Old 09-27-2005, 01:54 AM   #3946
ziggy12345's Avatar
Originally Posted by bulletdays
What happen is that, i run for several laps and it doesnt have a consistent situation where the engine dies, sometimes after a straight but usually when it goes into turn. I have used several glow plugs(Nova#5,#6, OSP6) but still doesnt work.
thanks.
Lean out the bottom end. If it then idles fast adjust the idle screw
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 09-27-2005, 04:30 AM   #3947
bulletdays's Avatar
Default Thanks
Hi guys,
thanks for the info, i have feeling that its the tuning, yah i was thnking the bottom end too, like what andy says. I will try it on friday..thanks a lot guys.
bulletdays is offline   Reply With Quote
Old 09-27-2005, 04:44 AM   #3948
esham's Avatar
Bulletdays, get your expert local rc friend to tune and teach you their trick on this matter. Because engine tuning for beginner is abit tricky.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 09-27-2005, 02:05 PM   #3949
Hi guys,
If you are new to nitro, I would suggest getting a OS engine. It is easier to tune.
silverM3 is offline   Reply With Quote
Old 09-27-2005, 04:45 PM   #3950
AndyT 's Avatar
Originally Posted by jeffreylin
I don't think glow plugs have anything to do with it--I think it's the tuning.
Yep gotta agree with you Jeffreylin....I reckon its tuning as well, but I`ve also seen these type of symptoms caused by stale/bad fuel.
AndyT  is offline   Reply With Quote
Old 09-27-2005, 06:55 PM   #3951
drfritz's Avatar
[setting bottom end, clear motor out a few times and listen to the idle for about 30 seceonds, if it goes up then the bottom is to lean, if it goes down and wants to die then it to rich. another way is to do the clearing it out and pitching the fuel line right at the carb, revs up and dies right away , to lean, if it sits there and bubbles along for some time then to rich, should have a nice steady increase it speed before it dies, hope this helps. you might check the fuel tank seal you might not be getting enough back pressure, this will cause alean problem too and all the carb tuning in the world is not going to help if its the lid.
drfritz is offline   Reply With Quote
Old 09-28-2005, 01:30 AM   #3952
Default Setup for Rubber tires
Hey all,
Got a bit confuse reading throught some of the threads...Hope someone can clearify for me. Do I need special pulley, or wheel offsets if I run rubber tires?
What would be a good setup for running rubber?
chumanji is offline   Reply With Quote
Old 09-28-2005, 01:31 AM   #3953
bulletdays's Avatar
Thanks for all the ideas, i will try it and see whats really the cause.
Maybe Andy is also right, it could be the fuel.
Thanks guys.
Old 09-28-2005, 01:38 AM   #3954
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by chumanji
Hey all,
You need to use the optional 24T pulley (included in the kit) in front and the longer 387 side belt (not included in the kit).
jeffreylin is offline   Reply With Quote
Old 09-28-2005, 03:54 AM   #3955
pme
pme's Avatar
Default .
guys, as you know, the throttle for the car is prone to bumps of another car coz the throttle servo is placed on the side. even when theres protector bar, do you think that the bar can handle the force from a bump? and i just tested the car, the servo horn broke. what do you think should i do? is there a hop-up fot this (servo horn) coz i use the stock servo horn included in the kit. futaba. its a plastic. has any1 of u guys expericenced this? and any1 broke the throttle servo?
pme is offline   Reply With Quote
Old 09-28-2005, 07:12 AM   #3956
bulletdays's Avatar
Default Hey PME
My throttle servo horn also got broke when someone hit me from the side. I use the same horn as you did. I bought a new servo horn which is much ticker and flexible i forgot the brand its color yellow, i hope this one works now.
Old 09-28-2005, 10:30 AM   #3957
RC_Greg's Avatar
weight
...Out of curiosity, how much does your RRR or RRR-WC weight?
(ready to run, with battery, without fuel)
thanks!
RC_Greg is offline   Reply With Quote
Old 09-28-2005, 10:42 AM   #3958
Data's Avatar
this mod should take care of it. the two al. blocks are kind of bulky so i changed them to four 0.25" O.D. al. posts. it work just as good and is easier to make yourself.
Data is offline   Reply With Quote
Old 09-28-2005, 11:01 AM   #3959
pme
pme's Avatar
Default .
wow!! is there any third party who makes that hop-up? my problem now is where can i get the alum. thing.. but atleast, i have an idea how..
Old 09-28-2005, 11:16 AM   #3960
luketob's Avatar
mine weights 1735 with body less fuel on last RD logics race
luketob is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
