Kyosho v-one rrr
Old 10-01-2005, 04:30 PM
  #3976
Trader Rating: 19 (100%+)
Originally Posted by spookyeng
I just bought a V-one RRR wc edition and was wondering how the 3-racing aftermarket parts are on quality and fit? There are some products from 3-racing that I am interested in, but wanted to get opinions on the products before I spend the money. I am looking at getting all the pulleys in alluminum.
Any other recommendations for aftermarket parts or stock Kyosho parts would be greatly appreciated. I have been out of On-road for awhile and previously raced a Nitro TC3. Thanks in advance for any inputs. Take it easy.
The WC edition is pretty good out of the box. I added an Indo Phenolic Brake Disc from Avidrc. Its more resistance to fading than the stock brake disc. Pdub makes a nice foam bumper thats a lot stiffer than the stock foam. Kawahara makes a nice aluminum brake arm. If you want to run a locked front diff, 3racings aluminum insert wont strip like the plastic one.
sjr456 is offline
Old 10-02-2005, 07:49 AM
  #3977
Hi guys,
Just to confirm on what i need to buy to make a front diff.
1. Differential joint (19) vz218
2. Bevel Shaft BS107
3. Differential gear set vz012
4. pully set vz203
5. differenntial pully set vz204
These parts are listed in the the manual however I believe I do have some of the parts as spares. Could u guys let me know what parts I need to buy.
and do u guys recommend updating the suspension shaft to the titanium ones?
tiger266 is offline
Old 10-02-2005, 04:36 PM
  #3978
drfritz's Avatar
Default front spool
Ok, I have read through the post, and can not find what I was looking for any ways, I did read at one time on this thread there was a aluminuim adapter to put in the front diff to make a spool, i thing 3r racing makes the part, does any body have a part number?
drfritz is offline
Old 10-02-2005, 06:36 PM
  #3979
Part number is V3R-005. I bought one from rc-toro.com.
sjr456 is offline
Old 10-03-2005, 12:39 AM
  #3980
AndyT 's Avatar
Originally Posted by pme
Problem #1 : My friend hit me and my dogbone pop-out. according to the manual, put 1 o0ring in the outdrive. is it enough? or do i nedd to place fuel lines/hose to the outdrive? pls help.
The Kyosho or 3-Racing front swingshafts should help with this problem.
AndyT  is offline
Old 10-03-2005, 12:44 AM
  #3981
AndyT 's Avatar
Originally Posted by tiger266
Hi guys,
4. pully set vz203
You`ll need the screws to assemble the diff cases, and from memory you`ll also need shims and diff case seal.
AndyT  is offline
Old 10-03-2005, 12:46 AM
  #3982
Default setup
just finished building the car last week. i took the car out for the first time this past saturday. i was wondering if anyone had any setup suggestions for a tight track??? her is a pic of the completed car.....thanks in advance!!!
enzo78 is offline
Old 10-03-2005, 08:20 AM
  #3983
dameetz's Avatar
Default Loose rear end
I ve been using RRR since it came out and my setting is pretty much the stock setting except I m using front diff and lowest hole for the rear arm roll center adjustment. And all these while I just raced it in a tight parking lot track however recently I raced it at a permanent big track with long sweeper and I noticed the rear end is very nervous during the high speed sweeper as well as in a chicane. I m using a one way set up for the big track and tried different tyre combination however this doesn't solve the loose rear end problem completly. At the moment I m using 40 F and 37 R which I think only reduces a bit of my problem. Can someone help me with this? Any suggention on set up? Will using front spool solve this?
dameetz is offline
Old 10-03-2005, 08:24 AM
  #3984
ziggy12345's Avatar
Increase the toe in to 4 deg.
Cheers
ziggy12345 is offline
Old 10-03-2005, 04:36 PM
  #3985
AndyT 's Avatar
Try running the front anti-roll bar in a more vertical position.....this should help tame the nervousness of the rear.
AndyT  is offline
Old 10-03-2005, 05:24 PM
  #3986
personnally i think you never need too run a oneway in the rrr, just done a national in the uk, its pretty much the fastest flowing track in the uk, you look at the track and think deffinetly use the oneway, but the solid axle was so much better.
i'm also finding the car is at its fastest when the tyres have worn too a 1mm split (using 23t pulley) instead of the recommended 2mm, anyone else found this
jas1 is offline
Old 10-03-2005, 05:52 PM
  #3987
wendellc1's Avatar
Hi Jas1,
What to you need to make the one-way to a solid. Thanks.
wendellc1 is offline
Old 10-04-2005, 04:36 AM
  #3988
AndyT 's Avatar
Oddly enough the fastest lap times i was getting at my local track were achieved using no split.....58mm on all four wheels.
Running the 2mm split i cant get anywhere near the fastest lap times i achieved with a zero split
AndyT  is offline
Old 10-04-2005, 05:02 AM
  #3989
etgdpu's Avatar
Hi,
The car is more front driven. Therefore, easier to drive but generally slower. Your belts also suffer.
etgdpu is offline
Old 10-04-2005, 05:10 AM
  #3990
ziggy12345's Avatar
I dont like the understear you get with the solid. I used the one way at Tibby and found the steering much better. My F final result didnt really prove the theory though!! LOL
The 1mm split seems to work well with me. I start off with 2mm and it seems to improve after 8 laps or so, i thought it was just me waking up halfway through the race!
Cheers
