Old 12-08-2005, 04:34 AM   #4351
JustRace's Avatar
Originally Posted by markp27
Hey Bobby,
How you doing?
Guess which car I'm running now
Cheers, Mark.
Let me guess...hmmmm...RRR?
JustRace is offline   Reply With Quote
Old 12-08-2005, 05:48 AM   #4352
impalabob64's Avatar
Send a message via AIM to impalabob64
Default markp27
hey mark what,s going how are things you gettin ready for the nats. my rrr is doing pretty good ,im running the new maxxpower ,trying to dable with 40% nitro just alittle .hope to get some practice in this weekend so i be ready for you
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 12-08-2005, 04:35 PM   #4353
Originally Posted by Kyle Hazell
Thanks for the tip big boy....
Clearly we can all see your a racer with a wealth of experience and have never experienced the mighty runaway after a crash when the switch has turned off. I guess maybe you dont crash, so its not a problem or have plenty of money because usually it takes the engine as well just to make sure you rememeber the experience. Gas racings a harsh environment as well, switches fail from time to time.
Good luck with your switch, make sure you let us all know when you experience the mighty runaway.
Attached is a pic of what i meant when i said to plug in direct to the reciever.
Regards
Kyle
Your car looks like its been wired up by a chimpanzee.
Ive never had switch failure, maybe thats because I look after my car/s.
Heres some real wiring..............
Later....... enjoy crashing.
rcrossco_1 is offline   Reply With Quote
Old 12-08-2005, 05:27 PM   #4354
Default Ball differential
anyone know what ball diff is possible to fit on V-one ? some people ask me the TM G4 .....
dragonal is offline   Reply With Quote
Old 12-08-2005, 07:41 PM   #4355
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Is the WC kit setup with the correct tires a good starting setup for Crystal Park and Revelation?
Old 12-08-2005, 08:22 PM   #4356
Francis M.'s Avatar
for crystal it should be a good starting point with rev you will probably have to go to harder tires around this time with the cold weather.
Francis M. is online now   Reply With Quote
Old 12-08-2005, 08:31 PM   #4357
Francis M.'s Avatar
[QUOTE=tommi]So I guess your advice will be..."Don't bother trying out one-way at Monacoria Speedway?"
tommi from your first question i noticed your running foam tires on concrete. I don't think foam tires work that well on concrete. you might want to try rubber tires for concrete and foams for asphalt.
Old 12-08-2005, 09:30 PM   #4358
spawn's Avatar
Racing4Evo, thanks heaps for the clarification!
Yup, in fact if there is a lack of grip you should try driving with solid front. I think your kit should include the front solid insert to convert the front diff to solid. I used front solid with pretty good results esp during the race using the full track of titi. Try it out and you might like it. However the racing line is slightly different than normal, early braking, early power out and its extremely stable.
spawn is offline   Reply With Quote
Old 12-08-2005, 09:47 PM   #4359
Trader Rating: 13 (93%+)
Default what ackerman plate to use with solid front ??
hey guys
what ackerman plate are you guys using when running the front solid diff ?
i want to use the solid on a short technical track and wanted more steering
thanks
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 12-09-2005, 12:04 AM   #4360
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
TM G4 diff will not fit; it has 48 teeth vs 22 on the RRR
Walter Diaz
wad is offline   Reply With Quote
Old 12-09-2005, 12:08 AM   #4361
wad
wad's Avatar
Originally Posted by mrgsr
hey guys
thanks
If you are looking for more steering, go to the 12 ackerman
Walter Diaz
Old 12-09-2005, 01:38 AM   #4362
Wad
i wait the kit and don't know the number of teth on rear differential...but
not think only 22....
Bye
Old 12-09-2005, 03:07 AM   #4363
AndyT 's Avatar
hey guys
thanks
I ran the standard #11 ackermann at the Winternats (Fairy Meadow) this year with a solid front diff....i was quite pleased with it
AndyT  is offline   Reply With Quote
Old 12-09-2005, 03:09 AM   #4364
tommi's Avatar
Yup I'm running foam tires on concrete. I was running on this concrete track for the past 2 years with my NTC3 with great success, but I wasn't running any arb and was with diff all the time, so i guess i might just have to revert back the setup on my RRR to some sorta similar setting to my NTC3. Having just acquired the RRR, it's also my first time on belts, on arb, and on one-way; so it will just take some time for me to get use to everything i think. Thanks for the input!
tommi is offline   Reply With Quote
Old 12-09-2005, 03:17 AM   #4365
tommi's Avatar
Thanks again, I just tried driving with the stock setting at Glenmarie yesterday night, the track wasn't 100% dried after a light drizzling, but the car handled great. Will try out different setups thru time, but at the moment, based on the outcome of my run yesterday, I gotta stick with the one-way for a while to figure out the best setup and the dynamics of it. Are u still with the NTC3?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
