Old 11-14-2005, 04:27 AM   #4186
Timox's Avatar
Tho I dont have a RRR, but to my understanding, your camber and toe in settings seem a little too aggressive for the track you are running. Unless its super high bite surface, or else too much toe-in can cause unstable action during take-off and low-speed movement, like the cases you described. You can also check the rear sway bar setting. Hope this may help.
The camber is set so the tyres wear evenly. The toe of 3* is to try and gain some rear traction. There is a LOT of camber change on this car through its suspension travel. Makes it hard to use the camber you want with foam tyres.
Should i be looking at the front end of the car instead? And try to reduce steering/traction at that end to balance out the car?
The track is really bumpy and all cracked up. Not much traction and a lot of tyre wear with 37 rears. I wouldn't like to go any softer. They wouldn't last 10 minutes.
Timox is offline   Reply With Quote
Old 11-14-2005, 02:01 PM   #4187
ogreasurada's Avatar
I think you mentioned that the car understeers at high speed, that seems the front should not have enough over steer to cause fish tail. Maybe you can try using thinner diff. lube for rear diff. such as 10k? Cuz I think 30k may be too stiff for low traction tracks. If you don't want so much suspension travel you can also try harder strings or move the rear shocks to upper holes for more progression. Just my little thoughts. Actually I think jeffreylin's post (scroll up a few posts) had stated all these already.
ogreasurada is offline   Reply With Quote
Old 11-14-2005, 02:05 PM   #4188
Originally Posted by MRX_joe21
just out of curiousity, wouldnt this part stiffen up the rear end. i thought stiffen up the rrr, it didnt run as well. for example if you put a 4mm chasis on this car, it didnt handle as well.
Joe Chaplow is offline   Reply With Quote
Old 11-14-2005, 02:06 PM   #4189
Originally Posted by jeffreylin
Personally I think the Mazda 6 is the most stable body at high speed and gives good overall steering.
jeff,
you try the new stratus? if so, what did you think about it with the rrr?
Old 11-14-2005, 05:54 PM   #4190
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by joemugen
jeff,
Hey Joe, I have not tried it because the Mazda 6 works so well. Once I went to Crystal Park with my friend Alex for some practice. We both had the RRR but he had the Stratus body on. For some reason, he couldn't keep a clean lap and kept hooking at the sweeper. Then he tried it with my Mazda body and his car worked immediately. He threw away the Stratus body right there on the spot.
jeffreylin is offline   Reply With Quote
Old 11-14-2005, 06:04 PM   #4191
AndyT 's Avatar
Originally Posted by Racing4Evo
I recommend the Stratus 3.1 It's really stable and aggresive at the same time. The only situation where it isn't that great is HIGH bite in which case the Mazda is the best.
Yep, on a low-medium traction surface, i`ve found the Stratus 3.1 to be very good.....more stability in hi-speed sweepers than the Mazda 6 and appeared to have less push on power.
AndyT  is offline   Reply With Quote
Old 11-14-2005, 06:11 PM   #4192
AndyT 's Avatar
I think it`ll stiffen up the rear of the car to some degree, but i doubt if it`ll have the same affect on the handling of the car as fitting a 4mm chassis.
It`ll be interesting to see what/if any other parts K-Factory have in the wings for the RRR.
Cheers
Old 11-14-2005, 09:40 PM   #4193
thanks, i think the mazda 6 is best for the rrr too.
Old 11-14-2005, 09:59 PM   #4194
MRX_joe21's Avatar
Send a message via Yahoo to MRX_joe21
Its better not the best...
MRX_joe21 is offline   Reply With Quote
Old 11-14-2005, 10:32 PM   #4195
Timox's Avatar
When putting oil in the diff do you fill it compleatly full to the brim or only half full?
Old 11-14-2005, 10:36 PM   #4196
jeffreylin's Avatar
Half full, just enough so that the oil covers the bevel gear shafts.
Old 11-14-2005, 11:16 PM   #4197
Trader Rating: 13 (93%+)
Default no droop when running small tyres on the rear
hey guys
noticed something interesting this weekend..
when your running low tyres, you compress the spring by the adjuster so that you can get ride height back, when i was running 5.5mm ride height and say 58-60mm tyres i had no droop
when i switched to a longer shock end it was fine
is this normal ? i built the car with the small ball ends as it say sin the book, what have you guys done to overdone this.
thanks
JOhn
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 11-14-2005, 11:21 PM   #4198
jeffreylin's Avatar
Originally Posted by mrgsr
hey guys
thanks
JOhn
This is normal. When you run really small tires you need to increase your droop. If your shocks are not long enough you need to increase the shock length by twisting the ball ends out a bit or use the longer ball end. However, even the medium ball end could be too long so I cut about 3-4 mm off.
Old 11-15-2005, 05:06 AM   #4199
geeunit1014's Avatar
i am looking to get this car for xmas. are there any parts prone to breaking more often thean others like the rear shock tower on the mtx4 does?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 11-15-2005, 05:29 AM   #4200
Timox's Avatar
Only thing i have broken or worn out are the belts and pullies. But thats mainly because of all the little rocks and stuff on the track.
Tyres....Lots of tyres
Get the 4mm thick shock towers if you like. It wont hirt. Just dont bother with a 4mm chassis. The 3mm works better.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
