Kyosho v-one rrr >
Kyosho v-one rrr
Kyosho v-one rrr
Old 12-09-2005, 03:12 AM
  #4366
Trader Rating: 49 (100%+)
Originally Posted by rcrossco_1
Your car looks like its been wired up by a chimpanzee.
Ive never had switch failure, maybe thats because I look after my car/s.
Heres some real wiring.............
Later....... enjoy crashing.
I don't want to interupt with the arguement there but crashing is something Kyle doesn't do a lot of and as for car prep, you'd go a long way to find someone better.
I'm glad that you have never experienced a switch failure, the car being turned off due to a collision or a marshall inadvertantly turning your car off when he tries to do his job. But I have and so have a lot of other people I know who now don't use a switch as it just eliminates one more thing that can go wrong.
I wish I could trust a switch as it would be convenient but you learn from your mistakes, so no switch.
Craig1 is offline
Old 12-09-2005, 09:45 AM
  #4367
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Francis M.
for crystal it should be a good starting point with rev you will probably have to go to harder tires around this time with the cold weather.
I'll have the right tires for both tracks, basically just wondering how good the setup is..
Randy Caster is offline
Old 12-09-2005, 09:52 AM
  #4368
Francis M.'s Avatar
sorry, misread the post the RRR kit setup shouldn't be too far off for both tracks. the only thing you would probably want to adjust is the droop settings. flatter for rev and oposite for crystal.
Francis M. is offline
Old 12-09-2005, 10:27 AM
  #4369
Racing4Evo's Avatar
Francis is right, droop is the most drastic change between the two tracks. You want a lot of droop at Crystal. I was running 1 in the rear and -1 in the front last time at Crystal Park.
Racing4Evo is offline
Old 12-09-2005, 01:23 PM
  #4370
jeffreylin's Avatar
Randy when are you going to come race at Revelation?
jeffreylin is offline
Old 12-09-2005, 03:49 PM
  #4371
AndyT ©'s Avatar
I`ll second that.....I`d rate Kyle up there in the top echelon of racers in this country and you dont get to that level by not having an understanding of how to wire/setup/ etc etc a car.
Cheers
AndyT © is offline
Old 12-09-2005, 11:49 PM
  #4372
wad
wad's Avatar
Originally Posted by dragonal
Wad
i wait the kit and don't know the number of teth on rear differential...but
not think only 22....
Bye
Sorry, I meant 42
wad is offline
Old 12-10-2005, 05:19 AM
  #4373
Cheers
Ok guys, no problems.
But there are others in this world too that know their stuff !
As with most stuff in life.... its each to thier own.
Ross
rcrossco_1 is offline
Old 12-10-2005, 04:57 PM
  #4374
Bundy_Bear's Avatar
Hey Guys...
Couple of questions for you today
1st... I am using a Futaba 9550 low profile servo for the steering and i have used the 1mm spacer behind the servo. I noticed today that at the end of the travel the servo horn seems to rub on the top deck??? Should i have used the 2.5mm spacer instead?
2nd...
As i am going to be running on rubbers tyres, i have changed the front pulley over to the 24T with the corresponding belt... But it is very loose, and i am worried about it skipping.
Look forward to seeing some responses..
BB
Bundy_Bear is offline
Old 12-11-2005, 01:54 AM
  #4375
BrainTeased's Avatar
Originally Posted by Bundy_Bear
Hey Guys...
2nd...
BB
Hey bundy bear
i have used both futaba s9550 and s9451 and the 2.5 mm spacer works best as it gives enough clearance from the top deck opening.
i to am using the 24T side pulley but i run foams and i use the 387T belt and although it does seem abit loose but really its fine as when the car is being acccelerated the belt actually tensions as it rotates. Some will tell you to run the side belt as loose as possible to free up the car, a more efficent drivetrain equals more top speed, better fuel economy and lower engine temps
BrainTeased is offline
Old 12-11-2005, 02:50 AM
  #4376
spawn's Avatar
Originally Posted by tommi
Thanks again, I just tried driving with the stock setting at Glenmarie yesterday night, the track wasn't 100% dried after a light drizzling, but the car handled great. Will try out different setups thru time, but at the moment, based on the outcome of my run yesterday, I gotta stick with the one-way for a while to figure out the best setup and the dynamics of it. Are u still with the NTC3?
Yup, still with my NTC3. Still working well for me. Tips, when driving 1 way, brake earlier and also power out earlier. Dont pump the gas like pink, do it smoothly and very importantly to take good racing line. Before running in a race, walk around the track or plan your racing line before racing.
spawn is offline
Old 12-11-2005, 03:02 AM
  #4377
Team-RTR's Avatar
hey people, i got my RRR for sale for anyone interested, have a look cause its pretty cheap!:
http://www.rctech.net/forum/showthread.php?t=93435
Team-RTR is offline
Old 12-11-2005, 02:49 PM
  #4378
Smile
hello out there, this is victor from madrid-spain, this is my first post and i want to say hi to all you, so, i want to know where i can to find the
K FACTORY optionals parts for my RRR:
http://www.kfactoryracing.com/prolis...01120805-97109
these parts are hard to find here in spain, please if anybody got these optional parts, let me know where found them, wich shop ?
thats all for the moment, thanxxxx
tifosi_es is offline
Old 12-11-2005, 08:06 PM
  #4379
fritzD's Avatar
try rcmart.com or shopping.rcmodel.hk
they ship anywhere around the globe and they're the cheapest place you can find hop-ups for Asian products.
fritzD is offline
Old 12-11-2005, 09:54 PM
  #4380
tommi's Avatar
Actually I was quite worried about driving one-way on belts with antiroll bar for the first time...never had the experience of driving on one-way and arb when I was with my NTC3. But last Thursday I got the chance to run the RRR properly at Glenmarie, the results was very satisfying. Before that run, I actually practised driving with the one-way on VRC... ...it helps! I managed to follow the pace of Chua and Pink on that track, which was also my very first time running there...the car IS good!
tommi is offline
