Old 02-09-2006, 08:01 PM   #4951
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmmm
wont make it to florida but after that LOOOOOOOOKKKKKKKKKKK OUT
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 02-10-2006, 11:45 AM   #4952
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Hey soloartist have you got your RRR yet?
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 02-10-2006, 09:30 PM   #4953
Default oh yeah
i got it IVAN D looking it over now studying may try to get 2 LA next sat. to do some running at cp
WILLIAM PENDERGRASS
Old 02-10-2006, 09:42 PM   #4954
carkillaii's Avatar
welcome to the family Will
carkillaii is offline   Reply With Quote
Old 02-11-2006, 05:20 AM   #4955
Default Stratus 3.1
I ve just got a Stratus 3.1 protoform and I have 2 questions:
1. What is the difference on the position of the rear wing?
What will be different in the setup if the wing gets forward or backward?
2. Should I or should I not cut the front door windows?
I am thinking about one large round hole in the front windscreen (as large as it can get without cuting the hood and the roof) and a same sized one in the back, both in the line of the engine. And that's all. (regulations don't bother me...)
I run in a tight, slippery truck and mostly in high temperature conditions (Greece though!).
Thanx for your replies dudes!!
DIA
dmastroy is offline   Reply With Quote
Old 02-11-2006, 05:58 AM   #4956
Kyosho3PKRacer's Avatar
Send a message via AIM to Kyosho3PKRacer Send a message via MSN to Kyosho3PKRacer
DIA
From memory having it forward gives it more steering and moving it back will decrease it making it smoother. You would move it forward for tight tracks but your track is slippery and very hot so i'd leave it in middle or to the rear if it don't let you put it in middle and focus more on setup rather than wing position.
Also probably good to cut out the holes in line with the engine atleast the air will go straight to it then.
I cut out circle in the front of mine so i can get to tank for fuel and air still gets to engine and then most of the rear window so i can get to hs,mr and idle needles and have a cable tie running out the back to lift fuel lid up.
I don't know the regulations about the holes i think its 55mm but no one has ever said anything so ahwell lol
Kyosho3PKRacer is offline   Reply With Quote
Old 02-11-2006, 09:10 AM   #4957
maskedrider's Avatar
anyone tried this LRP Hivolt 6.0v straight 1400mAh Rx battery ??
Just brought this baby to replace my old battery..
Any comment on how to prolong this battery or the performance ??
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 02-11-2006, 09:11 AM   #4958
Default oh boy
drop down & get your eagle on the baby has landed i will drop it like its hot on a track near you
WILLIAM PENDERGRASS
Old 02-11-2006, 11:17 AM   #4959
carkillaii's Avatar
where did you get them??
Old 02-11-2006, 08:48 PM   #4960
Default goat
1 3R IS READY FOR ACTION the storm is comming dont blink
WILLIAM PENDERGRASS
Old 02-11-2006, 08:48 PM   #4961
Got it from Toykar Singapore
Old 02-11-2006, 11:14 PM   #4962
bulletdays's Avatar
Default some problems
Hi guys,
I just wanted to know if you encounter the same problem like mine.
Ive tried to run the car for several laps, then it stops unexpectedly this happens several times. so i checked the car and noticed that you cant push back the car, it'll go forward but its locked when you try to push it back.
Is it the one way bearing of the spur gear? someone told me that may be the 2 speed shoe stacked up and it drags to the gear.
(if this subject has been tackled already can you refer me which page, if not please post your suggestions)
Thanks a lot guys...
bulletdays is offline   Reply With Quote
Old 02-12-2006, 12:06 AM   #4963
Originally Posted by Slingblade
I am moving to the San Diego area in May. I am getting a new car BUT I want to know if I can support it locally. I don't want to have to order parts online all the time. Do any of you guys know of any shops that carry the RRR wc parts. THANKS in advance.......
you've got pm!!
Dannoq1 is offline   Reply With Quote
Old 02-12-2006, 01:33 AM   #4964
It is the screw and black washer thing that holds the spur on, what you have to do is take the spurs off and unscrew the grub screw on the cam and move it further down the shaft and tighten it back up on the flat spot and install the spurs back again.
I had the same problem when i first got mine and that fixed it.
Old 02-12-2006, 01:54 AM   #4965
bulletdays's Avatar
Default Hi
Thanks a lot, you maybe right im gonna try it out, because that time when it stacked up, and i unscrewed it, then its ok..hmmm..thanks a lot and see how it goes this time..
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
