Old 11-30-2005, 03:22 AM   #4291
dodo's Avatar
Send a message via Yahoo to dodo
Originally Posted by tommi
Hi guys, need some advice here. I just got my WCE RRR from a local racer. Have been running the NTC3 for 2-3 years, I've to admit it was quite a leap for me to own this baby, it's soooo much complicated than the NTC3, looking forward to a pleasant experience with the RRR.
However, I find it a bltch to wrench with the philips head screws. I was wondering, was it me or was it because of the screws? I was using a Mugen philips screwdriver, but those screws are making me go nuts...and I'm thinking, should I get a screwdriver of "ultimatest quality" - HUDY, or I'm thinking of changing all the screws into hex screws/allen (possible to do so?)? Need advice! Thanks heaps!
would be nice if you can get hex screws, and upgrade it to Titanium ones
anyway, mugen tools should be quite good, if you don't find it comfortable using philips head, then i suggest you change it to hex screws. buying hudy tools won't help much if you hate philips head screw in the first place.
my 2 cents
dodo is offline   Reply With Quote
Old 11-30-2005, 04:48 AM   #4292
Timox's Avatar
Well i like philips head screws better than hex head..... I just use any good screw driver from the local hardware store of the right size and works fine for me I find hex heads strip out the head too easy ( the small ones anyway).
But i think the main thing is to get the right size driver. Doesn't matter about quality of the driver. Get the size right and you will be laughing
Timox is offline   Reply With Quote
Old 11-30-2005, 05:42 AM   #4293
BrainTeased's Avatar
i know exactly how you feel! as sometimes with philips head screws you have to really apply alot of pressure. where as hex screws you can just put it in place and turn.
but if you want to make life easy with philips head screws go buy yourself a cordless screwdriver! it will make life alot easier with screwing screws in and unscrewing them out!
if you worried about the torque that these units apply to the screws you could try and find those hobby type ones that are only operated at 3.6 volts not the standard trade type which are operated at 12-14 volts and in some cases they can come in 24 volts.
hope that helps
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 11-30-2005, 05:43 AM   #4294
Bundy_Bear's Avatar
Originally Posted by AndyT
The front diff uses the same size pulley as the one way.....you dont however glue the side to the pulley on the diff (as is required for the one way) or else the diff wont have enough clearance to fit.
VZ203 is the part number for the Pulley Set...... its probably easier to get a new pulley than to try and force the side off the one way pulley.
Cheers
AndyT: Thank you... I have always found the support for Kyosho to be good on R/C-Tech, shame the same couldn't be said about Dawn Trading
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 11-30-2005, 06:29 AM   #4295
Tim Johnson's Avatar
Originally Posted by mgtman
i should be done building it very soon ,just the holidays got me backed up a little ,got to tend to the wify a little ,some of you know what i mean. just bought the os tz 5 port, 2 3305 servos a vantage pipe and getting a pro paint job done as we speak so im figuring maybe by this thursday or earlier ill have it done and will post some pics .thought of a lot of cars but since im a big kyosho fan had to stick with this one and now they came out with the wc kit so i nabbed it and my sp2 cost me well over 2g here she is and both cars are going to be strickly for the track (been racing for years ) and are going to be shelf queens till april got my bashers anyway
I have seen your 777 somewhere......I wonder where.
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 11-30-2005, 08:51 AM   #4296
Randy Caster's Avatar
Trader Rating: 46 (100%+)
What's up guys, I'm just wondering if any parts on the RRR are more prone to breakage than others?
Old 11-30-2005, 09:04 AM   #4297
jeffreylin's Avatar
R/C Tech Charter Subscriber
What's up Randy--are you going to get a nitro car? Hope to see you at Revelation or Crystal Park.
The only part that is relatively weak is the rear shock tower. It can break in a roll over accident. You can get a Skyline one that is thicker (4mm) and it will never break again.
Skyline web site is:
http://www.skylinercracing.com/
jeffreylin is offline   Reply With Quote
Old 11-30-2005, 09:24 AM   #4298
I gotta stick with Kyosho stuff for now, but I'll be sure to order a few of them, thanks Jeffrey.
Old 11-30-2005, 09:40 AM   #4299
jeffreylin's Avatar
Did you get a ride with Kyosho? Come out to Revelation next Sunday (12/11) if you can, I will be there.
Old 11-30-2005, 10:19 AM   #4300
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
A lot of people have problems with the phillips screws because they don't fit properly into the screw head. Even though you may get the screw out, if it requires a lot of force then the screwdriver is the wrong size. Take one of the screws with you to the hardware store or walmart and find the right screwdriver. The correct size won't have any slope, and wrenching on your car will be a breeze afterwards. The Hudy screwdriver is really nice and fits perfectly as well.
Racing4Evo is offline   Reply With Quote
Old 11-30-2005, 12:21 PM   #4301
No, just was wondering what parts to order is all..
Old 11-30-2005, 12:41 PM   #4302
kewdawg's Avatar
The car's tough as a TANK! I still crash, every now and then, and the few crashes I've had would easily render others car completely in-operative (I drive extremely fast! ). I went almost an entire season before breaking one steering knuckle and one front suspension arm. I didn't even notice the breaks while I was driving! Pretty good, huh? Just get the basics: steering knuckles, suspensions arms, hinge pins, bumper parts and body posts. Throw in some spare belts for good measures. You don't need much, at all.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 11-30-2005, 01:23 PM   #4303
jeffreylin's Avatar
Randy, other than the rear shock tower, I'd order some rear uprights, rear arms, hinge pins, belts and gears. If you are building the car, I would also strongly recommend that you use the evolva harden pivot balls (may already been included in the WC). They weight the same but much tougher than the stock ones.
Old 11-30-2005, 06:11 PM   #4304
AndyT 's Avatar
Spare belts, spur gears, arms, and hinge pins are handy to have
I also keep a spare thrust bearing.
Cheers
AndyT  is offline   Reply With Quote
Old 11-30-2005, 09:00 PM   #4305
randy
Airtronics|Kyosho|
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
