Old 09-12-2005, 11:41 PM   #3901
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by deviltires
i just put my 1 way in my car and it seems like the universal does not fit in the outdrive far enough i screwed in the hubs and it still lookks like they still want to come out can anyone give me some help
If you are not missing the spacer that Jeff mentioned then that is normal.
The outdrive if you notice is not captured by the one-way differential so when under load the outdrives will move laterally to meet with the dogbones. You shouldn't worry about it. That's something most cars have in common.
Racing4Evo is offline   Reply With Quote
Old 09-13-2005, 06:41 PM   #3902
Default 2 degree front kingpins
This is the first time I will be trying them. I know it is supposed to give more onpower steering. Do you guys run them with your normal setup you would use for the standard ones? I will be on a mod to large size track more larger turns than hairpins
CHUCKMANDO is offline   Reply With Quote
Old 09-14-2005, 07:03 PM   #3903
impalabob64's Avatar
Send a message via AIM to impalabob64
Default josh cyrul
hey guys does anyone know if josh, was using an oneway or a spool when he raced in Texas Biggie in his setup it didn,t say.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 09-14-2005, 07:10 PM   #3904
jeffreylin's Avatar
R/C Tech Charter Subscriber
just use them with your normal set up. in fact, you might want to try adjusting the caster clips first before you put on the 2 degree knuckles--you might not need them.
jeffreylin is offline   Reply With Quote
Old 09-14-2005, 07:17 PM   #3905
Default hey jeffery
bobby here do i will trying out josh,s texas setup was he running a spool or oneway . loving my rrr think about the fwo sometimes.
RoninRc.com
Basher BT-4
Old 09-14-2005, 07:21 PM   #3906
jeffreylin's Avatar
hey bobby i don't know. i haven't been there so i can't say, but i would only run spool if heavy breaking in needed to go fast.
Old 09-14-2005, 08:15 PM   #3907
I have been having problems setting my clutch in my RRR WC. Have any of you guys got some set-up tips for setting them up please. Its seems as thoug it is not coming out far enough fo it to engage properly. It is set to the standard settings in the manual 1.25mm. What do you guys run???
KYOSHORACER is offline   Reply With Quote
Old 09-15-2005, 02:09 AM   #3908
carkillaii's Avatar
custom made spool
carkillaii is offline   Reply With Quote
Old 09-15-2005, 03:04 AM   #3909
RC_Greg's Avatar
hop-ups ???
Hi Guys,
I'm new to nitro racing and I want to get a good car that's very reliable. Can I get a RRR and race it "out of the box" and expect no surprises? Do I need to upgrade certain items?
Thanks!
RC_Greg is offline   Reply With Quote
Old 09-15-2005, 04:54 AM   #3910
Thanks Jeffrey, I was thinking along those lines too. I will try each.
Old 09-15-2005, 05:41 AM   #3911
mcsquish's Avatar
He almost always runs a spool. He told me to run one and the car is much better. I don't think I will be putting the one-way back in any time soon. It took away the twitchyness and made the steering feel better through the entire corner. You have to drive a little different, but I like it and I think it is faster.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 09-15-2005, 05:46 AM   #3912
mcsquish's Avatar
Originally Posted by RC_Greg
Hi Guys,
Thanks!
All I have changed is the break arm. It spun on the post so I pinned it, then I just went to an aluminum one. And I put on a thicker rear shock tower because I was afraid I might break it if I traction rolled and put it into a wall. And I put a spool in instead of a one-way. That's it. I'm thnking that is all you might want to do. In my opinion the rest of the car is good as-is.
Old 09-16-2005, 03:12 AM   #3913
pme
pme's Avatar
Default .
guys, my sidebelt for the 3r is touching the base of the manifold. is it normal? if not, what should i do?
pme is offline   Reply With Quote
Old 09-16-2005, 03:45 AM   #3914
I ground the bottom of the manifold. It has little cooling fins on it, I removed them (just where the belt was hitting).
Ted Flack is offline   Reply With Quote
Old 09-16-2005, 04:06 AM   #3915
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
