Old 02-20-2006, 10:33 AM   #5056
robert maestrey's Avatar
Hey Jeff, do you run at crystal park....reason im asking is because Im planning on attending the Nats....and im trying to make contacts before i head up there.
robert maestrey is offline   Reply With Quote
Old 02-20-2006, 10:55 AM   #5057
jeffreylin's Avatar
R/C Tech Charter Subscriber
I have, but not as much as Revelation. The stock set up works well there but you will need to increase your droop and ride height. It's a fairly big track for sedan so gear up.
jeffreylin is offline   Reply With Quote
Old 02-20-2006, 11:16 AM   #5058
markp27's Avatar
Send a message via ICQ to markp27
what i used was the 4mm end on the hudy glow plug tool it worked great , kept them straight as it went into the blocks.
That's what I used, too, Robert, but I guess I'm too stupid to do it correctly
Any chance of you giving us your impression of the Winternats? How the car went, any problems encountered, setup for next year?
Congratulation on your result! Great run!
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 02-20-2006, 12:43 PM   #5059
jag
jag's Avatar
Originally Posted by jeffreylin
I also tried the bearings before. While it makes the rear smoother it also makes the rear hub prong to breakage as there is no give when you tap the rear anymore.
Good point. I will have to give it a stress test. Has anyone tried the aluminum brace for the rear shock tower (from K Factory I think)? It looks pretty weird but if it works it might be worth a try.
jag is offline   Reply With Quote
Old 02-20-2006, 12:55 PM   #5060
Osiris's Avatar
One more question. Does anyone know where I can go online to purchase the little black plastic pieces (don't know what they are called) that go between the blue screw cap and the pivot balls??
Osiris is offline   Reply With Quote
Old 02-20-2006, 01:20 PM   #5061
jeffreylin's Avatar
In your manual there is an exploded view of the entire car. Next to each part it shows the part number. Call Kyosho America 800-716-4518 and either order directly from them or have them point you to your local hobby shop.
I don't know where you can buy complete Kyosho parts online other than going to an oversea shop such as RC Mushroom or order directly from Japan by email.
Old 02-20-2006, 01:55 PM   #5062
JustRace's Avatar
Cheers, Mark.
Mark...see what you missed And I would have been your pit monkey!!!
JustRace is offline   Reply With Quote
Old 02-20-2006, 02:07 PM   #5063
markp27's Avatar
You're right, Bro - that could have been us celebrating Next year you can be my pit moneky, though
Old 02-20-2006, 02:15 PM   #5064
markp27's Avatar
BTW, Bro, what's with your RRR?
I'm off to test mine again at the weekend - first test very positive, second test will be even better, I think.
Mark.
Old 02-20-2006, 03:09 PM   #5065
Trader Rating: 13 (93%+)
Default lola bumper
Originally Posted by fritzD
does anybody know which bumper parts are needed to be able to use lola or GT1 bodies on the RRR? thanks!
I used the bumper setup from a v one rr, fits straight on
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 02-20-2006, 03:11 PM   #5066
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default 1 bad 3r
possibly comming down sat for testing at cp anyone want to help me set up my triple for pre nats
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 02-20-2006, 03:14 PM   #5067
AndyT 's Avatar
Does anyone have any tips or hints on how to install the blue screw caps? The ones that go over the pivot balls. I'm strugglin with this right now.
Try applying a small amount of grease to them.....should help them go in a bit easier
Cheers
AndyT  is offline   Reply With Quote
Old 02-20-2006, 05:48 PM   #5068
Cheers, Mark.
Ill give you guys full report when I get home tonight....
Old 02-20-2006, 06:48 PM   #5069
esham's Avatar
New Kyosho rear shock mount and shock tower--no more crooked rear shock tower. Kyosho also made the shock tower thicker at 3mm, addressing another common complaint.
Part number VZW207.
Jeff i check the Japanese website but the VZW207 also listed with VZW207-01 and VZW207-02, Not so sure which and which it refer to. Could you describe what the no. refered to? Thank you
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 02-20-2006, 08:50 PM   #5070
Cheers
Sweet tip gotta try it.......
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
