Kyosho v-one rrr
#4831
Hello all,
I have a question, i will drive this year with rubber tyres and i would like to know if i have to used the pulley 23 or 24 and if i have to use the drive belt 384 or 387 drive belt for the preponderance ??
When i drive in mousse tyre i used pulley 23 and the drive belt 384.
Does preponderacne (influe) on the mousse tyre or on rubber tyres or can I drive with the same preponderance either in mousse or in rubber ??
Thank you for answers.
P.S : sorry for my bad english
#4832
Originally Posted by Ivan Dickson
Just got my RRR WC yesterday two days later than I plan, can't wait to get home from work to start building my first Kyosho kit this evening also if any RRR owners have any suggestion on building this kit to better the car is appreicated Thanks in advance.
Ivan
Ivan
#4833
Brakes
What do you guys do to keep the brakes from dragging... if anything? Do you put springs between the pads, return spring on the arm, etc... I find that the brake arm does not return to neutral very well.
Thanks,
jag
Thanks,
jag
#4834
Thanks,
jag
Thanks,
jag
#4835
Thanks,
jag
Thanks,
jag
#4836
Originally Posted by V1-RRR-WC
The K-Factory upgrade pads come with springs to go between them. You can do what kewdawg suggested and then perhaps some ball point pen springs between the pads.
#4837
Originally Posted by kewdawg
Re-align you linkage stoppers and spring on the throttle servo mixing arm / horn.
#4838
Do you know of a place to buy K-Factory and Kawahara parts in the US?
#4839
Originally Posted by Toinou
Hello all,
#4840
Originally Posted by markp27
How was your impression of the MTX-4 in comparion to the RRR, Robert?
Cheers, Mark.
Cheers, Mark.
Both cars felt very similar....I think all the top cars are very good. I think it boils down to what you feel most comfortable driving. just my opinion.
#4841
He would probably like to take the engine out of the MTX-4 and put it in the RRR ... that RB was fast!
Robert, are you coming up to Royal Palm on Wednesday? You can help me setup my RRR. Bring Wayne and Tino with you.
jag
jag
I will be there all day sunday. By the way Yes I iwll have some ponies for the RRr come W-nats.
#4843
Do you have a part number? Do the springs last? I did this to my T-Maxx and it worked pretty good but this is a different application.
Hi JAg,
The part number is K1498. Here is the page link as well -
http://www.kfactoryracing.com/produc...1498&pageNum=1
As for being able to purchase these parts in the US, you could check Crispy Critters who is also a member of this forum.
http://www.crispycrittershobbyshop.com/store/home.php
Their contact number is 973-790-3800
#4844
Jag, I have the plugs pointing up. I just run the wires up to the reciever at the backside of the upper deck. I don't run a switch, they are too heavy. J/K, I haven't had the best of luck with switches, I just unplug the battery from the reciever. I also took a chunck of bicycle innertube and wrapped the reciever in it.
