Old 01-10-2006, 12:14 PM   #4666
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by Dan D
Kawahara only makes first gear ones i can't find second. Some guy is selling them on ebay look like they are worth while. The hardened gear is not the reason because whatever kyosho makes there spurs out of it is strong. It was definatly your mesh or lack of up keep
Second gear pinion does not wear out that quickly. I'd just use the stock ones. If you run at a small track you can get hardened aluminum ones from KFactory and they will fit too. But I think the biggest they have is either 21T or 22T.
jeffreylin is offline   Reply With Quote
Old 01-10-2006, 12:28 PM   #4667
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Mugen makes steel pinions for the MTX-4 that will work on the RRR clutchbell.
Racing4Evo is offline   Reply With Quote
Old 01-10-2006, 01:50 PM   #4668
Trader Rating: 47 (100%+)
Shooter make hardened pinion from 16-24tooth.
I think you can get them as a set, or they can be brought seperate.
TOP GEAR R/C
EAST COAST HOBBIES
Craig1 is offline   Reply With Quote
Old 01-10-2006, 05:49 PM   #4669
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by RANDY SMOOTH
WERE CAN I GET THAT PIPE AND DO I HAVE TO GET A NEW HEADER WITH IT.
Try www.brooklynhobbies.com the pipe#61217R turbo3 I just spoke with him & he should be getting them in shortly & you can try ebay they always pop up. I will be getting some in soon & you don't have to change the header
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 01-10-2006, 06:05 PM   #4670
impalabob64's Avatar
Send a message via AIM to impalabob64
Default clutch-setup
hey ,markp27 bobby, here an all my rrr brothern ,im looking at josh cyrul clutch setup here is what he has 2.75mm clutch adj.end play 4mm can i get some feedback.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 01-10-2006, 06:15 PM   #4671
dodo's Avatar
Send a message via Yahoo to dodo
thanks guys, now i'm confident to give it a shot again. maybe my engine shifted slightly after a bump cos it didn't strip on the first few runs.
dodo is offline   Reply With Quote
Old 01-11-2006, 12:59 AM   #4672
tommi's Avatar
I believe Kawahara DOES make 2nd gear pinions. Look here.
tommi is offline   Reply With Quote
Old 01-11-2006, 11:18 PM   #4673
tenderfoot57's Avatar
Send a message via AIM to tenderfoot57 Send a message via Yahoo to tenderfoot57
Does anyone know what parts from the mtx-4 are useable on the rrr.
Thank You.
tenderfoot57 is offline   Reply With Quote
Old 01-11-2006, 11:30 PM   #4674
jeffreylin's Avatar
That would work for the FW05R/RR but not the V1RRR. It won't fit the RRR clutch bell and the gearing would be too tall anyway. Check here for all Kawahara parts for the V1RRR:
http://www.hikarisystem.net/kawahara...22V-one-RRR%22
Old 01-12-2006, 12:08 AM   #4675
BundyMan's Avatar
I believe the first speed pinion made for the FW05R will fit in nicely into the RRR clutch bell (used as second speed). I am currently using the KFactory hardened pinions (20T and 21T) from my FW05R on the RRR clutch bell without any problems.
In the RC World Magazine, Kyosho has already manufactured 15,16,17,20,21,22 T hardened pinions, but most shops in Japan have sold out! And it retails for 630 yen, much cheaper than Kawahara ones!
Rgds
BundyMan is offline   Reply With Quote
Old 01-12-2006, 12:31 AM   #4676
Hey guys,
I'm getting ready to buy a V-One RRR WC and I had a couple of questions.
Any of you guys run Lipo reciever packs? I've been looking into them and was wondering if any of you guys had any experience.
Also what spares should I stock up on when I buy the car? From scaning through parts of this thread it looks like I'm gonna need rear outdrives, but what else? What are the common parts that wear or get broken in a typical wreck?
Lastly, what upgrades/options should I be looking for? From what I can tell this car is pretty darn race ready out of the box, but if theres anything else that would be nice to have I want to go ahead and pick it up.
Thanks.
psbarger is offline   Reply With Quote
Old 01-12-2006, 01:31 AM   #4677
BundyMan's Avatar
1) Rear shock tower
Try getting the Kawahara or Skyline ones.
2) Fuel tank
It leaks (around the joint) easily especially in a collision.
3) Brake Pulley
Wears off easily. Kyosho has already come up with an aluminium pulley. Similarly Kawahara and 3 Racing have made option pulleys as well.
4) Pinions
Get the steel ones from Kyosho, Kawahara and KFactory. The original ones wear off real fast!
These are the only items require extra attention, other than that the belts and etc last pretty long for mine
Good luck!
Old 01-12-2006, 01:42 AM   #4678
AndyT 's Avatar
Have some spare front and rear arms.....as these can suffer if you hit barriers at the wrong angle.
As long as you dont tighten the mounting screws too tight for the fuel tank, it should be okay....I`ve still got the original in mine since February last year, it just needs the tank lid seal replaced from time to time and it`ll be fine.
Keep a few belts, spur gears, and pinions handy as spares and you should be fine.
Cheers
AndyT  is offline   Reply With Quote
Old 01-12-2006, 08:08 AM   #4679
tommi's Avatar
Rgds
Hmm...so those pinions from Kawahara do work? I just had my 16T first gear worn off, the 2nd gear ones are still in pretty much good condition; am looking for the steel pinions, does ToyKar has them? How bout the Kawahara/Skyline hop-ups, any idea who has those over here? PM me, thanks!
Old 01-12-2006, 09:58 AM   #4680
Rgds
Do you have the part # for the hardened pinions? I really want to get these. Any ideas where I can find them in US? thx.
silverM3 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
