Old 02-12-2006, 05:17 AM   #4966
tommi's Avatar
Originally Posted by esham
Need help here... I'm changing the rear upper arm link to the one that we can use bearing instead of end ball. But what size of bearing i should use?
Hi Esham, may I know if this is a custom mod or it's an option from Kyosho? I'm wondering how the captured rod end is gonna be held on to the bearing, mind to enlighten? Thanks!
tommi is offline   Reply With Quote
Old 02-12-2006, 02:57 PM   #4967
AndyT 's Avatar
In the rear arm set (included with kit) theres optional rear inner camber links.
The bearings (you`ll need 2 for each side) mount into the optional part (the link then screws into the plastic of this new part) and then the mounting screw runs thru the middle of the bearing......it acts like a hinge for the inner mount to pivot on....seems like its a lot smoother than the ball link mount.
Cheers
AndyT  is offline   Reply With Quote
Old 02-12-2006, 09:25 PM   #4968
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Originally Posted by SOLOARTIST 702
i got it IVAN D looking it over now studying may try to get 2 LA next sat. to do some running at cp
Congrats soloartist, welcome to the RRR hood Hopefully I'll see you at one of local Cali tracks CP or Rev.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is online now   Reply With Quote
Old 02-13-2006, 12:22 AM   #4969
rmdhawaii's Avatar
Default Clutch engaging late problem
I just built a V-ONE RRR WC Edition car with a OS TZ .12 3-port engine w/slide carb. After going through two tanks of Nitro on the starter box, I tried to run the car, but the clutch was really late in engaging. A buddy of mine took a look at it and tried to adjust it (we even took the whole clutch assembly to verify that I built it right), but we couldn't the setting right. The engine is running rich and my friend did fuss with the idle speed adjustment.
Anybody have similar problems?
Got any suggestions?
Thanks!
BTW: The TZ is really tight at TDC, even after going through two tanks of fuel.
rmdhawaii is offline   Reply With Quote
Old 02-13-2006, 12:38 AM   #4970
jeffreylin's Avatar
R/C Tech Charter Subscriber
Thanks!
It takes much more than 2 tanks to break in a motor. 10 tanks is more like it.
Your engine setting is too rich. This is fine as it is set for break in. But you should gradually lean it after say 5-6 tanks.
If you need to know how to break in your engine here is a good article you can read:
http://www.cefx.net/tips/nitro/break-in/index.php
jeffreylin is offline   Reply With Quote
Old 02-13-2006, 12:55 AM   #4971
tommi's Avatar
Cheers
Great! Thanks a lot Andy, appreciate your explaination. To be frank, I read your post yesterday night, it took me quite some time to get it figured out... Esham's attached pic helped... Coming back to it, can we get the bearings from Kyosho? I couldn't seem to get the part number for it... So besides the bearings and the optional link, are there any other parts that I should get to do this? A picture would've been a great help! Thanks in advance!
Old 02-13-2006, 02:42 AM   #4972
AndyT 's Avatar
It was kinda hard to figure out how to explain the way its done....
Each side of the car gets the new mount....the bearings go into these mounts....2 bearings are used for each side (so in total you need 4 bearings)....the bearings simply push straight into the plastic mount...this plastic assembly with the bearings inside then screws back onto the metal turnbuckle.....then the existing mounting screw is used to attach this whole new assembly to the existing attachment point.
I couldnt find a Kyosho genuine bearing size to fit, but had no problem getting the correct sized bearings from my LHS.
Let me know how you go, if you still have probs I`ll try and post a pic.
Cheers Andy
Old 02-13-2006, 03:43 AM   #4973
tommi's Avatar
Cheers Andy
Thanks again for the trouble Andy. I did a search, Kyosho does make those bearings for the Mini Inferno; GWS too has them for the helis.
Old 02-13-2006, 04:08 AM   #4974
B4
B4's Avatar
Do you know if the the Kyosho bearings come in a pack of two. If it is one per pack that is to expensive.
B4 is offline   Reply With Quote
Old 02-13-2006, 05:46 AM   #4975
tommi's Avatar
I had a hard time myself figuring that out too... It should come in a pack of 2, the 3x6x2.5 flanged bearings cost more and they come in a pack of 2 for 10 bucks. I'll be getting myself some GWS ones soon, no one runs the mini inferno over here, I reckon it will be close to impossible to get hold of the Kyosho ones.
Old 02-13-2006, 06:42 AM   #4976
jag
jag's Avatar
Thanks!
Besides the engine break-in, you probably have the preload nut in the clutch too tight. If you set it up per the manual (1.2mm) it's to much. Try loosening it to around .6mm. That's where I have mine and it works fine.
Don't rush the engine break-in.
jag is offline   Reply With Quote
Old 02-13-2006, 06:58 AM   #4977
tommi's Avatar
Hmm...isn't 0.6mm a little bit too..er...little? I've always find the stock 1.2mm to be fine, sometimes I would even go up to 1.25-1.3mm, and the clutch just never felt engaging too late.
rmdhawaii,
It could be the shimming too... Is the clutchbell moving excessively? If it is, it should not. Most importantly like what jefferylin and jag said, do not cut short the engine break-in process. A mere 2 tanks on the starterbox is NOT enough! My buddies who ran the TZ had to go through at least 6-8 tanks on the starterbox before hitting the track for another 4-5 tanks of running-in. Follow the Josh Cyrul's method that jefferylin posted, it might seemed time consuming and fuel-wasting, but it's a small price to pay for a longer-lasting engine.
Old 02-13-2006, 08:39 AM   #4978
I have a dumb question or maybe not... I was running my RRR Sunday at CP and having a good time on the track... Pulled my car off the track to help a friend with his... His RRR/Nova motor would'nt start... It was found to have a broken fuel tank... Got it fix/put in brand new one... Then when I went to refuel mine... Fuel ran out everywhere.... I too had a broken/leaking fuel tank... Is this an issue with Kyosho RRR's??? My car is only 2 weeks old and still looks brand new... I haven't seen anything like this since my NTC3 days years ago... Is there a fix for this or an updated fuel tank coming??? Thanks
RC_Alan
rc_alan is offline   Reply With Quote
Old 02-13-2006, 09:27 AM   #4979
GUINT1's Avatar
Thumbs up
RC_Alan
Alan... yes gas tanks do brake.This i belive has been known to happen to a few guys that run this car. My bubby and i both had the same problem, as well.
In my case. My gas tank didnt brake. Mine had
a air leak were they sealed the two peices togetther, to make the tank.
By me not knowing this at the time. It was also hard for me to start my car.But i was very lucky to catch it.
Because the motor could have leaned out from this air leak.
Just change the tank, and you will be fine. Hope this helps.
Empire Racing/Maxy's fuel/Ko Propo
Motor. .21 FLASH/353 Race
Body. Zytech/P909
Tyres. Ky Red Box
GUINT1 is offline   Reply With Quote
Old 02-13-2006, 09:32 AM   #4980
jeffreylin's Avatar
RC_Alan
It was a problem with the original RRR. When you hit the chassis will bend slightly and put stress on the tank and crack it. The newer ones and the WCE has a new upper deck with elongated screw holes for the tank so that it has room to move under stress thus alleviating the problem. Just make sure you do not over tighten the tank screws and leave them a little loose.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
