Kyosho v-one rrr
#32
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally posted by pramac
Team RTR, here is one of the english setup sheets.
#33
I don't know if anyoen has every checked their tanks for leaks but 3 people I know have experienced a leak at the seam in the front right of the tank near the mounting hole. Just wanted to give a heads up.
#34
#35
#36
Yokomo had a similar issue along with a faulty tank lid when the GT-4 was introduced. What you did was send it in and they would send you back a revised replacement. I don't know what owners outside Japan can do since it has only been distributed in Asia. When it comes to the United States, the tank will be fixed.
#37
I noticed the very tight front arms and also tight rear arms. I used a 3mm drill bit and ran it carefully through the hinge pin holes so the bit was running through both holes at the same time. this freed it up nicely and didnt make it sloppy at all. Do it carefully once and then reassemble and check and do again if you need to. There was also some flashing on the arms that was binding a bit and i filed that of to make it smooth. You can use a shim to stop that upper front arm play.... I filed down some 1mm castor clips to about .4mm and used those instead as it made it easier to change the castor.
#38
Originally posted by doki_doki
thanks for that very helpful information guys...still waiting here in the Philippines when will this kit arrive. am already excited to get one...
#39
Originally posted by buboy28
doki doki, TENG of MANILA HOBBIES will be bringing it by the middle of October when i first inquired it was to be for the last week of september apparently they might have been some problems regarding the shipping. i'm also going to get one if they finally arrived here
#40
what tires come with the v-one rrr kit??? does it come with foam or rubber tires??? which engine is a good match for this kit???
#41
the car comes with 35 shore foam tyres as standard.
#42
#43
it includes a front oneway
#44
that's good news bro..keep me posted when it arrives though... would you happen to know how much it costs???
#45
