Old 02-24-2006, 12:24 PM   #5116
Hey Robert, when you say roll center opposite to stock, what do you mean? And, did you set my car up that way?
Josh
ky-JOSH-o is offline   Reply With Quote
Old 02-24-2006, 12:56 PM   #5117
What made you put on the ufo clutch I tested it when it was first released & was not impressed with it the spring is way to soft & there was a loss in midrange when spooling up.
George did you use any other spring other than the red one?? I know we told you we used the orange one which is harder.
One of the benefits of the Kyosho K Factory UFO is it comes with a hard annodized alumunium clutch bell that bites consistant and does not wear or glaze. it weighs literally nothing and it comes with hardened pinions installed on it. How much of an improvment is it? (some) but if your looking for reduction in rotating weight its a pretty good reduction in the right place. Rotating weight reduction is 4 times as important as car weight reduction when it comes to acceleration. The bell removes 10 grams off the crank which equates to the same performance improvement as reducing 40 grams of weight off the car. If your going to reduce the weight of the car you start with rotating first and mass of the car last
On the G4 UFO the alumunium bell and pinions are extra. Just the reduction in rotating mass with the bell is an acceleration improvement.
Motorman2 is offline   Reply With Quote
Old 02-24-2006, 01:28 PM   #5118
GMartinez's Avatar
Trader Rating: 85 (100%+)
I went from red to orange & then used the Mugen spring for it to come to life .
I just wanted to hear his response cause on different motors it will take some tweaking to get it to perform at the highest level as for weight on the kyosho it comes right at the legal limit depending on servos. but when running modified motors & using the the UFO clucth there will be a need for gearing change since runtime will be a issue
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 02-24-2006, 01:32 PM   #5119
GMartinez's Avatar
Originally Posted by B4
Anyone tried this part yet VZ207. I have mine on the way from Japan.
I have mine's coming this weekend
? High bite track in my previous car I ran 30,000 in my diff & solid spool has anyone tried this on the RRR
Old 02-24-2006, 01:34 PM   #5120
robert maestrey's Avatar
Josh
your car has the roll centers stock josh. what I did in ft myers was flip the rear rollcenters......there are four positions top, upper,lower and bottom...I set your to upper which is stock ....in ftmyers I had them at lower......I hope you understand this explanation
Hope to see you soon take care
robert maestrey is offline   Reply With Quote
Old 02-24-2006, 01:38 PM   #5121
High bite youll probrably be able to run 50000 try ut the car is very good with it........ran 50000 with one-ways at ft myers and was good ......I should have tried a little heavier.....
Old 02-24-2006, 02:08 PM   #5122
GMartinez's Avatar
Thanks robert I saw you car it looked good but the ? is with a spool I tested it in a mongoose @ the GLC it felt really good just don't know how it would feel on the RRR since I really don't have time to test it before the next race
Old 02-24-2006, 04:35 PM   #5123
Should give you basically the same feel as it did with the monggose......4 wheel braking and good on power, you most likely will suffer some off power steering.
Old 02-24-2006, 04:52 PM   #5124
GMartinez's Avatar
Yeah I know what you mean on the off power steering what i did was offset the caster clips & it gave me great entry&exit I just don't want to tinker with the RRR to much since I really enjoy the car overall
Old 02-24-2006, 07:00 PM   #5125
Good Idea with the clips.......
Old 02-25-2006, 02:48 AM   #5126
EdwardN's Avatar
To whom it will be interested-on Winternats we were using 24 T pinion for second speed and it makes a lot of difference on top speed.
Edward
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 02-25-2006, 05:19 AM   #5127
Secret_weapon's Avatar
Hi,
I was wondering if I can use lola body for my v one rrr.
If so, What parts do I need to fix it ?
Secret_weapon is offline   Reply With Quote
Old 02-25-2006, 07:47 AM   #5128
Edward
Nice to know....I thought the highest was 23.......
Old 02-25-2006, 07:58 AM   #5129
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Originally Posted by Secret_weapon
Hi,
Hopefully if i,m correct any 200mm & 235mm body should fit with no problem, it is just a shell think of it that way,
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 02-25-2006, 08:23 AM   #5130
fritzD's Avatar
Send a message via Yahoo to fritzD
wouldn'y you need to change the bumper or something??
fritzD is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
