Old 10-30-2004, 01:50 AM   #391
Team-RTR's Avatar
i run a RB V12 with a novarossi inline polished EFRA pipe.
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 10-30-2004, 09:15 AM   #392
thescum's Avatar
Default Front Shock Stays
Ok, had a chance to compare the differences between the shock stays offered by Kyosho (stock), Five Star, 3 racing and Kawahara's option for the RR Evo.
The Evo seems about .5mm longer than any of the others made specifically for the RRR.
The Shock position angles seem to be similar for the Five Star and the Kawahara. While the 3 racing and Kyosho's stock shock stay seem similar.
Hope this helps....
thescum is offline   Reply With Quote
Old 10-31-2004, 08:47 AM   #393
ziggy12345's Avatar
Just back from the track after the first run with the RRR. You can see why this car won the worlds!
The track was damp and so i wasnt expecting much but was really surpriced at the level of grip and how the car just went where it was pointed. Applying the power didnt seem to have any effect on the cars direction other than a slight push really hard.
I tried to get the back to spin out but found it was almost impossible if i applied the power where i normally do. I had to put the power on mid corner to get it to spin.
The track dried out in the afternoon and i had a chance to tru some foams. 35 shore Nitro shoes. The car went like an arrow down the straight and turned like it was on rails.
The setup was as per the kit with 50 weight oil and rear roll bar. I never run a roll bar at Ashby but thought i would try as per the kit setup.
The clutch setting of 1.2mm is too agresive so backed it off to .9mm and used the red shoes. I cant wait for next week!!!
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-31-2004, 10:28 AM   #394
jeffreylin's Avatar
R/C Tech Charter Subscriber
Cheers
FYI, the kit oil is #500 and it's closer to 40wt.
jeffreylin is offline   Reply With Quote
Old 10-31-2004, 10:43 AM   #395
ziggy12345's Avatar
Ok i thought the numbering system was a bit off. I fitted the single hole shock pistons on the front but people have mentioned they work better if fitted on the back. What are most people running?
Cheers
Sponsored by:
Norfolk and Chance
Old 10-31-2004, 11:05 AM   #396
jeffreylin's Avatar
Cheers
I dunno. I just built it per kit spec and it works quite well.
Old 10-31-2004, 05:47 PM   #397
bcquick's Avatar
anyone know if any of the team world setups have been posted anywhere
bcquick is offline   Reply With Quote
Old 10-31-2004, 06:16 PM   #398
Default tire offset
i have a bunch of mtx-3 fast tires. the mtx-3 tires come with a 2 mm offset. most cars do not require this offset. does anyone know if the rrr tires have a offset, i.e. will these tires work with this car?
thanks.
Joe Chaplow is offline   Reply With Quote
Old 10-31-2004, 07:14 PM   #399
InitialD's Avatar
This was posted earlier. Try the link below for the WC setups;
http://www.kyosho.co.jp/web/race/ra...ma1-10on-j.html
BTW, if you have to run rear offset tires, just try screwing in the rear pivot balls more to so that in the end the rear trackwidth is the same as with normal zero offset tires (less or equal to 200 mm).
Old 10-31-2004, 07:34 PM   #400
thanks. i am just changing over to the rrr. anything else i should know before i start building this car any and all advice will be greatly appreciated!!!
Old 11-01-2004, 01:39 AM   #401
ziggy12345's Avatar
Default Re: tire offset
thanks.
The RRR doesnt use offset tyres but does have a spacer on the axle to widen the rear end. If you change the axle for the mugen one (it fits) and dont use the spacer yu can use the offset tyres as there is room for them
Cheers
Sponsored by:
Norfolk and Chance
Old 11-01-2004, 02:57 AM   #402
Joehwee's Avatar
I run 1mm offset tyres on my RRR and FW05R, all you need is to make the car 2mm narrower and it will be fine.
HB Racing - OS Engine - VP Powermaster - Nosram - Sanwa - Schumacher Racing - HPI Racing - CapricornRC - Dualsky - Savox - AKA - Juc Racing - Team Orion - SMJ - MM Spec - Muchmore Racing
Joehwee is offline   Reply With Quote
Old 11-01-2004, 06:23 PM   #403
glad to here you like it ziggy! The rrr is so relaxing to drive.
Just a small note on maintanence. I noticed that after time the roll center bushings will wear out and allow the arms to have a little to much play. A very cheep part to replace and very easy to change out. something to check.
rcosmax is offline   Reply With Quote
Old 11-01-2004, 11:27 PM   #404
Hi, I am building this world champion 1/10 nitro power touring car. May I know if you could use AAA size battery and what will be the placement?
Thanks,
N
NetBike is offline   Reply With Quote
Old 11-02-2004, 12:47 AM   #405
Team-RTR's Avatar
i have also noticed that the bushings wear out quite quickly... i wonder why?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
