Kyosho v-one rrr
Old 09-03-2005, 08:12 PM
  #3796
froilan's Avatar
Ghoppa......YGPM.....
froilan is offline
Old 09-03-2005, 08:48 PM
  #3797
ghoppa's Avatar
Trader Rating: 55 (98%+)
Froilan,
back at cha'!!!!!
ghoppa is offline
Old 09-04-2005, 12:19 AM
  #3798
hey guys,
What gears do you guys run at long and large tracks? When my car hit the straight, the top speed just stays here The 1st gear the spur is 61 and 17t. 2nd gear is stock.
nero1943 is offline
Old 09-04-2005, 12:36 AM
  #3799
Team-RTR's Avatar
Originally Posted by AndyT
Oops got ya msg a bit late but yep i raced there yesterday, glad that the weather held up long enough to get thru most of the finals before it rained
howd ya go? i done a PB of 19 laps, 7th in the A final
Team-RTR is offline
Old 09-04-2005, 06:13 AM
  #3800
pme
pme's Avatar
Default question
wana ask everybody if my engine (nova rossi Mt-12) used in mtx2 mugen will fit to kyosho trple r? and if the engine mounts included in the kit will fit also? tnx.. also the manifold wil fit the 3r used in mtx2?
pme is offline
Old 09-04-2005, 06:27 AM
  #3801
Mie3R's Avatar
Originally Posted by nero1943
hey guys,
try this out : 17/61 and 23/55
Mie3R is offline
Old 09-04-2005, 06:37 AM
  #3802
Mie3R's Avatar
i just come back from race today using that gear combo. almost Tq if not becoz of my teammate hit my back. i managed to overtook another cars using OS TZ 5port at the long straight...
Mie3R is offline
Old 09-04-2005, 06:54 AM
  #3803
im thinking to get the 5 ports too
nero1943 is offline
Old 09-04-2005, 12:30 PM
  #3804
fastrcracer's Avatar
Where are the best places to buy parts for the rrr on the web ?
I live in the midwest and parts for Kyosho kits are hard to come by.
Thanks in advnce.
fastrcracer is offline
Old 09-04-2005, 01:13 PM
  #3805
drfritz's Avatar
Ok I know this is the rrr thread, but the rr thread is dead. any ways I got the evo chassie and I'm running vone rrr rear up rights and 2 deg fronts knuckles, and I'm having a hell of a time with traction rolling.
car feels good in all the high speed sections but is giving me fits in slow speed corners, this is the strange part its going on during power on exit of the corners
set up is
shocks 60wt all four corners
gold springs up front, black in the rear
shockes lay all the way down both ends
1/2 toe out in the front
3 toe in on the rear
0 droop in the front, up stops set so chassie does not bootom out
1 droop in the rear, up stops set same as front
2 1/2 neg camber in the rear
2 neg in the front
37 shore all the way around
3 mm split on the tires
high traction surface.
drfritz is offline
Old 09-04-2005, 01:29 PM
  #3806
drfritz that is strange. You are running pretty much my set on my Evo except that I still run the Evo uprights and front arms. It must be something easy. Did you just move to the newer arms and the problem started? I do run about 4 on the rear droop using a Hudy setup station. Any binding in the belts or rear diff?
JEFF
jeff whiting is offline
Old 09-04-2005, 01:33 PM
  #3807
jeffreylin's Avatar
Thanks in advnce.
Deano's Raceway & R/C Shop
4547 North Dixe
Elizabethtown , Kentucky, 42701
(270) 234-0051
HOBO's R/C Planes & Cars
208 W. Main St.
Leitchfield , Kentucky, 42754
270-879-3173
Got them off the Kyosho America web site www.kyoshoamerica.com
jeffreylin is offline
Old 09-04-2005, 01:43 PM
  #3808
drfritz's Avatar
JEFF
I had the same thought , tore the car apart and found no problems, what strange is that every body else was saying the track was loose in those section so the kept putting vht down just adding to my problem, it was just two stupid corners that were giving me problems a quick right and right back to a lefty. (pork chop) it's has to be in the set up, car was real good till they did that. maybe more camber or more roll center in the back?
drfritz is offline
Old 09-04-2005, 02:26 PM
  #3809
I guess if there isn't anything physically wrong with the car then it must be setup. You must be getting way to much bite. Your chassis must start rolling through that section and just keep going right through the up stops. If you tighten up the roll center I am sure that would help. Those rear up rights may have upset your rear roll center. This is an area that always seems to get people in a tizzy but to me 1 droop setting on the rear is going to allow a lot of movement of the chassis. I would try 3 or 4. The Evo is a great car. Its tough and doesn't eat parts. I am curios what size track you run on. PM me sometime.
JEFF
Old 09-04-2005, 02:28 PM
  #3810
jeffreylin's Avatar
The easiest fix could be running harder tires in front. Try 40 or even 42 in front and see if that works. On a VHT prepared track we run 42 or 45 in front with 42 in the rear.
