Old 01-05-2006, 01:15 AM   #4591
markp27's Avatar
Send a message via ICQ to markp27
Originally Posted by 710baby
C'Mon don't be that cruel
It shows 0mm front & rear on the stock set up
but some drivers might put a 2mm spacer in the rear for high bite tracks similar to Josh cyrul's set up for Toledo GLC
Oh you can ignore Sow&Steady without any problems - he's my evil twin Bro
I still don't know what this spacer is though. The knuckle arms seem to be the steering blocks, and there seem to be three different kinds of these 0, 1 and 2 degrees - but what about this spacer? Where should the spacer go? Do they really mean the wheel spacer - which is how it is named for the rear of the car?
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 01-05-2006, 01:19 AM   #4592
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by wad
Hey Jeff!! Are you racing this weekend?
Yes! Walter are you running 1/8 or 1/10?
jeffreylin is offline   Reply With Quote
Old 01-05-2006, 02:00 AM   #4593
rfy
Hi Guys,
Anybody know how the 0, 1, 2 degree knuckle arms differ in handling
rfy is offline   Reply With Quote
Old 01-05-2006, 02:10 AM   #4594
B4
B4's Avatar
Originally Posted by rfy
Hi Guys,
Give you a wider range for the caster setting.
B4 is offline   Reply With Quote
Old 01-05-2006, 08:27 AM   #4595
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by markp27
Guys what is the knuckle arm spacer which is denoted on the setup sheet?
Cheers, Mark.
I think that's the caster clip.
Racing4Evo is offline   Reply With Quote
Old 01-05-2006, 08:37 AM   #4596
markp27's Avatar
Good point - that must be it! Thanks mate!
Old 01-05-2006, 09:51 AM   #4597
V1-RRR-WC's Avatar
Hi Markp27,
I will be getting my kit tomorrow (my first build) and have gone over the online manual many times and made my notes before hand to make sure I understand everything. These caster clips you speak about, what page of the manual is it on?
Also, on the very first page, it mentions "After inserting both (163) to (16) and (17), apply instant glue"
I assume they mean to CA glue the O'rings on each side of the diff housing, is this correct???
I ask, because I did not see the actual symbol for CA glue specifically illustrated here.
Any repsonse would be greatly appreciated.
V1-RRR-WC is offline   Reply With Quote
Old 01-05-2006, 10:38 AM   #4598
markp27's Avatar
It is a wise decision to understand everything fully before assembling a car for the first time. Also remember to take your time with the build process, as the better you build the car the less problems you will have later and the better your car will perform.
If you have a look on page 5 of the manual "Arrangement of plastic parts on runners", the item in the top left-hand corner has the caster clips attached to it. The two clips are shown as piece number 27. You attach the caster clips in step 6 of the assembly procedure.
With the original RRR, which I built just over a year ago, I found that there weren't enough caster clips supplied with the kit to remove all the play from the front upper suspension arm, so you may have to get some from another kit - I got mine from my Xray or Serpent 710, as you can buy the caster clips on their own with those two kits.
Maybe the RRR WC doesn't need extra clips though.
I wouldn't do that to be honest. I've no idea why the instructions are telling you to apply CA glue there - I would only ever use a silicon sealent on those parts (i.e. the edge of part 16). You really don't want to be gluing the Diff with CA as you will never get it apart again - the diff oil plays a very important role in the car setup and therefore you will need to change it to suit different track conditions.
Hope that helps.
Cheers, Mark.
Old 01-05-2006, 12:27 PM   #4599
V1-RRR-WC's Avatar
Hi Mark,
Yes, a great help. I just realized how stupid the question was though. Off course I know the caster clips. I think I am just very anxious and excited about getting it tomorrow.
As regards the diff, I do not think they are reffering to sealing the diff closed, but glue to hold the outer seals in place.
Should I use a lighter glue or nothing at all?
Thanks for the help so far.
Old 01-05-2006, 01:27 PM   #4600
markp27's Avatar
I wouldn't use anything there to be honest, as long as the rubber seal stays in place ok. I'm sure I didn't glue it on my RRR.
I haven't started building my RRR WC yet, as I've come down with a really bad cold
Hi Mark,
Old 01-05-2006, 02:01 PM   #4601
Sow&Steady's Avatar
sorry, couldn't help it. when I saw his post, I remembered how he can't see anyway so why would it matter. He borrowed my telescope and lost it. Then he borrowed by microscope and broke it ... of course, even if you give my Bro a 1 foot thick disc he won't be able to see it.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 01-05-2006, 02:03 PM   #4602
Sow&Steady's Avatar
Cheers, Mark.
See .. now not only he can't see it, he won't remember either.
Old 01-05-2006, 03:58 PM   #4603
markp27's Avatar
Remember what?
Old 01-05-2006, 06:19 PM   #4604
GMartinez's Avatar
Trader Rating: 85 (100%+)
It was just to funny good one though
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 01-05-2006, 06:22 PM   #4605
GMartinez's Avatar
Originally Posted by Motorman
We now have K factory RRR options in house for the USA. have your dealer contact us.
What's up Dennis are you referring to Rdlogics or is this another company you are talking about
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
