Kyosho v-one rrr
#4681
We have K factory V1RRR Pinions. Have your dealer contact us. We also have other RRR K factory parts.
Phenix Distributing USA
(586)604-3792
(586)604-3792
#4682
(586)604-3792
(586)604-3792
#4683
Did you not just ask where to get k Factory pinions or did I miss somthing?? Sorry guess i misunderstood
#4684
#4686
Silver
After I thought about it for a minute the light did come on. I'm sure that most people don't realise that K factory makes alot of Kawahara stuff for kawahara, I would almost bet money that the pinions Kyosho and kawahara are selling are OEM'd from K factory. I can't say for a fact but I would almost bet. Funny they all came out about the same time. Hum? The deaper I get involved with the factories the more I find that the actual manufacturers making all the parts for the industry is a whole lot less than you would think.
If Genuine kyosho's yer bag, right on
#4687
Originally Posted by RANDY SMOOTH
HEY, HAVE ANY OF YOU GUYS TRYED THAT RD LOGICS TURBO 3 PIPE NO YOUR RRR. I JUST GOT ONE TO DAY. I WOULD LIKE TO KNOW HOW WELL IT WORKS. THANKS
Should you have not found that out before you went and bought one?
If you have one already it should be US thats asking YOU how it performs !
#4688
Originally Posted by tommi
Hmm...so those pinions from Kawahara do work? I just had my 16T first gear worn off, the 2nd gear ones are still in pretty much good condition; am looking for the steel pinions, does ToyKar has them? How bout the Kawahara/Skyline hop-ups, any idea who has those over here? PM me, thanks!
#4689
im keen to get some Titanium CVD's for my V1RRR, does anyone know of any?!
#4690
Originally Posted by BundyMan
Yup, the pinions work wonderfully. A little heavier than the original pinions but what the heck, been through a couple of races with these pinions and it still looks great. Local vendors do NOT stock the Kawahara pinions, got mine overseas. However, wait for ToyKar to import the kyosho hardened pinions, much cheaper than Kawahara. Check out Hobbizone/HPC they may have some hop-ups for the RRR
#4691
#4692
1) Rear shock tower
Try getting the Kawahara or Skyline ones.
2) Fuel tank
It leaks (around the joint) easily especially in a collision.
3) Brake Pulley
Wears off easily. Kyosho has already come up with an aluminium pulley. Similarly Kawahara and 3 Racing have made option pulleys as well.
4) Pinions
Get the steel ones from Kyosho, Kawahara and KFactory. The original ones wear off real fast!
These are the only items require extra attention, other than that the belts and etc last pretty long for mine
Good luck!
2) Fuel tank
3) Brake Pulley
4) Pinions
Good luck!
Hi Buddyman,
When you say "brake pulley" exactly which part are you refering too?
I just ordered a few hop ups for my new RRR WC Edition from K Factory in TW and should get them by mid next week. I ordered:
Rear Shock Tower
Front Bumper Brace
Rear Brace
Hardened Pin set
Vented Disc
Disc Pads
Aluminum Lower Shock cups
I am now reading up that the Pinions go very quickly and should also upgrade to steel. Is there an imporved ratio I should go to for a large track or is the stock ratio a good overall performer?
#4693
Originally Posted by maskedrider
Stupid me how could i forget to call Toykar which based in my country if they had stock !!!
#4694
Originally Posted by V1-RRR-WC
Hi Buddyman,
Rear Shock Tower
Front Bumper Brace
Rear Brace
Hardened Pin set
Vented Disc
Disc Pads
Rear Shock Tower
Front Bumper Brace
Rear Brace
Hardened Pin set
Vented Disc
Disc Pads
#4695
I believe he is referring to the 21T pulley on the rear spur gear shaft, just adjacent to the brake pads. This car handles very well with the stock setup, I would suggest working from everything stock, so that one will be able to know the car better. Just a suggestion since you mentioned large track, it is good to have 22T and 23T pinions handy.
I will arrange to order these as well.
Anything else I should consider one time?
