Old 09-23-2005, 10:58 AM   #3931
Thanks for the feedback all. Looks like $320 is a good price.
BTW, the clutch assembly in RC-Toro is out of stock. But now I know the prices from my LHS is overprice. They wanted $86 for it while RC-Toro listed for $60. (Ultimate hobby doesnt have the entire clutch, but they have part of it...)
chumanji is offline   Reply With Quote
Old 09-23-2005, 09:22 PM   #3932
Tim Johnson's Avatar
It is not over priced. It is just your Local hobby shop has to pay for a shop. RC-Toro is an internet store, which does not have over head. RC-Toro might be a over seas place in hong kong or something, so you will pay very high prices for shipping. Call 1-800-716-4588 to get the correct US retail price.
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 09-23-2005, 10:26 PM   #3933
boner's Avatar
Thumbs up
rc-toro.com is in Cali, USA. they charged me, 5 dollars for USPS on my previous orders.
boner is offline   Reply With Quote
Old 09-23-2005, 11:17 PM   #3934
oK COOL!! thats good to hear
Airtronics|Kyosho|
Old 09-24-2005, 07:49 AM   #3935
impalabob64's Avatar
Send a message via AIM to impalabob64
Default gearing
hey ,anyone know the best gear combo for fortmeyers track i will be running my novamaxx engine but will hve my sirio evo3 for backup.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 09-24-2005, 05:21 PM   #3936
SnakeEyz's Avatar
Hey I'm new to the rrr and was curious what is the difference in the 384 and 387 side belts
SnakeEyz is offline   Reply With Quote
Old 09-24-2005, 11:57 PM   #3937
B4
B4's Avatar
Different front side pulley gear required for the 387T belt. This one is for when using rubber tires as no split between front and rear diameter is required.
B4 is offline   Reply With Quote
Old 09-25-2005, 05:49 AM   #3938
BrainTeased's Avatar
hi B4
i was wondering what would happen if you used the 384T with the 24T front side pulley for rubber tyres... would this still give me overdrive because i have 384T to go through on the belt.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 09-25-2005, 09:56 AM   #3939
whether your running the 384 or 387 your gearing will still be the same, the 384 is very tight fit, and to run it loose enough the belt rubs on the exhaust manifold
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 09-25-2005, 05:01 PM   #3940
B4
B4's Avatar
Originally Posted by BrainTeased
hi B4
I think there is currently about 1% overdrive when running the standard configuration with foam tires and a 2.5mm split between the front and rear tire diameter. There are many calculators available to enter your pulley's and tires sizes that will tell you the % overdirve.
Old 09-25-2005, 11:40 PM   #3941
AndyT 's Avatar
Originally Posted by pme
guys, my sidebelt for the 3r is touching the base of the manifold. is it normal? if not, what should i do?
Its normal, to get around this problem without having to grind exhaust manifolds fit the Kyosho FRP Middle plate....this will move the tensioner pulley further to the rear of the car and allow greater clearance under the exhaust manifold.
Cheers
AndyT  is offline   Reply With Quote
Old 09-26-2005, 04:34 AM   #3942
bulletdays's Avatar
Default Some Problems
Hi guys,
I hope someone can give me an idea how to overcome this, the engine always die when after several laps, ive tried to replace a new glow plug, and its still the same thing. I wonder why, but it runs normally i could run for several laps, but the engine die and i cant finish even a tank without this problem. Im using 16%, and Hot glow plug.(Even tried the medium plug but still the same).
Hope you can help solve this out. Thanks a lot.
Andy thanks for tips regarding my push problem.
bulletdays is offline   Reply With Quote
Old 09-26-2005, 10:14 AM   #3943
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by bulletdays
Hi guys,
How does it die? If it dies after a long straight you are too lean on top. If it dies when you come in to pit it could be too rich in the bottom or your idle could be too low.
jeffreylin is offline   Reply With Quote
Old 09-27-2005, 12:07 AM   #3944
bulletdays's Avatar
Default Hi Jeff
What happen is that, i run for several laps and it doesnt have a consistent situation where the engine dies, sometimes after a straight but usually when it goes into turn. I have used several glow plugs(Nova#5,#6, OSP6) but still doesnt work.
thanks.
Old 09-27-2005, 12:12 AM   #3945
jeffreylin's Avatar
thanks.
I don't think glow plugs have anything to do with it--I think it's the tuning.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
