts or the company?
I'm starting to salivate...
K Factory Kyosho V1 200mm Gas Touring Car (V1RRR) Optional Parts
http://www.kfactoryracing.com/produc...99V1&pageNum=1
Thanks!
rmdhawaii is offline   Reply With Quote
Old 03-13-2006, 01:20 AM   #5316
jeffreylin's Avatar
R/C Tech Charter Subscriber
KFactory makes good stuff. I used some of their hop ups on my FW05R and performed well. While I do not have any on my RRR now I would not hestitate to put them on my car.
jeffreylin is offline   Reply With Quote
Old 03-13-2006, 01:28 AM   #5317
litespeed-dom's Avatar
Which US shop has a good selection of hopups? I know Lee has some, but that's about it.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 03-13-2006, 05:01 AM   #5318
Secret_weapon's Avatar
wow !! Easy and simple .. Thanks alot
Secret_weapon is offline   Reply With Quote
Old 03-13-2006, 05:23 AM   #5319
mcsquish's Avatar
Thanks kewdawg, I will.
Old 03-13-2006, 06:01 AM   #5320
markp27's Avatar
Send a message via ICQ to markp27
Originally Posted by fritzD
Thanks guys for the help! will this universal drive shaft be a little longer?
http://www.rcmart.com/catalog/produc...ducts_id=16689
I'm not sure I would recommend these K-Factory parts - this isn't any criticism about the quality of the K-Factory parts, in fact they are of exceptional quality.
The problem is the rear out-drives of the RRR are too soft for the hardend pins of these universals.
I ran one tank with these universals and now I need to replace what was a brand new set of out-drives
I would stick with the kyosho parts to be honest, as they are better matched in terms of hardness to the out-drives.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 03-13-2006, 08:18 AM   #5321
robert maestrey's Avatar
Cheers, Mark.
I agree with mark in some sense.....But I have used some k-factory parts including the chassis......they are very good.......the rear back plate I am still using and it is strong very strong.....chassis is thin has some flex you need to decide if thats what you want but it performs well......the brake pads and disc are awesome ran them at wnats never had brake fad for the whole 45 min main plus warmup....and they great braking power....hope this helps.......
robert maestrey is offline   Reply With Quote
Old 03-13-2006, 08:30 AM   #5322
maskedrider's Avatar
hey guys, how to make the boxes in our carry bag stronger as we know that the carton boxes are pretty soft. Currently i'm using those cloth masking tape rap it to make it stronger.
Or is there a better way to do it ? ( Spend quite a bit on this carry bag, so hope can last longer )
cheers,
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 03-13-2006, 08:32 AM   #5323
Ive seen some guys reinforce them with plexiglass and screw it all together and even attach handles.....
Old 03-13-2006, 08:47 AM   #5324
jag
jag's Avatar
Originally Posted by 710baby
KF1910 Front oneway/solid axle just like the 710
Where did you get it? I would like to give it a try.
jag is offline   Reply With Quote
Old 03-13-2006, 08:55 AM   #5325
jag
jag's Avatar
You will also get the same results with caster clips changes
1mm clip all around neutral setting equal entry & exit arms in middle positon
1mm clip front 2 mm clip back neutral entry positive exit semi aggressive
0 clip front 3 mm clip back aggressive entry slugish exit arms forward
I don't quite follow you here. I have my car setup stock (1mm clip in front, 1mm clip in back). 1 + 1 = 2. How are you fitting 3mm in there... trimming the arms? I have some play there but not 1mm worth. I was thinking about taking a 2mm clip and sanding them down to fit.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
