Old 11-30-2005, 11:04 PM   #4306
tommi's Avatar
dodo, Timox, BrainTeased, Racing4Evo, thanks a lot for you guys' inputs, appreciate it. You guys are right, it's all about getting the right tool for the right job. Bizzarre is that 3 out of 3 philps screwdrivers I had in my rc toolbox did not do the job well, and was I laughing when I looked into my dad's old toolbox yesterday night, found and fetched out a philips screwdriver, and it does the job WAY better than the rc tools i had! And that driver only cost less than 1USD!
tommi is offline   Reply With Quote
Old 12-01-2005, 12:04 AM   #4307
dodo's Avatar
Send a message via Yahoo to dodo
see.... good that you haven't spent money on HUDY tools... now you have more to spent on other parts...
dodo is offline   Reply With Quote
Old 12-01-2005, 03:35 AM   #4308
BrainTeased's Avatar
Originally Posted by jeffreylin
Randy, other than the rear shock tower, I'd order some rear uprights, rear arms, hinge pins, belts and gears. If you are building the car, I would also strongly recommend that you use the evolva harden pivot balls (may already been included in the WC). They weight the same but much tougher than the stock ones.
hi Jeff are the evolva harden pivot balls the black coated ones?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 12-01-2005, 04:44 AM   #4309
etgdpu's Avatar
I would recommend the kyosho tools. Since I bought them I did not destroy or have problem with any screw. Expensive though. What you really need for RRR is philips +1 and +2, hex 1.5, 2.0 and 2.5. All the rest type of screws do not request this high quality tools. They cost about $20-$30 each, so about $150 all together. Their code starts with the ykw, i.e. ykw006.
etgdpu is offline   Reply With Quote
Old 12-01-2005, 05:09 AM   #4310
tommi's Avatar
...there are more advice I need from you guys... The deal I had is quite a good one, it's a WCE which the owner had already further upgraded it with Boca ceramic bearings.
That aside...I had already did a search in this thread about the springs...the shorter, less coil spring is stiffer (which is to be used on the front as stated in the manual), while the longer more coil (softer) to be used on the rear...correct me if I'm wrong? I'm thinking...could I use the SHORTER for the REAR and the LONGER for the FRONT? My concern is that besides the INTENDED difference in spring stiffness by using the LONGER one for FRONT and SHORTER for the REAR, are there any other effects of doing that?
Another thing, just to make sure...(as this is quite a whole new area for me to explore jumping from a simple shaft driven car to a much more complicated belt car... )...I already have a diff housing and the solid adapter, what else do I need to have a front solid? Is a diff joint all I need? Any other that I need? Screws? Nuts? Pins? Thanks again!
Old 12-01-2005, 05:15 AM   #4311
tommi's Avatar
Thanks for the heads up!
Old 12-01-2005, 09:40 AM   #4312
jeffreylin's Avatar
R/C Tech Charter Subscriber
Yes. They are fantastic and they never break. I've had the regular ones bend or break all together on my FW05RR and RRR. Once I swithed to the black one I haven't had one problem yet.
jeffreylin is offline   Reply With Quote
Old 12-01-2005, 05:33 PM   #4313
AndyT 's Avatar
[QUOTE=tommi
Another thing, just to make sure...(as this is quite a whole new area for me to explore jumping from a simple shaft driven car to a much more complicated belt car... )...I already have a diff housing and the solid adapter, what else do I need to have a front solid? Is a diff joint all I need? Any other that I need? Screws? Nuts? Pins? Thanks again! [/QUOTE]
If youre going to run a solid front diff....i`d highly recommend getting the 3-Racing solid axle adaptor....its aluminium and wont strip like the plastic one thats included with the kit.
You`ll need a pulley to fit the front solid....its the same as the one on the front one way, but its fitted with out the side glued on (this allows clearance).
You`ll also need the screws to hold the diff casing together, and spacers for the servo saver to allow the diff to clear it.
Cheers
AndyT  is offline   Reply With Quote
Old 12-01-2005, 05:54 PM   #4314
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Agreed, the black ones are indestructible from my experience.
Racing4Evo is offline   Reply With Quote
Old 12-01-2005, 07:23 PM   #4315
Can you plz provide the part number ? thx a lot
silverM3 is offline   Reply With Quote
Old 12-01-2005, 07:30 PM   #4316
dodo's Avatar
i think it's fm337
Old 12-01-2005, 07:32 PM   #4317
i tried couple shops and cannot seem to fm337.
Old 12-01-2005, 09:57 PM   #4318
dodo's Avatar
hmm strange... but pretty sure it's the correct product code....
Old 12-01-2005, 10:21 PM   #4319
jeffreylin's Avatar
It is FM337
Old 12-01-2005, 10:55 PM   #4320
freefallmarine's Avatar
Who make's good aftermarket wheel hex's for the RRR with 1 to 2mm offset's?
i would like to get some for the rear wheels.
freefallmarine is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
