Old 12-18-2005, 09:14 PM   #4426
rowveg36's Avatar
Trader Rating: 21 (100%+)
guys w/c oil diff gives you more rear grip, lighter or heavier? i'm using one way on the front. thanks for the info:
rowveg36 is offline   Reply With Quote
Old 12-18-2005, 10:06 PM   #4427
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Lighter oil will give you more grip.
Walter Diaz
wad is offline   Reply With Quote
Old 12-19-2005, 04:27 PM   #4428
Are the titanium differential bevel shafts worth getting?
The standard ones weigh a ton !!
VZW211 64-grade Titanium Bevel Shaft
Cheers
rcrossco_1 is offline   Reply With Quote
Old 12-20-2005, 06:12 PM   #4429
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I just doubled up the rear shock tower, I did break a couple of them last week. It is a ton stiffer than the single tower though, do you guys run a softer spring when running the thicker towers or double towers.
Old 12-20-2005, 06:28 PM   #4430
jeffreylin's Avatar
R/C Tech Charter Subscriber
Cheers
I think anytime you can reduce rotating mass in the drivetrain is a good thing. I also uses the hollow middle shaft, the titanium 2 speed shaft, lightweight flywheel and clutch bell. The only thing I did use that added weight is the steel first speed pinion. The stock one just wears out too quickly.
jeffreylin is offline   Reply With Quote
Old 12-20-2005, 06:31 PM   #4431
jeffreylin's Avatar
Randy, most people use the same springs. I use the skyline 4mm shock tower and the package gives you a couple of shims so that you can mount your shock bottom a bit out to preserve the original shock angle geometry.
Old 12-20-2005, 06:51 PM   #4432
Jeff,
I agree. Are all the parts you labeled Kyosho? I do have the lightweight clutchbell. If so, where can I get the rest of them?
CHUCKMANDO is offline   Reply With Quote
Old 12-20-2005, 07:17 PM   #4433
jeffreylin's Avatar
Originally Posted by CHUCKMANDO
Jeff,
All Kyosho parts:
hollow middle shaft VZ227
titanium 2 speed shaft VZW209
lightweight flywheel VSW043
clutch bell VZW213
titanium bevel shaft VZW211
Old 12-20-2005, 08:33 PM   #4434
wad
wad's Avatar
Who makes those steel pinions?
Walter Diaz
Old 12-20-2005, 08:36 PM   #4435
ogreasurada's Avatar
http://www.rckenon.com/public_html/s...hp?cPath=64_97
ogreasurada is offline   Reply With Quote
Old 12-20-2005, 08:39 PM   #4436
wad
wad's Avatar
Originally Posted by ogreasurada
Thanks!!
Walter Diaz
Old 12-20-2005, 10:47 PM   #4437
jeffreylin's Avatar
Kawahara:
http://www.kawahara-racing.co.jp/
Old 12-20-2005, 11:16 PM   #4438
I was just going to ditch the 2mm spacer on the upper shock mount and use a .7mm spacer instead, should keep the same geometry that way.
Old 12-21-2005, 04:54 PM   #4439
Just finished building the kit this morning. But I've got two questions to ask,
1. Which way does the outer gear mount, with the tubes on one side facing outwards or inwards?
2. Which engine should fits this car without the manifold rubbing or how do I fix this problem?
thanks
theBUZZ is offline   Reply With Quote
Old 12-21-2005, 05:07 PM   #4440
It mounts with the number of teeth showing towards the outside.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
