Old 11-08-2004, 09:42 AM   #496
Data's Avatar
Originally posted by rossiRocket
my fronts bind excessively.
try this.
Data is offline   Reply With Quote
Old 11-08-2004, 11:11 AM   #497
Ron C.'s Avatar
Originally posted by bcquick
thanks but none of them have them,
Hi bcquick,
I sent you a PM for some contact info where you may get the
parts you need... Hope this helps.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 11-08-2004, 10:04 PM   #498
Default screws
does anyone know of a maker who makes a set of titanium screws specifically for the rrr? and is there a bid difference between titanium and steel?
Joe Chaplow is offline   Reply With Quote
Old 11-09-2004, 02:02 AM   #499
pelos's Avatar
Default Camber
What does it mean 0G and 1G in the camber setting?
I red 0G refers to standard chassis height and 1G refers to lowered chassis height, but I do not understand what does it mean.
Could anyone help me? Thanks.
pelos is offline   Reply With Quote
Old 11-09-2004, 02:27 AM   #500
Joehwee's Avatar
0G = Elevated camber ie, droop fully extended
1G = Camber when car is on the ground, the camber will be affected by the ride height
HB Racing - OS Engine - VP Powermaster - Nosram - Sanwa - Schumacher Racing - HPI Racing - CapricornRC - Dualsky - Savox - AKA - Juc Racing - Team Orion - SMJ - MM Spec - Muchmore Racing
Joehwee is offline   Reply With Quote
Old 11-09-2004, 06:29 AM   #501
pelos's Avatar
So if I want to set camber with 0G I have to put the car on blocks?
Old 11-09-2004, 06:39 AM   #502
Joehwee's Avatar
yes, you are right
Old 11-09-2004, 07:03 AM   #503
Default screws
Old 11-09-2004, 07:10 AM   #504
pelos's Avatar
Default Caster
Another question regarding caster.
The out of the box version is very loose. I tried with another 1mm caster clip from my old V1R but then is binding. How did you manage to solve this problem?
Old 11-09-2004, 10:38 AM   #505
ziggy12345's Avatar
Default Re: Caster
Add a small 3mm washer to the hinge pin during construction.
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 11-09-2004, 10:49 AM   #506
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: screws
The titanium screws are lighter but not as strong as steel. The RRR is underweight as it is you really don't need titanium screws to lighten the car further.
jeffreylin is offline   Reply With Quote
Old 11-09-2004, 11:11 AM   #507
Default screws
titanium screws tend too round off fairly quickly also, if the car is under weight i wouldn't bother
but if you really want a set
click here
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 11-09-2004, 11:30 AM   #508
dougday's Avatar
Hey what did you guys do to keep the front and rear lower suspension arms from binding? I'm in the process of building my car, taking my sweet time and my fronts bind excessively. I think my right bulkhead is deformed, but I wanted to see if there are any remedys to get them to work without buying replacements. I already tried drilling the arms out but to no avail.
Does any aftermarket company sell anything that could help in removing the bind?
Just flex the bulkheads until the hinge pins slide thru. They are quite flexible.
dougday is offline   Reply With Quote
Old 11-09-2004, 11:35 AM   #509
dougday's Avatar
Try Fast N Furious in Ft Lauderdale. They should have parts
Old 11-09-2004, 01:29 PM   #510
Send a message via AIM to rossiRocket
I tried that and it still binds. I finally just drilled them out with a drill bit that was barely slighty larger then the hingepins by only less then 0.2 mm. No more binding! The arms pivot nice and freely with just barely slight play that, in my estimate, wouldn't affect handling. I did this to the rear lower arms as well since they were binding more than the fronts. Now the suspension geometry will act as they were designed to.
rossiRocket is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
