Old 02-20-2006, 09:27 PM   #5071
markp27's Avatar
Send a message via ICQ to markp27
Originally Posted by robert maestrey
Ill give you guys full report when I get home tonight....
Coooool
markp27 is offline   Reply With Quote
Old 02-20-2006, 09:32 PM   #5072
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by esham
Jeff i check the Japanese website but the VZW207 also listed with VZW207-01 and VZW207-02, Not so sure which and which it refer to. Could you describe what the no. refered to? Thank you
VZW207 = VZW207-01 + VZW207-02
One is the shock tower, the other the mount.
jeffreylin is offline   Reply With Quote
Old 02-20-2006, 09:36 PM   #5073
robert maestrey's Avatar
Originally Posted by markp27
That's what I used, too, Robert, but I guess I'm too stupid to do it correctly
Any chance of you giving us your impression of the Winternats? How the car went, any problems encountered, setup for next year?
Congratulation on your result! Great run!
Cheers, Mark.
Winternats was awesome like usual, Jim Rice and his crew put on a fantastic show.
It was so freaking cold out there that one morning you could even scrap ice off of the pit tables
The car is good real good the car only got better from practice to qualifiers. The only real problem was one traction roll I had thru the s in front of the timing loop. The car slide on its roof and the rear end smacked the wall breaking the left rear lower arm . I also had mileage problems like others .
Good weekend over all.....and now hear comes what I think you guys really want to see.
Setup front
droop 0
camber 2.5
caster defalut
track width 200
sway stiff
ackerman 11
toe out .5
roll center defalut
shock oil 600
spring black
shock loc. default
oneway
Setup rear
droop 5
camber left 4.0 right 3.5
track width 200
sway 2.3
toe in 2.0
roll center opposite from default
shock oil 600
spring gold
shock loc. default
diff 50000
gears default,shock bladders and pistons default
Did i forget anything....
Thanks Tino (Niketa) Hall , Wayne Hinds
Ravi, Patrick
robert maestrey is offline   Reply With Quote
Old 02-20-2006, 09:41 PM   #5074
Old 02-20-2006, 09:43 PM   #5075
Coooool
Cut the report a little short due to how late it is
But I think you got what you wanted
Old 02-20-2006, 10:31 PM   #5076
JustRace's Avatar
BTW, Bro, what's with your RRR?
I'm off to test mine again at the weekend - first test very positive, second test will be even better, I think.
Mark.
Mark....it's more of a borrowed ride from Niketa. I'm still waiting for some parts to finish up. But you know I'm a big snake fan
JustRace is offline   Reply With Quote
Old 02-20-2006, 10:35 PM   #5077
JustRace's Avatar
Ravi, Patrick
What shore tire? What brand? What body?
You also forgot to thank your fuel and motor guy
Old 02-21-2006, 12:13 AM   #5078
esham's Avatar
Thank you Jeff.
I tried to search back the discussion on off set front knuckle but after 10-20 pages i still could find one. Have to raise it again guys sorry. Anybody have good comment on The front knuckle 1 and 2 offset. Is it will improve further the steering etc?
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 02-21-2006, 01:03 AM   #5079
BundyMan's Avatar
Thank you Jeff.
Esham, all depends on your driving style and also the requirements of the particular track. I have installed the 1 degree front knuckle and on power steering has noticeably improved. The V1RRR have enough off power steering even with the 1 degree knuckle
BundyMan is offline   Reply With Quote
Old 02-21-2006, 01:18 AM   #5080
esham's Avatar
Thanks Bundyman.. 1 knuckle coming up for our coming local Mugen Qlfy. race.
Old 02-21-2006, 02:08 AM   #5081
MCRUZ's Avatar
Smile
Thank you Jeff.
using the 1or2 deg. knuckle is like adding more caster to the car. it will tame the entrance steering but will give you more exit steering.
M32EVOX
MCRUZ is offline   Reply With Quote
Old 02-21-2006, 06:03 AM   #5082
rmdhawaii's Avatar
Default What rear diff oil are you using?
The kit comes with 30,000 rear diff silicon oil (hard). What are you using and why?
My rear diff started leaking again and I need to buy a new housing and change it out. I might as well put in some other oil in while I'm at it!
Thanks!
P.S. Things were just fine with the front one-way this weekend. Driving and braking were not a problem at all. I think I'll keep it as is.
V-ONE RRR WC Edition
OS .12 TZ(P)T 3-Port
rmdhawaii is offline   Reply With Quote
Old 02-21-2006, 06:47 AM   #5083
Used Nitro shoes jaco 42 front and rear
protoform stratus 3.1
Sirio Evo3 modded by Uriah Murnan.......
Fuel Mr. Lee's Special Blend
Thank you Uriah Murnan, Francis Lee
is that better......
Old 02-21-2006, 06:52 AM   #5084
Thanks!
Go up in weight according to how much traaction track has. higher traction
heavier weight lower traction lighter weight...that simple........find a happy median with your setup and diff and the car should react......dont try to get the car to work soley on changing diff oil. you also need to fine tune with other things to make the car bettter.
Hope this helps a little
Old 02-21-2006, 07:17 AM   #5085
markp27's Avatar
Thanks for the info.
How about the wear-and-tear on the car - the track is pretty hard on on the parts, so any weaknesses will show up there pretty quickyl.
Thanks, Mark.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
