Old 10-26-2005, 11:00 PM   #4126
Default where to buy RC cars stuff in Tokyo
Hi guys,
Anyone knows which is best store and location within Tokyo to get massive selection of RC cars and accessories?
I am staying at Shinagawa area.
Tigerluvbm is offline   Reply With Quote
Old 10-27-2005, 04:09 AM   #4127
k617nu-b's Avatar
The only place i know is around Akihabara area, i use to visit 4 shops there, Rakusei, Futaba-Sangyo, Super-Radicon and Champ RC. If you know how to get there, I have a map with the location of the shops...
K6
k617nu-b is offline   Reply With Quote
Old 10-27-2005, 06:14 AM   #4128
Is it near some famous street or Laox? Akihabara of some electronic shops?
Old 10-27-2005, 07:34 AM   #4129
Team-RTR's Avatar
Originally Posted by silverM3
how much performance would you see using these ceramic bearings? I am quite satisfied with the bearings coming with the kit
not much more. you would benefit more from preparing your standard car bearings properly and driving more consistently.
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 10-27-2005, 05:33 PM   #4130
k617nu-b's Avatar
Tiger,
Heres the map, just get somebody to translate the street names for you, hehehe, the farthest i guess is champ, about 10 min. walk from the JR station, hope this helps...
Old 10-27-2005, 06:36 PM   #4131
deviltires's Avatar
WHAT CAMBER AND TOE WORKS GOOD ON THE 3R IN THE REAR
DARNELL WASHINGTON-- TEAM MUGEN----FUTABA 4PK--HOT RACE TIRES
deviltires is offline   Reply With Quote
Old 10-27-2005, 11:04 PM   #4132
AndyT 's Avatar
Depends on the track layout and surface youre racing on, but a good starting point would be 3 degrees toe in and -3 degrees camber on the rear.
AndyT  is offline   Reply With Quote
Old 10-30-2005, 09:39 PM   #4133
Default V1RRR cannot get to 2nd speed
Tried to re-adjust the gears but my RRR cannot engage the 2nd gear? What is the error and what should I do?
Sorry I am still new to this hobby.
Thanks a lot guys.
Old 10-30-2005, 09:58 PM   #4134
Trader Rating: 13 (93%+)
Default 2 speed setting
try setting it back to the book plus 1 extra turn
i t hink the book is 3 turns from closed so go 4 turns from close then adjust from there
all depends on your engine rpm, maybe its shifting into 2nd straight away ?
does it take off quick or take off normally then gradually pick up speed ?
mrgsr is offline   Reply With Quote
Old 10-30-2005, 10:37 PM   #4135
This means 4 full turns ?
Engine used is a Sirio Evo3 and it takes off normally fast. But it just doesn't get to 2nd gear even though I pump the throttle. Usually in 2nd gear, there should be a noticeable kick in the car when moving. However, when I hold the car up and full throttle, I notice there is a "kick" to move in 2nd gear. But when I put the car down on the track, the 2nd gear doesn't kick.
I kind off dinked my pipe before and the stinger was pushed in. Could this be the fault also?
Old 10-30-2005, 10:41 PM   #4136
jeffreylin's Avatar
R/C Tech Charter Subscriber
Sounds like the pipe. Replace your pipe before you try to do anything drastic with your 2 speed setting.
jeffreylin is offline   Reply With Quote
Old 10-31-2005, 04:46 AM   #4137
B4
B4's Avatar
When you hold the car to test if the second gear is kicking in. Do you slowly raise the revs to find the pickup point and if so where in the rev range does it pickup ?
B4 is offline   Reply With Quote
Old 10-31-2005, 11:45 PM   #4138
Going to Japan this December, Only in Tokyo for 2 days so won't have much time to shop around. Is there any car better than this for the same price and where is the cheapest and best hobby shop in Tokyo.
theBUZZ is offline   Reply With Quote
Old 11-03-2005, 01:02 AM   #4139
MRX_joe21's Avatar
Send a message via Yahoo to MRX_joe21
It is possible to see the performances, this type of CONICAL
5 fins manifold - short type (best solution on long straights)
6 fins manifold - medium type (suggested to have more push exiting curves and on the straight)
7 fins manifold - long type (more power exiting curves)
Choose your weapon
MRX_joe21 is offline   Reply With Quote
Old 11-03-2005, 07:46 PM   #4140
Default leaking shocks
Is anyone expirancing oil coming out of the caps on top? I replaced everything ,bladder, blue cap and eyepiece. It has to be something I am doing wrong. It is slow, but there. I am almost at the point of trying mugen or associated shocks.
Tks
CHUCKMANDO is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
