Old 03-06-2006, 09:34 AM   #5221
ziggy12345's Avatar
What are the inputs for this program assuming you setup the car as per the kit default?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 03-06-2006, 12:13 PM   #5222
MCRUZ's Avatar
Thumbs up RRR
Congrats to Kyosho America driver Walter Diaz for a second place win at the pre-nats race this past weekend.
M32EVOX
MCRUZ is offline   Reply With Quote
Old 03-06-2006, 12:25 PM   #5223
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by robert maestrey
If you are using the phillips style motor mount screws.......You might want to try some 2.0 x 8 they work great and you crank them down real tight.....thread lock never hurts there including before a big long race.....
Hey rob did not get a chance to meet you yesterday @ Kissimmee raceway was busy running 2 classes how did you finish. will I see you @ the cup
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 03-06-2006, 03:12 PM   #5224
robert maestrey's Avatar
What is your name anyways...........I quailified 2 , finished 4 th.....
robert maestrey is offline   Reply With Quote
Old 03-06-2006, 03:18 PM   #5225
George Martinez........Im pretty sure you were one of the guys with a yellow hat......am i correct.....
I have not yet decided about the cup race.......I checked the kyosho america and kyosho sites foiund nothing about the kyosho cup.
Old 03-06-2006, 07:11 PM   #5226
rmdhawaii's Avatar
Default Understeer problem
I had to adjust the steering throw because the front shock bottom endcaps were rubbing against the front rims. Now I have a slight understeer problem on a pretty tight track. Have any of you experienced this problem? What adjustments did you make to correct the problem? BTW - Also changed my rear diff oil from 30,000 to 20,000 and I'm running the front one-way.
Thanks!
rmdhawaii is offline   Reply With Quote
Old 03-06-2006, 07:19 PM   #5227
GMartinez's Avatar
No yellow hat for me finished 4th in the B main
I was checking also & did not find anything as well
Old 03-06-2006, 07:34 PM   #5228
drfritz's Avatar
Thanks!
Try increasing the front width a hair, or trimming the inside of the rim.
set up wise you need to loosen the rear up some so the car will rotate.ak shock oil, sway bar or thicker diff fluid. raise your rear roll center, those are a few things you can try,how tight is the track?
drfritz is offline   Reply With Quote
Old 03-06-2006, 11:18 PM   #5229
rmdhawaii's Avatar
drfritz
Coming off a straightaway at full-throttle, you go into a track-wide left "C" turn, which after 12 ft goes into a left "S" turn (bottom of the "S") which upon exit goes straight 50 ft and then goes into a right "C" turn. (Sorry, I'm still new at track terminology) Height of the top half of the "S" turn is about 15 ft. The height of the 2nd "C" turn can't be more than 30 ft. It is so tight, that if I don't place the car in the correct position at the start the S turn, I'll never make it out the other end without hitting the track. Same thing with the C turn, only I know I've placed the car correctly at the top of the 2nd "C" turn and even at full right turn, I can't make it around at a decent speed compared to the other cars. The track dimensions are approximately 200 x 60 ft with a lot of tight turns like this.
The prior race weekend, the rear end was way too lose. The car was "sliding" quite a bit. I'm not quite sure if you could call it oversteer, as the car never really spun out.
Width wise, I ran about 197 mm with some new tires that I bought. I was at 200mm with the previous tires, which hit the end caps. Extending back to 200 would probably help things a bit. I'll have to check. Now that you mention it, I was being lazy and didn't want to have to completely redo the alignment - I figured, "it's only 1.5mm on each side - I'll leave it".
The diff oil change to 20,000 was based on some feedback that 30,000 (included with the kit) felt really tight when out of the car and turning by hand. I had to take the diff apart because it was leaking (again), so I decided to change it at the same time.
Ride height wise I'm 6mm rear, 5.5mm front as recommended in the setup sheet.
Any other suggests or thoughts would be greatly appreciated.
Cheers
Old 03-07-2006, 01:17 AM   #5230
ziggy12345's Avatar
Get on the gas earlier! If its understeering on power reduce the toe in at the rear
Sponsored by:
Norfolk and Chance
Old 03-07-2006, 05:23 AM   #5231
what part of florida are you from George......also where were you pitting at the race and with whom......
Old 03-07-2006, 08:29 AM   #5232
rmdhawaii's Avatar
Interesting. I would have thought that accelerating on understeer would just make things worse, but I’m still extremely new at this. With the 4WD, is understeer a desirable condition so that a person can accelerate much earlier exiting a turn? At what point in the turn would you suggest accelerating? I usually go neutral into a turn (more below) and don’t accelerate until I’m about 90% out of it.
In my prior thread I wrote, “Coming off a straightaway at full-throttle…”, what I should have written was, “Full-throttle on the straightaway and brake before the turn so that I’m going through it neutral.” I accelerate 90% out of the turn and go through the bottom of the “S” turn off power, accelerate a bit (more of a blip) and then go through the top of the “S” turn off power, accelerating 90% out of the turn, then go through the 2nd “C” turn off power, accelerating 90% out of the turn.
Maybe I need driving lessons!
Old 03-07-2006, 09:01 AM   #5233
I would suggest as early as possible.. my theory is if you can be on throttle longer than the other guys and keep a tight line you should be faster.........some guys like understeer....I dont like it at all...... all i can tell you is the earlier you can roll on the throttle the faster you will be.
Old 03-07-2006, 09:04 AM   #5234
You might want to also go to a heavier weight oil in diff if you have understeer...this will help both on and off power understeer...
Old 03-07-2006, 10:27 AM   #5235
markp27's Avatar
Send a message via ICQ to markp27
Hi Robert,
my understanding was that a heavier weight oil would create more understeer into the corner - is this not the case?
Cheers, Mark.
markp27 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
