Old 02-25-2006, 08:28 AM   #5131
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Originally Posted by fritzD
wouldn'y you need to change the bumper or something??
I would think so it makes a lot of sense considering the low clearence in the front.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 02-25-2006, 08:46 AM   #5132
So Robert what was the reason for this change? What did it do for the handling?
BTW Dude, I was so proud of your results at the Winternats! I remember when you and I used to dice at Go Racing and Coral Springs and now I see you have moved to another level! Way to go star! Are you coming to our inaugural race in Jamaica for Easter weekend?
Look forward to seeing you!
Later
Josh
ky-JOSH-o is offline   Reply With Quote
Old 02-25-2006, 09:02 AM   #5133
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by EdwardN
To whom it will be interested-on Winternats we were using 24 T pinion for second speed and it makes a lot of difference on top speed.
Edward
Hey Ed it was nice to meet you @ the Nat's when are yo going to have pics of the motor you were talking about I don't see it on the website
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 02-25-2006, 03:56 PM   #5134
robert maestrey's Avatar
Later
Josh
Thanks Josh, I remember those days very vividly and I miss them. The change to the rear for Ft.myers just made the rear end feel more stable less roll. Hey what are the dates for that race I might be going up with the wife......
robert maestrey is offline   Reply With Quote
Old 02-25-2006, 07:43 PM   #5135
maskedrider's Avatar
Any good R/C bag to recommend ??
Wanna to get one but don't know which one to choose from
any suggestion on the bags you guys been using
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 02-25-2006, 08:42 PM   #5136
team magic formula 8 awesome........I havent had any problems with it
Old 02-25-2006, 08:48 PM   #5137
jeffreylin's Avatar
R/C Tech Charter Subscriber
jeffreylin is offline   Reply With Quote
Old 02-25-2006, 09:01 PM   #5138
how about the TM touring bag ( black ) ??
Old 02-25-2006, 09:30 PM   #5139
ogreasurada's Avatar
The TM touring bag is for 1/10 while the Formula 8 is for 1/8, but to me more space is better.
ogreasurada is offline   Reply With Quote
Old 02-26-2006, 02:51 AM   #5140
Secret_weapon's Avatar
What diameter of foam is good ?
I use Ellegi tires and they work good with me.
I recieved my new 3racing tire truer and I was just thinking of what diameter should I start with. And what about the angle thing ? Is it good to make an angle for the tires ?
Secret_weapon is offline   Reply With Quote
Old 02-26-2006, 07:32 AM   #5141
jeffreylin's Avatar
It all depends on the kind of track you run. For tracks with higher bites and little tire wear, 57F and 59R is near optimum. But for lesser traction and high wear track, you really have no choice but to start big, like 62F 64R.
You shouldn't need to cut the tires with camber angle--it'll just wear into it depends on your car set up.
Old 02-26-2006, 07:42 PM   #5142
Trader Rating: 13 (93%+)
Default pinion sizes for large tracks // excess rear right tyre wear
hey guys
i jus wanted to know if i go up a tooth in pinions from the stock would i then be using 17/22 ? will this work with 55/60 spur gears ?
this weekend that justpassed we had a pretty big race meet. my outer wheel being the rear right was suffereing from major tyre wear. in a 20 minute final it wore 2mm more than the rear left. the right wheel was the outer wheel so i know its doing more work.
would it be best to look at roll centre or maybe going to a higher shore tyre like a 40 ? the car was a bit loose on power on that corner
thanks
John
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 02-26-2006, 08:03 PM   #5143
fritzD's Avatar
Send a message via Yahoo to fritzD
Edward
i'mjust curious although i will never be using 24T. what combination do you use? 17T/24T for clutch? and what for the spur? thanks!
fritzD is offline   Reply With Quote
Old 02-26-2006, 10:20 PM   #5144
AndyT 's Avatar
Originally Posted by mrgsr
hey guys
thanks
John
Hey John
Lowering the rear roll centre will help ease rear tyre wear a bit.......theres 3mm spacers available that replace the stock 2mm ones that will lower the rear roll centre......or you could change the blocks.....that said though I ran the final with the rear roll centre at stock setting.
In that final i started with the rear right fresh out of the box (64mm)....at the end it was down to 56.2mm........7.8mm wear!! .....the left side wore 3.3mm......I had 37 shore on the rear (didnt like the 40`s i tried in the final heat on Saturday at all).
Cheers
AndyT  is offline   Reply With Quote
Old 02-26-2006, 10:38 PM   #5145
EdwardN's Avatar
We didn't think that motor will turn it over, but it did very easy.
17/24 61/56. Also we were using "red' spring from EVOLVA for cluth.
Edward
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
