Old 10-04-2005, 09:50 PM   #4006
AndyT 's Avatar
Originally Posted by fastrcracer
Where's the best place to get Kyosho parts online ?
We don't have a lhs that stocks Kyosho parts.
If you dont mind purchasing from overseas, then Rc-Mushroom are good.....orders take about 3 days to reach Australia from Hong Kong.
Cheers
AndyT  is offline   Reply With Quote
Old 10-05-2005, 03:10 AM   #4007
ziggy12345's Avatar
Originally Posted by jas1
Ziggy i didn't suffer any understeer at tibby running the solid, the 180 deg backed bend you could run round flat out and still take a tight line, and even the tight corner into race control not a hint of under steer but could hit the brakes as hard as you like.
It must be something else with my setup then. I'll do some testing at Ashby at the weekend
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-05-2005, 03:46 AM   #4008
Trader Rating: 13 (93%+)
Default camber change...
what sort of roll center are you running on the rear, if you use the lower position this gives a lot less camber change which maybe your problem, i generally run 2nd highest position, with a 3mm shim under the camber link on top of the hub, and usually get away with 3 degrees camber and 1 degree camber cut into the tyre
Hello
i am using the stock roll centre front and rear
the track i race on is a medium grip track, carpark type asphalt with some small bumps. i use 37 shore tyres but on hot days with high grip we use 40s.
is the standard roll centre high or low ?
mrgsr is offline   Reply With Quote
Old 10-05-2005, 06:23 PM   #4009
AndyT 's Avatar
Originally Posted by mrgsr
what could be somthing that im not doing wrong ? or something to look for
thanks heaps
John
Also check the balls on top of the rear hubs and the camber links to make sure they havent worn and created any slop.
Cheers
Old 10-05-2005, 06:58 PM   #4010
Default camber..
na there all fine
the car is only a few race meets old
Old 10-05-2005, 11:59 PM   #4011
Default Bumper
Hello, I was thinking of changing from the Mugen to the V-one RRR but the thing that concerns me is the front bumper...does it have a front bumper? How do you keep from breaking parts if you dont have a hard front bumper?
Dowg is offline   Reply With Quote
Old 10-06-2005, 12:03 AM   #4012
jeffreylin's Avatar
R/C Tech Charter Subscriber
It's really not an issue. The foam bumper absorbs most of the shock and works great. It is attached to smaller plastic bumpers and no one I know has any problems.
jeffreylin is offline   Reply With Quote
Old 10-06-2005, 02:22 AM   #4013
Dynamite's Avatar
Send a message via MSN to Dynamite
i smacked a stalled car at the end of our straight at home just coming off second gear gliding through corner... cracked him square on... no damage done at all to my surprise. rrr seems to be fairly resiliant to any serious damage.
mrgsr
front std rollcenter is 2nd lowest (b upper) rear std rollcenter is 3rd highest (b upper) afaik these are the std settings...
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 10-06-2005, 02:27 AM   #4014
Dynamite's Avatar
Default Clutch Shoes
hey, has anyone tryed the red clutch shoe?
just wondering what characteristics or circumstances you would want to use the red shoe over the std grey shoe and how it differs from the grey one in clutch feel whilst driving?
Old 10-06-2005, 07:35 AM   #4015
freefallmarine's Avatar
I used the red clutch shoe on loose tracks, it smoothe's thing out but it's deciving because you "feel" the car is slipping when it's really not. I went crazy cause i thought it was my clutch setting. But once you get used to it it's feels good. less punch but make's for smooth driving.
freefallmarine is offline   Reply With Quote
Old 10-06-2005, 05:56 PM   #4016
AndyT 's Avatar
na there all fine
When youre setting the camber, what are using to measure it? A camber gauge against the wheel, or a setup station?
Old 10-06-2005, 06:00 PM   #4017
AndyT 's Avatar
Yep it has a front bumper (which you`ll have to trim to size to fit your particular body)....and it really stands up to some quite substantial punishment...its very good
Cheers
Old 10-06-2005, 06:10 PM   #4018
Default camber..
i normally use the rpm camber gauge
or sometime i use a setup station, i put the ride height gauge under the chassis, push down to the rideheight i want then set the camber.
Old 10-06-2005, 06:13 PM   #4019
jeffreylin's Avatar
You should really set your ride height before you set the camber.
Old 10-06-2005, 06:17 PM   #4020
yeh i do set the ride height first
a q. about the setup station, is it possible to set the ride height with it ?
one problem i find is is et the ride height with the tyres im about to use before the next race. then i put the car on the setup station and the ride height is different ?
is that normal
thanks for all this help guys
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
