Old 11-03-2005, 08:12 PM   #4141
dodo's Avatar
Send a message via Yahoo to dodo
Originally Posted by CHUCKMANDO
Is anyone expirancing oil coming out of the caps on top? I replaced everything ,bladder, blue cap and eyepiece. It has to be something I am doing wrong. It is slow, but there. I am almost at the point of trying mugen or associated shocks.
Tks
may I know how you built your shocks? i had the same problem before and seems that the cause was too much oil in the shocks. now i put the bladder and press it down until the oil 'bleed' out then screw the cap. works fine for me.
dodo is offline   Reply With Quote
Old 11-03-2005, 08:17 PM   #4142
MRX_joe21's Avatar
Send a message via Yahoo to MRX_joe21
Originally Posted by deviltires
WHAT CAMBER AND TOE WORKS GOOD ON THE 3R IN THE REAR
Depends on the Track Layout surface and the way you drive too. But a good starting point. Just use stock setup for a while. If you dont like it change it one at the time. Aight fellah.
MRX_joe21 is offline   Reply With Quote
Old 11-03-2005, 08:23 PM   #4143
Ah, maybe that is it. Basically, I fill up to almost the top, I put the bladder in the cap, and screw on pretty slowly at first, as so to bleed it a little. Then check the rebound when done. If they are close its a go. I am too used to my ntc3 shocks I guess, with no bladder and done differently. I will give your method a try tomorrow.
Tks
CHUCKMANDO is offline   Reply With Quote
Old 11-03-2005, 09:54 PM   #4144
MRX_joe21's Avatar
Kissimme R/C Raceway Online! http://www.kissimmeercraceway.com/index.html Here some information regarding upcoming events and results from beautiful track down in Kissimmee, Florida. Home to the 2005 ROAR Fuel Nats Nov 3-6!!!
Old 11-05-2005, 03:22 AM   #4145
what's the highest gearing I can do with triple R?
23t 17t 60 55 ?
nero1943 is offline   Reply With Quote
Old 11-05-2005, 06:08 AM   #4146
ziggy12345's Avatar
You can get a metal gear set off ebay that has a 24t gear in and I think there is a 54 gear that will fit the RRR
If you want the top speed then use 65mm tyres as well. You might have to install the OS TZP .18 engine to pull that gearing though...
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 11-05-2005, 09:12 PM   #4147
Number 11's Avatar
Number 11 is offline   Reply With Quote
Old 11-05-2005, 09:13 PM   #4148
i am thinking to get a NS 15S5
Old 11-06-2005, 05:57 AM   #4149
Trader Rating: 47 (100%+)
Tks
Yes I've found the diaphrams a little on the small side in overall diameter. They simply fall in and that lets the oil leak.
I've been using Tamiya diaphrams (TRF damper seal 53576) works very good.
TOP GEAR R/C
EAST COAST HOBBIES
Craig1 is online now   Reply With Quote
Old 11-06-2005, 10:16 AM   #4150
dameetz's Avatar
Does Kyosho make rear blade type sway bar, just like Cyrul's car that I saw in the mag? What is the part no for it? And has anybody here using it?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 11-06-2005, 06:23 PM   #4151
dodo's Avatar
i use a similar one made by kawahara, not sure of the parts number though.
Old 11-07-2005, 04:25 AM   #4152
ziggy12345's Avatar
KHK 497 from here
http://shopping.rcmodel.com.hk/
Sponsored by:
Norfolk and Chance
Old 11-08-2005, 04:44 AM   #4153
dameetz's Avatar
I ve seen Kawahara's before but Cyrul's one was blue anodised, I wonder if Kyosho made one.
Old 11-08-2005, 07:08 PM   #4154
Bundy_Bear's Avatar
Default Over Drive!
Hey Guys
To cancel out the overdrive on the RRR, do you change the pulley to the 24t and just change the belt???? It appears as though the MTX4 does not currently over you this option! I look forward to reading some response
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is online now   Reply With Quote
Old 11-08-2005, 07:21 PM   #4155
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by Bundy_Bear
Hey Guys
BB
Yes, that's all you need to do.
jeffreylin is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
