Kyosho v-one rrr
#3916
clutch problem
ok thank you.. i am also experiencing clutch problem. can anyone help me out? my kit is new, and i already assembled the centax. all parts isset but, when i am locking the allen screw (last thing to screw) the clutch bell will not rotate free. instead when i rotate the clutch bell, the flywheel also rotates together with the clutch bell. i already set the the nut above the spring, the bearing was in place, the 2 shims are there and under the shims, are the bearing (sandwich by spacer of housing for the bearing.
#3918
Originally Posted by pme
guys, my sidebelt for the 3r is touching the base of the manifold. is it normal? if not, what should i do?
#3919
Originally Posted by KYOSHORACER
I have been having problems setting my clutch in my RRR WC. Have any of you guys got some set-up tips for setting them up please. Its seems as thoug it is not coming out far enough fo it to engage properly. It is set to the standard settings in the manual 1.25mm. What do you guys run???
#3920
Setups
Does anyone have any good setups the the v one rrr with a front diff. We run on tighter tracks here and most are in parking lots with a lot of hairpins.
#3921
guys:
if you found the rear outdrives and dog bones wears out faster than you would like on the RRR, this mod might help.
make two spacers (0.380" O.D. X 0.157" I.D. X 0.290" H), get a set of mugen outdrives and put the diff. together as shown. i use EVO rear dog bones instead of the mugen one becasue mugen's might be a bit too long. i ran the car for 3 days and the wear on the rear outdrive is much much better.
just got a steel first pinon from master ken, so i don't have to change 1st pinion every two weeks.
the only thing left is to make the roll center blocks last a little longer.
data
data
#3922
An alternative is to just make your own, it's very easy I just used a piece of carbon fibre I had and it's as good if not better than the one from Kyosho.
#3923
Rear wheel offset
Does anyone know whether Kyosho makes an offset to that I can run 0mm wheels on the back of my V One RRR WCE. I want to run TRC tires abut can't get them in 2mm offset.
I am afraid of just putting a 2mm spacer on the hex because of strippng the hex in the wheel out.
#3925
you need to use the standard rear stub axles, then you can fit the 2mm spacer between bearing and hex to use 0mm offset, part no. vz081 i think
#3926
Thanks I'll try it.
#3927
Is $320 for V-One RRR a good price?
Someone offer me a V-One RRR #31256B for $320. Brand new still in box. Is this a good price?
And does anyone know where I can pick up another clutch assembly for the V1RRR. I would perfer online store...if any.
#3928
#3929
That is a good price. you can get the parts you need at ultimate hobbies. Give them a call, and they can ship it out to you....
Get your pre orders in quick for the V-OneRRR WC edition. The WC is a limited production model. there will be one more batch shipped out at the end of november, and that will be the end of the WC edition. But don't worry, yoiu can stll get the normal V-OneRRR. the only major differences between the WC and the non WC are 12 kyosho option parts, which will still be available even after the WC's are gone.
#3930
